Off road axle in a sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewRider, Apr 26, 2016.
  1. Apr 26, 2016 at 3:13 PM
    NewRider
    NewRider [OP] Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    I might have access to an off road axle soon and was wondering about putting it in my sport for the locker. I eventually want to get ARBs but for the next couple years this would seem like a great option. Has anyone done this? I've looked briefly but can't decide if the wiring for it is there or not?
    IronPeak likes this.
  2. Apr 26, 2016 at 3:18 PM
    idahbro
    idahbro Well-Known Member
    TRD OR AC
    Leer XL Cap, Thule Rack, Weathertech Mats, Sleeping Deck/Bed Storage, Pop and Lock Tailgate Lock
    Swapping the diffs would be way easier, no?
  3. Apr 26, 2016 at 3:22 PM
    Pigpen
    Dan
    Northwest Montana
    WWWAAAAAAAYYYYYYY easier. Go straight to ARBs - way easier and cheaper than putting elocker on a non elocker truck. Also, your Sport diff is stronger than the Offroad diff.
    IronPeak and travel_taco like this.
  4. Apr 26, 2016 at 3:23 PM
    idahbro
    TRD OR AC
    Why?
  5. Apr 26, 2016 at 3:25 PM
    Pigpen
    Dan
    Northwest Montana
    I forget the details. They both have an 8" diff, but it has something to do with accomodating the elocker...let me se if I can find it...
    First search to come up...
    This diff commonly and mistakenly called an 8.4" or 8.25" diff, possibly to imply its extra strength. The ring gear actually measures 8". The extra strength of this diff comes from the bearing cap/truss and large diameter pinion gear shaft.
  6. Apr 26, 2016 at 3:29 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    8.4" sport/sr5 vs 8.0" offroad
    TacoCynGsxr and IronPeak like this.
  7. Apr 26, 2016 at 3:36 PM
    NewRider
    Travis
    '87 4runner
    So has anyone ever looked into this? The cost for me (without checking on the wiring expense) would definitely be cheaper than the ARB
  8. Apr 26, 2016 at 3:38 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Are the gears even the same ratio?
    If they aren't just go ARB or wait and go ARB...
  9. Apr 26, 2016 at 4:48 PM
    idahbro
    TRD OR AC
    Gotcha. Good info :thumbsup:
  10. Apr 26, 2016 at 5:19 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    NewRider[OP] likes this.
  11. Apr 26, 2016 at 7:06 PM
    NewRider
    Travis
    '87 4runner
    Thank you! I don't know that I'll go through with this, I just wanted to know how feasible it was and how complicated
  12. Apr 26, 2016 at 8:23 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    If you had to regear the elocker to match your front end then it doesn't make sense to me to do it. Regearing is expensive and I'm about to do it the second time. Costly mistake lol. Just do it once and wait for what you really want.
  13. Apr 27, 2016 at 4:20 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    If you have access to the whole rear end it would be a no brainer as you can easily wire up the E-locker lots of info on the web about this. Keep the stock rear end and when you want to go to an ARB put it in the stronger Sport rear end. Otherwise, save your $$$ and do the arb in the sport rear end.
  14. Apr 27, 2016 at 4:30 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    go with the ARB. Putting the elocker 3rd in a non elocker axle requires modification... putting the full elocker axle in the non elocker truck requires all sorts of wiring.
    and like stated the physical ring gears at the same 8in diameter. BUT the non elocker is commonly referred to the 8.4 for what ever reason. The 8.4 is technically stronger as it has cradle caps over the main bearings and has 10 bolt ring gear to diff connection vs 8 of the elocker.
    Unless you got a clean elocker rear axle for free - 100 bucks, just go the arb.
