Off road lights placement configuration ??
Discussion in 'Lighting' started by betsydestroyer, Mar 7, 2013.
  1. Mar 7, 2013 at 3:50 PM
    betsydestroyer
    betsydestroyer [OP] You'll have to excuse me I'm not at my best
    Dan
    Sault, Ontario
    2012 access cab SR5
    Toyo MT, fox 2.o struts, dakars, Rear head-rest delete, pioneer avh 8400 ,fusion sub and polk components
    Hey guys
    I just ordered a bull bar, headach rack and 6 130w halogens 2driving and 4 long range For my taco. Other the the amperage issue I'm going to have to deal with ( I'm already running 2amps for my stereo). What config should I use I'm thinking maybe 2long range on bull bar and 2 long range in the middle of rack with the driving lights on either side. Is that going to work out ? What do you guys think?
  2. Mar 7, 2013 at 5:56 PM
    betsydestroyer
    Dan
    Sault, Ontario
    2012 access cab SR5
  3. Mar 7, 2013 at 9:25 PM
    09DBLCAB09
    09DBLCAB09 Well-Known Member
    1: convert to HID for lower power consumption
    2: spots up top, floods down low
    Aim the spots for distance and use the floods in front to cover the area in front of your truck
  4. Mar 7, 2013 at 9:27 PM
    Drew5387
    Drew5387 You can't fix stupid
    Drew
    Kansas
    03 PreRunner SR5 DC Black
    Raptor Style Grill, KC Highlight Spot Beams, 2.5% Window Tint, Kenwood Touchscreen Head Unit, Train Horn, Tinted Tail Lights, Retrofit Source Projectors with Halos, BHLM, LED Fog Lights, 40" LED Light Bar, 33" Cooper STT Tires, Herculined Rocker Panels, 175+ hp in stickers
    I would do exactly what the guy before me said
  5. Mar 7, 2013 at 9:39 PM
    acdronin
    acdronin Well-Known Member
    dayum, six 130's? I got four 130's and they're dammed bright, you ain't screwing around are ya?
  6. Mar 11, 2013 at 11:52 AM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    What kind of lights/bars did you get? For placement, spots up top and driving lights on your bull bar as mentioned. I have a Westin bull bar on my truck with 2 longrange 130w slimlites mounted there. It works but I would have more useable light if they were mounted up top. I'm thinking of getting a Headrack, like a back rack but a little more friendly for light mounting. Canadian based company too out of Thunder Bay.
  7. Mar 11, 2013 at 7:10 PM
    betsydestroyer
    Dan
    Sault, Ontario
    2012 access cab SR5
    Thanks for the help guys that's how il run em. I just put the back rack on and it looks good lights will go up tomorrow
    Ronn I got all kc daylighters 130w and am getting the Weston bar soon hopefully tomorrow it's in. How so you like yours?
  8. Mar 11, 2013 at 7:11 PM
    acdronin
    Post some pics dude, I wanna see em!
  9. Mar 11, 2013 at 7:16 PM
    betsydestroyer
    Dan
    Sault, Ontario
    2012 access cab SR5
    Will do once there up! I'm getting pumped I just got the backtrack on and now it's raining so il hopefully have em on tomorrow! How do you like yours?
  10. Mar 11, 2013 at 7:20 PM
    acdronin
    Well 520 watts coming out of the front grill ain't no joke I'll tell ya that, I like em, suppose I could HID those suckers but hell, I'll do that if I realize I have to, I can see miles down the road, I can't outrun them, if I light up an A-hole in front of me, I can see his thoughts. I don't think I need to change them, they do every thing I need.
    How are you running the wire and what gauge are you using? Three relays right?
  11. Mar 11, 2013 at 7:40 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    I'm happy with them, they have a good fit and finish and also have some pretty good light output and reach out pretty far. The only issues I have had is with rust. I bought them back in 08 and have been back 3 times for warranty. KC has been good everytime but it is a 1 month turnaround from arizona. Post some pictures when you get yours installed.
  12. Mar 11, 2013 at 7:59 PM
    betsydestroyer
    Dan
    Sault, Ontario
    2012 access cab SR5
    I can see his thoughts haha Ya the lights came with wiring harnesses with relays and fuses those should work right?
    You notice any issues with the lights drawing too much amps or power ?
  13. Mar 11, 2013 at 8:01 PM
    acdronin
    Do you have the tow package?
  14. Mar 11, 2013 at 8:03 PM
    betsydestroyer
    Dan
    Sault, Ontario
    2012 access cab SR5
    Nope so I don't have the bigger alt. Hopefully I don't run into crazy issues and can get away with just a battery upgrade unless I can get a diff alternator
  15. Mar 11, 2013 at 8:13 PM
    acdronin
    Hmm, you may be running it pretty close to the limit, from what I have been told, drawing close to the limit of an alternator a lot will shorten it's lifespan, how much IDK.
    Heck, guess you find out soon enough eh? :)
  16. Mar 11, 2013 at 8:20 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    A 130 watt light running say at 14 volts max will net you around 9 amps. So in your case 54 amps total. I have the SR5 with upgraded alt, and no tow package... check your options it should say on the window sticker if you still have it.
  17. Mar 11, 2013 at 8:23 PM
    betsydestroyer
    Dan
    Sault, Ontario
    2012 access cab SR5
    Yes sir I will find out:). And I also have sr5 maybe mine is upgraded il have to look
  18. Mar 14, 2013 at 5:37 PM
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Word to the wise- pay attention to the maxing out your alternator-
    I've gone through four alternators prematurely on my last two trucks and couldn't figure out why
    Until I remembered the two 12" subs I had and dual amps and the typical high school habit of thinking loud music all the time was super cool
    On the other hand
    How often are you REALLY gonna use the lights? And for how long at a time? Typical night runs will go a few hours sure but they're few and far between enough to just say abuse the alternator occasionally.
    I got my hands on five 55w HIDs for a steal so I won't have your problem ;)
  19. Mar 19, 2013 at 6:57 PM
    betsydestroyer
    Dan
    Sault, Ontario
    2012 access cab SR5
    Hey guys sorry for the long delay but I got the lights up and running on Sunday they look great and are super bright il post pics ASAP if anyone is still interested
  20. Mar 19, 2013 at 7:03 PM
    05taco2.7
    05taco2.7 Well-Known Member
    JIMSTER
    omaha nebraska
    Soon to come
