Off Camera Flash Photography Thread
Discussion in 'Photography' started by medic2230, Apr 14, 2014.
  1. Apr 15, 2014 at 10:55 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
  2. Apr 15, 2014 at 11:10 AM
    medic2230
    medic2230 [OP] @Koditten Pirate Radio member #002
    Murph
    Bama! Roll Tide
    My setup. Not as compact as Chaz's
    I had my eye on the future with bigger strobes so I went with bigger medium duty light stands. Glad I did cause the parabolic is a monster umbrella. lol
    BTW don't bother with the umbrella mount (ball type) like is on the second from the bottom light stand. They are not very secure when holding a $550 flash and umbrella. I went with the Manfrotto on the bottom light stand and it is very stable and secure.
  3. Apr 17, 2014 at 8:17 PM
    medic2230
    Murph
    Bama! Roll Tide
    Let's start with the stuff you will need to get started in off camera flash photography.
    1) Flash
    First you will need a flash of some sort. This doesn't have to be one of the high dollar camera maker brands. For this type of use we can use simple manual flashes such as the Yougnuo YN-560-II or YN560-III. These sell for around $70-80. Both of these flashes also have what is known as a PC connection on them.
    2) Trigger
    You need some way to make your camera and flash know what the other is doing and when to flash. This can be done a couple of ways.
    A)Lowest cost and most reliable is the old fashioned sync cable. These cables run around $15-20. One problem you may run into with newer camera's is that the camera doesn't have a PC connection on it which is what the sync cord plugs into. That can be solved with a PC adapter (PC adapter example)that fits on the hotshoe of your camera. With this setup you will always be tied to the cable though.
    B)Next and mostly reliable is infrared with Nikon and I believe canon has something like it also. With Nikon you can use the built in flash to fire the remote flashes. Note that it is not compatible with the lower end flashes. With this setup you need to have line of sight with the flash sensor and the camera.
    C)Radio triggers are some of the most reliable also, kind of. Radio trigger can be as cheap as $30 (pair) or as expensive as $200 (each). For $30 you can get some chinese triggers off ebay and would probably work to begin with if you want to save some money. Want the industry standard? Well Pocketwizard would be just that. They start at $99 each and you will need at least two of them (one for the camera hotshot and one for each flash). Yougnuo also makes triggers for around $70 for a pair and I've heard good things about them. These will work through walls and around corners.
    Now that we've gotten the complex part done let's move on.
    3) Light stand
    These stands hold your flash and light modifier (umbrella) up in the air. They vary in price and size ($20 and up). To start with a light weight stand will get you started and will be easy to carry and store.
    Example:
    http://www.adorama.com/LTSPS.html
    4) Umbrella / flash adapter
    This is what actually holds your flash and the umbrella on top of the light stand.
    Example:
    Flash Adapter
    5) Umbrella
    These vary some by material. There are white (versatile) and silver. The white produces a nice soft light like what we are looking for with this setup. The silver gives a more contrasty appearance. To start off we'll go with a white convertible umbrella. This is a white umbrella with a black cover over the top of it. The black cover has a silver inner liner to help reflect light back when we are bouncing the light. The black cover and also be removed and the umbrella turned around to use as a shoot through. Basically the flash shoots throughout the white fabric and it makes a nice soft light. Prices will vary for umbrella's from $15-over $100.
    Example:
    Convertible umbrella
    You can also get kits that have the light stand, flash adapter, and umbrella combined. For a reasonable price.
    Example:
    westcott-collapsible-umbrella-flash-kit-includes-umrella-stand-bracket
    Disclaimer:
    I used the above websites as examples. I can't recommend them because I haven't used them personally. Adorama is a well known camera store and has been around a long time. Mid West Photo Exchange is what David Hobby (The Strobist from second post) refers people to. I have used B&H photo and have not had any issues with them.
  4. Apr 25, 2014 at 7:53 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    For my commercial catalog clients, I bought a Dynalite 1000w/s 4 head system about 9 years ago and it has proven to be the best $$$ I have invested. It's a work horse and produces very consistent solid work.
    For my smaller jobs though, I have found that my single 600ex-rt bouncing backwards into a 40" translucent works great for me as well.
    I was raised on "It's not what you got, but how you use it."
  5. May 20, 2014 at 7:43 AM
    medic2230
    Murph
    Bama! Roll Tide
  6. May 20, 2014 at 3:49 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    s
    i once had a client who brought something similar to a location shoot. It was convenient for the first few outfits, but once it drained after a couple hundred shots, it became a paperweight to lug around.
    After that, if i don't have a generator, i just use speedlights and bring extra batteries.
  7. May 20, 2014 at 5:49 PM
    medic2230
    Murph
    Bama! Roll Tide
    This is an ac/dc unit. Comes with the battery and ac cord.
  8. May 20, 2014 at 7:44 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    Are you looking to use it more as an AC unit or equally DC?
    $400+ is good chunk of change...
    You could always get an AC unit and then out on location, plug into your truck's AC plug... Wish my first gen had that plug...
    What are you planning to use the lighting for?
  9. May 21, 2014 at 9:46 AM
    medic2230
    Murph
    Bama! Roll Tide
    More as an AC unit. My truck doesn't have the plug in the bed either.
    The pricing on these is less than $400. The 150ws goes for $304 and the 300ws is $317. Not much difference in the two.
    I'll mainly be using it inside for portraits with occasional use outdoors in late evening to be able to overpower the sun. Could be used mid-day in the shade I suppose. Do you think that the 300ws would be too powerful for a small studio inside? I see some people go for the 150ws inside a small studio. Modifier wise I will have it on a 28" or 50" soft box. I'll also use it for a 7' Parabolic umbrella. It takes 3 speedlights to light it up.
  10. May 21, 2014 at 10:11 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    300ws is doable indoor studio... i use between 125 to 1,000 ws depending on what focal plane i want to play with...
    if not shooting high volume, the DC is convenient for fill outdoors and in dark places...
    i am a minimalist by nature so i use my speedlight and bounce in dark places and outdoors... more convenient for me to swap out AA batteries than wait for recharge...
    this is my typical setup, even on clothing company lookbooks...
  11. May 21, 2014 at 10:15 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    For studio modifier, I really like the look of a big Octabank or Octabox
    soooooooooooo nice
    beauty dish is really nice too...
  12. May 21, 2014 at 11:50 AM
    medic2230
    Murph
    Bama! Roll Tide
    Yeah I was thinking if I could get away with the 300ws unit indoors I'd go with it for $13 more. I figured I'd start out with one strobe and supplement it with speedlights if needed. I like simple.
    I really like the Octabox and beauty dish looks too.
    Here's the link to one with actual pricing.
    300ws
    http://www.bhphotovideo.com/c/product/569952-REG/Interfit_INT474_Stellar_Xtreme_300_Watt_Second.html
    150ws
    http://www.bhphotovideo.com/c/product/569951-REG/Interfit_INT473_Stellar_Xtreme_150_Watt_Second.html
  13. May 21, 2014 at 12:14 PM
    medic2230
    Murph
    Bama! Roll Tide
    You have some really awesome shots from such a simple approach.
  14. May 21, 2014 at 4:45 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Less is almost always more :) minimalist here as well :)
  15. May 21, 2014 at 6:18 PM
    #35
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    thanks! when i first started back in the late 1990s (yah, im a little old), i bought all kinds of monolights, modifiers, portable battery packs, etc... the older i got, the less i wanted to carry...
    although now that i have an assistant, i will bring some of the bigger stuff out, but 95% of the time, i shoot with that single speedlight and bounce setup...
  16. May 21, 2014 at 6:19 PM
    #36
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    that's how i feel about some boob jobs... haha
  17. May 21, 2014 at 6:54 PM
    #37
    medic2230
    Murph
    Bama! Roll Tide
    I started in 1984 :eek: Advanced to studio and darkroom by 1988. Back then I was using a 3 light Paul C Buff White Lightning 10,000 setup. Remember them? The big white can strobes. lol
    I don't want a huge setup now. Just something that I can light my modifiers I have up with. Cheaper to buy a monolight than another speedlight and hope 3 of them will put out enough to fill it. I was looking at the Flashpoint 320M from Adorama but they are never in stock. I can buy the Interfit locally.
  18. May 21, 2014 at 7:02 PM
    #38
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    whoa, 1984?
    i didn't have that kind of discipline at that age... i was too busy ditching 5th period...
  19. May 21, 2014 at 8:42 PM
    #39
    medic2230
    Murph
    Bama! Roll Tide
    What flash bracket are you using in the photo above, Mike?
  20. May 21, 2014 at 8:55 PM
    #40
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    it's a Stroboframe VH2000 with a discontinued anti twist plate... i got this bracket back in 2002 during my paparazzi days...
    this is just a stock photo of it... mine is a bit banged up in comparison... hahaha
