Off road light wiring
Discussion in 'Technical Chat' started by DaytonLax14, Jan 18, 2010.
  1. Jan 18, 2010 at 2:04 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    I posted this in the lighting section but I then noticed it was the wrong section for this question:p Anyways I bought an off road light kit that I'm going to put on my brush guard. But I was wondering, where do you run the wires that come off the back of the lights? Do you route them through the grill somewhere to get to the battery, or do you route them under the truck and then up to the batter? Just looking for some advice.
  2. Jan 18, 2010 at 2:25 PM
    G-Sak
    G-Sak Well-Known Member
    PNW
    2005 TRD Offroad SR5 DC 6 speed
    FX-R Projector Retrofit with Apollo Shrouds, Digital HID 55 watt ballasts, D2S Philips 85122+ bulbs in the Winter and Digital HID 55w 5k bulbs in the summer, Bakflip G2, Pop N Lock, Tint, Grillcraft with PIAAs behind it, ScanguageII and a few audio/video upgrades.
    Go with the option that hides them the best and keeps them out of the way of any debris you may come across while off road (branches and such). Going through the grill would be better than going under the front of the truck IMO.
  3. Jan 18, 2010 at 2:38 PM
    JAG
    JAG Well-Known Member
    I went through the bottom portion of the grill. And for each wire i just stuck to the lateral sides as much as possible. It looks good. With the brushguard you don't even see the wires going through the grill. I try to snap a pic. :-/
  4. Jan 18, 2010 at 4:09 PM
    DaytonLax14
    Corey
    Ohio
    A picture would be awesome. Thanks!
  5. Jan 19, 2010 at 9:45 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Use lots of zip ties so nothing moves or hangs... I installed the Hella 4000 wire harness/ relay to my '05 for 2 lights.
  6. Jan 19, 2010 at 10:01 AM
    kmrofka
    kmrofka Im so hungry i can ride a horse...
    Arizona
    03 V6 Prerunner SR5
    Stripped down to the frame
    i just went straight through the grill
  7. Jan 19, 2010 at 11:50 AM
    DaytonLax14
    Corey
    Ohio
    Alright I got that part figured out. Thanks guys!
    Now, the next question:
    I am mounting the switch on the blank spot to the left of the steering wheel next to the ECT button. How do I get the wires from the battery to the switch? Is it relatively simple? Should I mount the switch in a different spot?
  8. Jan 19, 2010 at 12:19 PM
    JAG
    Use some stiffer gauge wire and it will push right through the fire wall. Go through where the hood latch cable is. Its a black looking boot on the driver side and then it will come out near all the other cables... if only I had a camera with me right now! If you can't picture this in your mind I can try to describe it a lil better.
  9. Jan 19, 2010 at 12:28 PM
    DaytonLax14
    Corey
    Ohio
    is this black boot that you speak of circular shape? Like a little black donut?
  10. Jan 19, 2010 at 1:06 PM
    JAG
    Exactly! Go through the smaller circle that is in that same donut shaped circle. For some reason it is easier to push through and you won't hurt the hood cable.
  11. Jan 19, 2010 at 1:08 PM
    DaytonLax14
    Corey
    Ohio
    Okay great, thanks. When I push the wire though, where should I expect it to come out? Do I need to take apart any of my dash or anything to get to the wires?
  12. Jan 19, 2010 at 1:15 PM
    JAG
    No. take a flash light and look up underneath the steering wheel and it will be there. You don't have to take apart nothing. It easy if you lay on your back where your floormats are and thats I have found it. What kind of lights you get?
  13. Jan 19, 2010 at 1:16 PM
    JAG
    Oh crap!!! I just saw you had a earlier model truck... I'm a 06. Hopefully its the same principle area.
  14. Jan 19, 2010 at 3:41 PM
    DaytonLax14
    Corey
    Ohio
    Okay hopefully it won't be too different. I'm going to wire them up in the near future and will let you know. Thanks for your help!
  15. Jan 19, 2010 at 5:54 PM
    David K
    I put my switch in one of those blanks as well (2005 Tacoma)... The battery wire will push through the firewall next to all the other wires... just look and you will see. There is a screw up in there above the fuse area where you can ground the switch, too!
    Now, my 2010 uses up all those cherry switch blanks with VSC Off and Downhill assist and side curtain shut off... Where do I go now!
  16. Jan 20, 2010 at 11:29 AM
    DaytonLax14
    Corey
    Ohio
    what did you all do to hide the wires going from your lights and into the grill? I used that black circular tubing stuff, but now there's just a black tube going straight into the grill that shows.
    Also, with my light kit, the wiring that I got will not reach from the battery and to where I am mounting the switch. I have some speaker wire from a sub that I had in my old car. Could I use that and splice into the wiring for an extension? I mean, wire is wire, right?
  17. Jan 20, 2010 at 1:38 PM
    JAG
    I haven't got that detailed yet with hiding the wire. I was going to do it later. I just ran black wire down low and you can't see through the grill. I would use the type of wire that your lights came with whether it is 12 or 14 gauge it doesn't matter where you get it from though. imo
  18. Jan 20, 2010 at 1:57 PM
    DaytonLax14
    Corey
    Ohio
    Alright thanks. I'm gonna get up a picture later of the wires from the lights through the grill. I think we may have them the same way.
    Also, a buddy of mine just told me that speaker wire is designed to carry high frequencies for sound. So I'm gonna need to buy some wire. Where can I get some? I don't think it will cost much, right?
  19. Jan 20, 2010 at 2:25 PM
    JAG
    Um... good question... try any auto store and they usually sell a lil roll of it. If you want to get a lot you could try any electrical stores in your area. Not sure on prices, but wire is not usually cheap. It should be under 20 dollars for the amount you need. Maybe even less. You might need connectors too. But if you have an friend that is a electrician he can hook you up with some of his extra wire.
  20. Jan 20, 2010 at 2:26 PM
    JAG
    I'm gonna go take a pic of my truck grill now... I'll try to put it on here to show you.
