off road 2wd.
Discussion in '4 Cylinder' started by ROGER JR., May 11, 2012.
  1. May 11, 2012 at 8:11 PM
    ROGER JR.
    ROGER JR. [OP] Member
    ROGER
    GASTONIA NC.
    08 TACOMA 4X2 REG CAB BASE
    MOSSY OAK CAMO BRAND SEAT AND STEERING WHEEL COVER/BONE COLLECTOR HUNTINGDECAL/WATER PROOF FLOOR MATS/TIE DOWNS/STOCK AM FM CD PLAYER/hood and window deflectors hopefully more aftermarket mods soon.
    anyone here go off roading in a 2wd base 4cyl reg cab 2.7i4 if so what upgrades are installed im kinda on a budget but like going trailing.
  2. May 11, 2012 at 8:17 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    Yep, tires first.
  3. May 12, 2012 at 6:46 AM
    DESTROYERRACER
    DESTROYERRACER Well-Known Member
    Sean
    Buffalo NY
    10 RC 4x4 5 speed
    2010 Reg Cab 4x4, de-flapped, OME 884s/90000s, Wheelers leaf packs/Bilsteins, Audi A8 headlights, 255/85-16 Cooper ST Maxx's, 8 inch Type R sub, JL door speakers, 1000 watt amp, carbon filter nixxed and K and N air filter because its not dusty here and I do ALL my own work
    tires and upgrade the shocks atleast since the 2wd suspension is tuned strictly for road use it wont hold up to the cycling of offroad use for very long
  4. May 12, 2012 at 12:02 PM
    Yjryder
    Yjryder Member
    A good deep treaded all terrain and lots of skinny pedal. I went down into a retention pond and came back up the hill flawlessly in my single cab Tacoma and by buddy's in his suburban had to stop and put it in 4wd. It was lots of fun.
  5. May 12, 2012 at 12:10 PM
    zachc113
    zachc113 Well-Known Member
    i have an 01 prerunner dbc and i use it off road all the time. been on a few slick trails and it handled them better than a 87 bronco that also was in 2wd. You also may want to get a small lift because the 4 cylinders dont have to much clearance stock.
  6. May 12, 2012 at 10:42 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    I off-road my prerunner (both before and after a small lift). Can't do anything crazy, but it's still fun.
    A rear locker would probably be a big help.
    Do you mean the 5 lugs don't have much clearance? There shouldn't be much height difference between the 4 and 6 cylinder trucks. However, the 5 lugs are a bit lower...
    Proper application of the skinny pedal is important, too. Foot to the floor isn't necessarily the answer to every problem...
  7. May 12, 2012 at 10:49 PM
    FBGW01
    FBGW01 Well-Known Member
    Kaleb
    East Mesa AZ
    check my build
    im 2wd with locker. 01 prerunner extended cab:D i can keep up with my buddies broncos;) sometimes haha with lots of speed! its funner when u haul ass up a hill not crawl!
  8. May 13, 2012 at 1:11 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    My friend has taken his 5lugger taco into the sand with me and he got stuck a couple of times. Then he learned you just a have to floor it :) .
    Good tires will help a ton, and new shocks like others have said.
  9. May 14, 2012 at 9:35 PM
    ROGER JR.
    ROGER
    GASTONIA NC.
    THATS AWESOME APPREIATE IT.
  10. May 14, 2012 at 11:07 PM
    drifter
    Sam
    Oregon
    good stuff
    take it easy and understand your limits...
  11. May 17, 2012 at 10:49 PM
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    haha ya i dont beat the living shit out of my truck. but i put alot pretty much all my money and time into it (im 16) and i love it! its not like its a stock tacoma 2wd. i got the suspension done up. Bed cage LT fox 2.0 in the rear and front soon to have fox CO resi's. does fine through high speed stuff. not much of a crawer guy anyway but i enjoy it still. just the highspeed is more fun in my opinion:D
  12. May 21, 2012 at 10:59 AM
    franken 831
    franken 831 Member
    frank
    ontario
    stock 2.7 litre
    new 16inch wheels and p235/70r16 goodyear wrangler silent armor
    Check out the post by "franken 831" ----on larger rims and tires. this change raises the ground clearance by one and one quarter inch to one and a half inch., about the same clearance of the 4by4.
    you can not raise ground clearance with lift kits, only larger dia. rims and tires can will do it. Ground clearance is a major factor in off roading. and go slow slow and stay out of the deep mud, where 4 by 4 jobs get stuck.
    c 321
  13. Jun 12, 2012 at 12:46 PM
    Sawyercomesclean
    Sawyercomesclean >:3
    Zell
    Tampa area
    2011 DCSB Prerunner SR5 TRD
    3" jacked up/ 33s/ Sockmonkey decals/ tailgate lock/ TRD FJ wheels/ tinting/ Black Hunter Bull Bar/ Devil Horns by Andres/
    Mine's a prerunner and I do really well on most off road trails with my 33 mud tires and 3 inch lift. If I avoid crazy shit, I'm usually good. My next truck will most likely be 4x4 though.
  14. Jun 19, 2012 at 8:54 PM
    HunterArdrey
    HunterArdrey Member
    Hunter
    Hickory NC
    05 5 lug taco
