Off road fab shops in DFW
Discussion in 'Texas' started by KarlTheToyotaGuy, Nov 26, 2016.
  1. Apr 7, 2017 at 1:26 PM
    jameskhana
    jameskhana Maibatsu Monstrosity
    James
    Dallas, TX
    2007 DCSB Base 4x4 6spd
    Good to know, thanks. I just messaged them as well, and yep I've got the bumper already.
  2. Apr 11, 2017 at 1:19 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Yeah, and I think it needs some more stuff done to it. It's not fast enough, but it will surprise people. I need to do the locker-anytime mod so I can really smoke the tires.
  3. Jul 25, 2017 at 5:43 PM
    texasyeti
    texasyeti Member
    Another vote for Tandem Automotive. Pablo recently installed a Harrop e-locker in my truck and he did a great job. Gave it a little workout in Colorado last week and it did great.
  4. Jul 25, 2017 at 7:05 PM
    ThomasMore66
  5. Jul 25, 2017 at 7:08 PM
    Buckles
    Buckles Well-Known Member
    Texas
    2017 TRDOR
    Lone Wolf Off-road
  6. Jul 26, 2017 at 7:33 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    You're probably the reason mine had to come from Australia
  7. Jul 26, 2017 at 11:24 AM
    kennethalan
    kennethalan Well-Known Member
    Michigan
    Inferno TRD Off-Road 4x4
    King Total Chaos Dakar SCS Ray 10 315/75-16 STT Pro
    I have worked with both Tandem and LoneWolf multiple times.
    I give both "10/10 would recommend" reviews.
  8. Nov 25, 2017 at 10:48 AM
    Cruiser Brothers
    Cruiser Brothers Get There
    Ward
    Boise, Idaho
    Lots of old Toyotas
    MRBOND101 likes this.
  9. Apr 12, 2018 at 4:57 AM
    khill007
    khill007 Active Member
    2018 Tacoma Double Cab SR, V6, Auto, 4x4
    I’m a little frustrated with Baertrax. Every time I call the phone is busy and I sent an email yesterday and got no reply. I have talked to Pablo at Tandem and he is a very nice guy. I’ve got a slew of things I need done since adding 285 70 17 tires (adjust my Kings up, install JBA UCA’s, add rear block, CMC, and alignment). The only reason I didn’t call Tandem first was that I live close to downtown Dallas and the trip to Ft Worth and having to leave my truck is going to be a beat down. Wish there was someone else in Big D?!? I may just drive out to FW, leave at Tandem, and rent a car at Enterprise?!?
    su.b.rat likes this.
  10. Apr 12, 2018 at 5:43 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Im pretty sure if you set an appt with Tandem to start work first thing in the morning, they can have all that done by close of the day. Now with new shop they have more space to work.
  11. Apr 12, 2018 at 8:26 AM
    ThomasMore66
    I leave mine and uber home. I have a third vehicle. I have found that getting it all done in one day may not work because once they're in there, they may find something else. And not just to upcharge you. Pablo will tell you if something is worn and how worn.
  12. Apr 12, 2018 at 8:59 AM
    su.b.rat
    su.b.rat broken truck
    i just did exactly that two weeks ago. there is an Enterprise not far from Tandem and they will drive you back & forth if you need.
    so, this is also another vote for Tandem. it's true that Pablo is a perfectionist. that's the kind of guy worth knowing about and driving for.
  13. Apr 12, 2018 at 10:02 AM
    kennethalan
    Michigan
    I did the leave for the day and Uber home method at Tandem. They are great to work with.
  14. Apr 12, 2018 at 1:15 PM
    dsmdylan
    dsmdylan Well-Known Member
    Dallas, TX
    '17 DCSB OR Quicksand
    I live near downtown too. Smith Offroad is much closer and they're great. They've rebuilt my Icons, replaced axles, did a CMC, and some other stuff. Highly recommended. Baertrax rubbed me the wrong way when I talked to them about rebuilding my Icons. Won't be doing any business with them.
    khill007[QUOTED] likes this.
  15. Apr 12, 2018 at 1:50 PM
    #35
    Ram.95
    Ram.95 Well-Known Member
    2017 Black Tacoma TRD OR 4x4 Dallas Tx
    TRD PRO Bilstein Suspension HS Progressive AAL
    Baertrax installed my suspension. I did try emailing them for a quote and did not receive a response but got a hold of them on my second call in. Their quote was less than Dallas Offroad so I used them. Talked to the owner when I picked up my truck, seems like a nice guy.
    I probably would have gone with Tandem, based on what I read here, had it been closer to me. I just didn't feel like taking Uber to Ft. Worth and back.
  16. Apr 12, 2018 at 2:57 PM
    #36
    hoarder23
    Shay
    NJ
    Scratches
    Smith Offroad is a solid choice as well.
  17. Apr 13, 2018 at 9:47 AM
    #37
    khill007
    I actually got an appointment Monday at Tandem. I'll just rent a car at Enterprise and go about my business. The guys at Tandem are great and the estimate they gave me for all of the crap I need done was pretty sweet.
  18. Nov 18, 2018 at 6:20 PM
    #38
    tkwny
    tkwny Well-Known Member
    Randy
    Wylie, TX
    2016 Quicksand Tacoma TRD Off-Road
    Toytec 3" Lift w/AAL Demello Hybrid Sliders BFG KO2 285/70/17
    My vote would be for BaerTrax as well (http://www.baertrax.com). They've done quite a bit of work on my truck (lift, sliders, etc.) and I've found them to be top-notch professionals. They also don't mark up the parts!
  19. Nov 24, 2018 at 7:23 AM
    #39
    thehonger
    thehonger Well-Known Member
    Dallas, Texas
    2017 Toyota Tacoma TRD OR 4X4
    TRD Pro Grill Auxbeam LED Headlights
    Driven Service and Performance
    11292 Leo Ln
    Dallas, TX 75229
    ask for Andy
    Phone number (469) 475-3564
    He does great work, and I've known him for years.
  20. Feb 13, 2021 at 2:14 PM
    #40
    meats
    meats superwhite MT taco meats
    Justin
    Grapevine, TX & Cushing, OK
    '20 Super White DCSB 6spd MT 4x4
    Lots--
    Do you guys make full skids for 3rd gen tacos? Steel. With reroute
