Off center driveline?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alderleet, Oct 25, 2013.
  1. Oct 25, 2013 at 8:34 PM
    Alderleet
    Alderleet [OP] Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    On my fun adventures, trying to track down and murder the Tacoma Shake demon, i've stumbled onto a clue.
    Is anyone elses rear driveline off center?
    Meaning, your output flange from the rear of the transmission, to the flange on the rear differential, sit a inch or so offset (lateral, not vertical) from one another?
    I was changing my Carrier Bearing, and I noticed my shit was slightly cock-eyed. The carrier bearing wanted to bolt up with one side further forward than the other. That signaled to me that something might be wrong.
    Thats when i busted out the ghetto plumbs (wrenchs tied to strings), and started comparing straightness (used frame as reference)
    Sure enough, the output flange on the Transmission, and the flange on the rear differential, sit laterally offset from one another.
    I'm going to safely assume, thats not good.
  2. Oct 25, 2013 at 9:54 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You can rest easy knowing this is normal....;)
  3. Oct 26, 2013 at 5:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You're over thinking it.
    Unless your transmission has magically shifted from its mounting points, it was engineered not to be perfectly inline.
