Off road mudflap opinions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Notacos4u, Oct 2, 2022.
  1. Oct 2, 2022 at 8:59 AM
    Notacos4u
    Notacos4u [OP] Active Member
    New England (Not Old England)
    2024 Trailhunter
    I searched the archives and I’m not getting any good results.
    I’m looking for opinions on good off-road mudflaps. I was in some fields yesterday and hit the oem flaps a few times when moving through some holes. Nothing damaged but could hear them impact the ground.
    Any better options that help the rock spray off the front and are maybe a bit more flexible for ground contact?
    thanks!
  2. Oct 2, 2022 at 9:12 AM
    SpeySquatch
    2016 TRD OR DCSB
    Get some cheap rubber ones off Amazon and drill your own holes that align to the factory holes. Works great
  3. Oct 2, 2022 at 9:58 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    My only caution about mud flaps is to make sure the mounting screws allow for break-away of the flap. I would often lose one or 2 when snowplowing as I backed into a snow bank (consider the effect on the flap when pinched between the snow bank and the tire - it gets pulled downward). I also suffered serious damage to a front quarter panel when backing over a stump - seems the flap got pinched between the front tire and the stump and the sheet metal buckled before the fasteners let go. Very costly body work needed.
    I don't have a recommendation regarding flexible or stiff like OEM. I would think that flexible sheds slush better when driving on slush-covered roads.
  4. Oct 2, 2022 at 10:26 AM
    ConantTaco
    ConantTaco Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    Not sure if anything is going to last if you're bottoming out in holes so deep to hit the ground with the stock ones.
  5. Oct 2, 2022 at 10:39 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Off road mud flap sounds like an oxymoron.
    Notacos4u[OP] likes this.
  6. Oct 2, 2022 at 11:01 AM
    CT Yankee
    CT
    & @Notacos4u
    @ConantTaco: If you're replying to my post it's obvious you didn't understand what I was describing. My experience had nothing to do with bottoming out - rather a situation when backing up where the flap gets pinched between the tire and and obstacle like a short stump or a snow bank.
  7. Oct 2, 2022 at 11:04 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Remove the mud flaps when wheeling.
    RIX TUX, Merling and gudujarlson like this.
  8. Oct 2, 2022 at 11:04 AM
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    i have rekgen
  9. Oct 2, 2022 at 12:00 PM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    I have the Rokblokz XL’s and have been pleased so far. Provide a lot more front tire clearance than the factory ones, are a lot more flexible, provide a lot more coverage, and won’t hold the snow/slush like the factory ones did. Not the best pic, but….
    Doghouse61 and Notacos4u[OP] like this.
  10. Oct 2, 2022 at 1:45 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    Mud Flap Suggestions | Tacoma World
    3-5 REAL CHOICES....oem, rokblokz, weather tech, rekgen or search on Amazon for copies
    Notacos4u[QUOTED][OP] likes this.
  11. Oct 2, 2022 at 1:49 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    I love my Rekgens. You can fold them nearly in half and they just spring back. They protect well too.
  12. Oct 2, 2022 at 7:17 PM
    ConantTaco
    Dave
    Stock ones are pretty short.
  13. Oct 2, 2022 at 7:21 PM
    ConantTaco
    Dave
    You said they hit the ground.
    Sounds like a
    Maybe you don't understand what your original post said.
    dee
  14. Oct 2, 2022 at 7:22 PM
    ConantTaco
    Dave
    "hear them hit the ground"
  15. Oct 2, 2022 at 7:43 PM
    Notacos4u
    2024 Trailhunter
    Are you ok? I can’t make any sense of your responses. Yes I heard the plastic hit the ground, it’s not that weird. Thankfully they didn’t break off or damage anything. Something more flexible would be better, maybe the rockblocks. Additionally I drive on many miles of varying conditions gravel roads every day, the oem flaps don’t stop rocks from spraying up on the sides/rockers. They sit reasonably low but aren’t very wide, I think width is the issue.
  16. Oct 2, 2022 at 8:01 PM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Rekgen XLs are exactly what you’re looking for. Slightly longer and about an inch wider. Can bend nearly in half but keep the rocks off the sides.
