Off-road Diff with Locker Swapped into Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bajaracer, Mar 29, 2009.
  1. Mar 29, 2009 at 11:26 AM
    bajaracer
    bajaracer [OP] Well-Known Member
    Charly
    Chandler
    06 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES,285/70/17 BFG'S AT KO'S MOTO METALS 17X8 3" REVTEK, SOUND SYSTEM
    I was wondering if anyone has done this swap?? I just bought a 06 Tacoma Differential with a locker that i would like to install into my 05. The bad part is that they did not have the wiring and i have no ideas of what is needed. Can anyone help?
  2. Mar 29, 2009 at 11:29 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    interested in this idea. subscribed
  3. Mar 29, 2009 at 12:56 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    I looked into this a while back, the pre runner and sport share the same rear end, the sport has the LSD. The off road version is a different rear end.
    Supposedly the sport/prerunner rear will not accept the stock , off-road locker diff. Your best bet is to get an aftermarket locker. It will require a diff/tranny shop to align your ring gear and other workings inside the rear diff. And with aftermarket... do you want an air / maunual / or electric type? Air might be good, use can use the compressor to air up or whatever, but it will cost more. Figure at least $900 to get started and maybe a few more hundred in case there are problems. good luck
  4. Mar 29, 2009 at 1:01 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    did you buy the whole differential?? if you did then you need the switch, i believe the harness for the switch is in the cab already just not used in the trd sports, then youll need to see if theres a plug along the rear that connects to the locker, your probably missing a small harness in the rear
  5. Mar 29, 2009 at 1:10 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    In order to use the Off-Road third member (locker) you will have to swap your 8.4" housing (PreRunner/Sport/4x4 non-TRD) axle housing with a TRD-Locker housing.
    Like LBtaco and oakleyTRD mentioned, You best bet is to use an ARB locker. You will save money in the end and have a much better locker over stock.
  6. Mar 29, 2009 at 1:12 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    yeah we need clarification on what you bought exactly, did you buy the whole diff w/housing?? or just the 3rd member??
  7. Mar 29, 2009 at 2:06 PM
    bajaracer
    Charly
    Chandler
    I bought the entire differential unit,, removed from a dc preruner just exactly mine.
  8. Mar 29, 2009 at 2:11 PM
    SC4333
    Grant
    San Antonio, TX
    Then swap, wire, and your good to good. You can get a wiring diagram for the locker from the FSM and run a simple switch to the cab if the harness is not already installed, or other harnesses are needed and cost prohibitive.
  9. Mar 29, 2009 at 2:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    How helpful is a locker??
  10. Mar 29, 2009 at 2:21 PM
    bajaracer
    Charly
    Chandler
    What wiring do i need? Where woud i look to see if it already has it??
  11. Mar 29, 2009 at 3:02 PM
    SC4333
    Grant
    San Antonio, TX
    I'm sure someone will chime in with information on where the factory wiring harness is located. If the vehicle is prewired, logic would lead me to believe that it is going to be located near the rear end and should be easily located with some looking around. Take a look at the connection on your locking rear end that you picked up, and you will know what you are looking for.
    Here is the wiring digram for the 05+ factory TRD-Locker on a 2wd setup. I am not sure on how extensive the factory wiring is for non equipped trucks, hopefully we can get some comments from people with experience on this. If your truck did not come with a harness, you could probably pick up a Pill for the connection at the diff., which would allow you to wire the diff. so it will lock whenever w/o the safety features (for simplicity) but it would not be advised that you turn your lock your diff @ speeds over the factory set limits. (5MPH)
  12. Mar 29, 2009 at 3:07 PM
    jwscoot
    jwscoot Well-Known Member
    Mississauga, ON
    98 Tacoma v6 4x4
    Bilstein 5100 shocks all the way around, add a leaf in the rear
  13. Mar 29, 2009 at 3:21 PM
    MannyECG
    MannyECG MasterChief
    Tempe, AZ
    06 TRD Sport, 4x4, D-Cab, Long Bed
    K&N Air Intake, BFG A/Ts, N-Fab Nerf Steps, Tailgate Pop N Lock
    I've looked into this as well. I called my local dealership to get an idea on how much it would be to install a factory Off-Road E-Locker onto my Sport.
    The guy said total would be about $3000 including labor.
    Like mentioned, better off installing an ARB locker onto the rear!!!
  14. Mar 30, 2009 at 3:09 PM
    bajaracer
    Charly
    Chandler
    Nope, i got it off of a similar truck hit in the font.
