Off-Road Solutions high angle cv boots
Discussion in '1st Gen. Tacomas (1995-2004)' started by GA1044, Sep 22, 2009.
  1. Sep 22, 2009 at 1:27 PM
    GA1044
    GA1044 [OP] Well-Known Member
    San Marcos, TX
    2002 trd 4x4
    Air Hog, Grey-Wire Mod, Fabtech Coilover 3.5 Lift, Deck Plate Mod, Rear Diff Breather Mod, Magnaflow Exhaust
    Got torn inner cv boots and was looking into replacing 'em asap and came across these boots a lil pricey but if they do the job they r worth it. However I just wanted to know if any1 has used these reddish cv boots and have they been all that or they u fluke? Thanks in advance
  2. Sep 22, 2009 at 1:28 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    UCAs should do the trick
  3. Sep 22, 2009 at 2:09 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    ....More like he needs a diff drop.
    GA1044 - do you have a lift kit? Did your CV boots rip due to axle shaft angles due to the lift?
    If yes.... Do some research on a 'diff drop' for the front. I don't have one myself but it's specifically designed to get your axle shaft angles back to stock angles.
    In fact, here's a link: If you decide to get the diff drop - then you won't need some fancy high angle CV boot.
    Did you call the dealership to get a quote on Toyota CV boots? or shop around for standard replacement CV boots. Compare prices.
  4. Sep 22, 2009 at 5:06 PM
    GA1044
    San Marcos, TX
    2002 trd 4x4
    Already got the diff drop just guessing since they just got torn I might as well replace em with some better ones
  5. Sep 22, 2009 at 5:30 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    never had any personal experience with them... but i have heard good things about them from others...
  6. Sep 22, 2009 at 5:59 PM
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    why does the diff drop not work as well on the 2nd gens?
  7. Sep 23, 2009 at 3:40 PM
    Janster
    Jandy
    Lancaster, PA
    Wow....How'd they tear? Got any pictures?
  8. Sep 23, 2009 at 3:45 PM
    GA1044
    San Marcos, TX
    2002 trd 4x4
    Don't know but will post before n after pics
  9. Sep 23, 2009 at 4:23 PM
    Fire931
    VA
    00 4Runner
    i've never compared them side by side but i have been told that the 2nd gen ones are bigger.. it would make since since the diff is larger than previous years they probably used a larger cv as well... as far as i know at the moment there is no other boot for the 2nd gen trucks...
  10. Sep 23, 2009 at 4:25 PM
    Fire931
    VA
    00 4Runner
    never seen the diff drop on a 1st gen but i know from experience on the 2nd gens they only drop the diff like 1/8th to 1/4 inch.. plus they arnt compatible with just about any skid plate either. i took mine off a long time ago and havnt noticed any difference in the boots rubbing or anything.
  11. Sep 23, 2009 at 4:27 PM
    Fire931
    VA
    00 4Runner
    i've torn two boots already on my drivers side cv.. got both the inside and outside boot on the same axle. now its my trail spare. both mine were due to branches on the trail not from rubbing though. i've been trying to work up a LCA skid that would incorporate some sort of guard for the outter boot to help deter this problem.. still in the design phase though.........
  12. Sep 23, 2009 at 5:55 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Wtf!!! Did I miss something? What did Janster say that you are refering to. What ever it was I doubt it qualifies you calling her a terd on crack. FYI Janster is a female.
    Is it necesarry to call dgerm an idiot? C'mon man name calling certainly isn't making any progress. Maybe you can correct him if you feel he is wrong but simply calling him an idiot accomplishes absolutly nothing.
  13. Sep 23, 2009 at 6:12 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    I only see one terd and idiot on this thread. The one with the least post count.
  14. Sep 23, 2009 at 6:14 PM
    Jason'sLawnCare
    I'm sorry for getting off topic. I'm not trying to pick a fight and I have no doubt in your answer/answers.
    You're 100% correct you are more than welcome to say whatever you would like, freedom of speech. I just don't understand the necesity of being so harsh. That's all.
  15. Sep 23, 2009 at 6:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you dont like it.....get the fuck out. simple.;)
  16. Sep 23, 2009 at 6:26 PM
    Jason'sLawnCare
    x2. We appreciate the info we just don't need the negativity.
  17. Sep 23, 2009 at 6:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that....and we dont need a douchenozzle asshat know it all either.
  18. Sep 23, 2009 at 6:28 PM
    Jason'sLawnCare
    haha. True true.
  19. Sep 23, 2009 at 6:29 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ah...see how that works.:cool:
  20. Sep 23, 2009 at 6:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    due for?? did i miss something?
