Off Road Lift Plan critique
Discussion in '3rd Gen. Tacomas (2016-2023)' started by majpooper, Mar 23, 2024.
  1. Mar 23, 2024 at 2:53 PM
    majpooper
    majpooper [OP] Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Rookie wheeler here with a year doing Uwharrie (no Ds) in my 2022 Taco Off Road. I have sliders and went up to 265/75R16 E rated KO2s. I also have steel front and transmission skid plates. The last thing I did was have an exhaust re-route to tuck up the exhaust that was hanging down kind of low. The truck will not have a lot of added weight except for sliders and skid plates (possibly one or two more skid plates )I have done a ton of research but would like to bounce my plan off of some folks with a lot more trail experience. I basically have two objectives:
    1.) To be able to take on some of the more rated difficult trails like the Ds in Uaharrie or Hurricane Creek - trails like that but in no way be a hard core rock crawler.
    2.) Keep it affordable on a limited budget and maybe improve things over time
    My next steps are:
    1.) upgrade the suspension with Bilstein 5100 front and back plus an Icon AAL for a 2“ lift in front 1.5“ in the rear.
    2.) new tires when the current ones need replacing on DX4 Terrain 16x8 wheels with a +10 offset with 285/75R16 E rated 32.8“ KO2s - this should keep the back spacing to the UCA pretty close to where it is now and with the offset mitagate the rubbing somewhat.
    3.) bumpstops front and rear
    Questions:
    1.) would 33s require a CMC and maybe a viper cut or if I did get a CMC and a viper cut could I possibly go to 34s without needing UCAs and re-gearing?
    2.) watching the Tinker on YouTube makes the case with stiffer springs, a front sway bar delete to helps with more down travel - would like to know if this is common or a bad idea?
    3.) what would be a reasonable cost to have a shop do the the above installation?
    Wish List:
    1.) High Clearance Cat-back exhaust (R4T)
    2.) Armor - front transfer case, Rear Diff and gas tank
    3.) SPC UCA
    4.) 35s
    5.) re-gear to 4.88
    215Yota likes this.
