Off-road Lighting: Fog, Driving, and/or Long range spot?
Discussion in 'Lighting' started by ETAV8R, Feb 15, 2012.
  1. Feb 15, 2012 at 2:57 PM
    ETAV8R
    ETAV8R [OP] Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    I have some questions about off-road lighting. My original plan was to get some Hella Blackmagic lights and mount them behind the mesh grill. Now I'm thinking about getting a Smittybuilt lightbar and putting four lights on it. KC HiLites get pretty good reviews and come in 3 varieties, fog, driving, and long-range. What are the general recommendations for lighting? I'm thinking fogs on the outer tabs and long-range lights in the middle. This way I could throw them all on and have good coverage close and far. Would driving beams on the outer tabs pointed out to the sides be better than fogs?
    Thoughts?
  2. Feb 15, 2012 at 3:01 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    I'm happy with the KC130w driving lights 6 inch. simple to hook up with the supplied harness. You can always change the reflectors to long range if you want.
  3. Feb 15, 2012 at 3:23 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    You generally want flood on outers and driving in the middle. Long range only needed for race trucks.
  4. Feb 15, 2012 at 9:24 PM
    ETAV8R
    Just the basics
    Thanks for the replies.
    Since I go out in the middle of nowhere and during the daytime I tend to travel between 30-50 mph on the roads I figured the long range spots would be better than driving lights since I have those from the factory already.
  5. Feb 15, 2012 at 9:25 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  6. Feb 16, 2012 at 2:50 AM
    ETAV8R
    Just the basics
    I didnt plan on using "fogs" up that high just figured they would give better wide angle lighting for seeing the sides of the road. I only turn on my factory fogs when on long drives where the added lighting is of benefit or in inclement weather even though I know they aren't "true" fogs. I'll give some thought to using driving lights on the sides angled out a little bit and either another set of driving or the long range spots in the middle.
  7. Feb 16, 2012 at 6:50 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    i had hella black magic lights. i was not very ipressed with the output.
  8. Feb 16, 2012 at 7:35 PM
    ETAV8R
    Just the basics
    Even though I originally wanted blackmagics but read reviews of their poor performance so decided to go with something else.
