Off road springs vs sport springs
Discussion in 'Suspension' started by El Tano, Sep 4, 2023.
  1. Sep 4, 2023 at 4:02 PM
    El Tano
    El Tano [OP] i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Streets here in Los Angeles are very bad, specially after all the the rains and the crappy repairs that they did. Will Off road springs will be better than sport springs? (looking for a softer ride).
    Also I have a pair of used springs but I can't find part number or how to know which one is left or right.
  2. Sep 5, 2023 at 1:28 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I have yet to see spring rates published that suggest they differ across 3rd gen trims. The only information on coil spring rates I am aware of is in this stickied thread.
    https://www.tacomaworld.com/threads...2016-tacoma-presented-by-toytec-lifts.395798/
    "Spring rate on the factory coil did indeed come back at 717lbs/inch."
    However, there are many aftermarket coil springs available with 600, 650, and 700 lb/in rates. I have 600 lb/in coils myself.
    drizzoh and El Tano[OP] like this.
  3. Sep 5, 2023 at 3:26 PM
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    Thank you
  4. Sep 5, 2023 at 3:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Sep 5, 2023 at 3:36 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    The offroad shocks will help. The springs themselves I don't believe make a difference across all 3g trims excluding the Pro (which still has the same leaf springs, just 2.5" Fox shocks/coilovers instead of the Bilsteins found on the OR and Sport).
    El Tano[OP] likes this.
  6. Sep 5, 2023 at 4:56 PM
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    I'm running bilsteins 5100 with the sport springs. Since I have a new set of take offs with a 1.000 miles from an Off-road that I bought long time ago I was going to switch springs. But I can't find a part number on the springs to corroborate if they are indeed off road and which is left or right. I never ever go off road although it seems that way driving in LA and I already got pulled over for swerving trying to not to fall into the big pot holes.
