Off-Road SR5 2022
Discussion in '3rd Gen. Tacomas (2016-2023)' started by StriderSnG, Sep 7, 2022.
  1. Sep 7, 2022 at 3:48 PM
    StriderSnG
    StriderSnG [OP] Well-Known Member
    22' Tacoma SR5
    Anyone have any experience with the new SR5's on trails and in the snow? How are they with a good set of A/T tires?
  2. Sep 7, 2022 at 3:49 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Huh? There’s TRD Off-road and SR5, two different trims. SR5 handles just fine with a decent set of tires off-road.
    Starman2112 likes this.
  3. Sep 7, 2022 at 3:50 PM
    StriderSnG
    22' Tacoma SR5
    I guess the title is worded poorly. just mean taking the sr5 off road
    Lt. Dangle and outdoor frenzy like this.
  4. Sep 7, 2022 at 3:52 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I do know hardcore Offroad guys like the SR5 cause it's a clean slate for modding. They can build it how they want it.
    2016Tacoman and StriderSnG[OP] like this.
  5. Sep 7, 2022 at 3:58 PM
    Bishop84
    Bishop84 Well-Known Member
    SR5's are perfectly suited for offroading.
    All tacomas just need are a decent set of tires and an enthusiastic driver.
    Take it out, learn the limits and decide what you want to do.
    Share pics if you do get out, even if its a dirt road.
  6. Sep 7, 2022 at 4:00 PM
    StriderSnG
    22' Tacoma SR5
    Good way to look at it. I am definitely excited to get out there
    outdoor frenzy and Junkhead like this.
  7. Sep 7, 2022 at 4:33 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    With respect to off-road performance, All the trims with 4wd are basically the same with some differences that most people will never need. The all-season tires on the sr5 will likely be it’s limiting factor.
    EDIT: if was going to run fast in the desert, I would definitely want the v6.
    EDIT2: I’ve owned both an SR5 and a OR and I do get some use out of ATRAC and the rear locker on the OR.
    Junkhead likes this.
  8. Sep 7, 2022 at 4:35 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Yeah, you’ll be more than fine. You got 4WD?
  9. Sep 7, 2022 at 4:37 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    As long as it is in 4hi, the SR/SR5 would be solid in the snow! A/T tires with the 3 peak snow designation would make it even better!
  10. Sep 7, 2022 at 4:43 PM
    StriderSnG
    22' Tacoma SR5
    Yes, 4x4
  11. Sep 7, 2022 at 4:49 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Yeah, get some good tires, pull off that air dam, and you’re good to go.
  12. Sep 7, 2022 at 4:51 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You are good to go sir.
  13. Sep 7, 2022 at 4:53 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    If I could’ve got an SR5 with MT, i would’ve. I’ve replaced the whole suspension on my truck, 4WD system is identical.
  14. Sep 7, 2022 at 4:54 PM
    Georgia Native
    Georgia Native Well-Known Member
    4x4 DCLB 2017 SR5, 2019 4runner Offroad, 2021 SR Access Cab
    I have yet to be disappointed with my SR5. I can always add a locker if I ever feel I need one.
  15. Sep 7, 2022 at 4:54 PM
    StriderSnG
    22' Tacoma SR5
    Thanks guys, I'll update with photos later
  16. Sep 7, 2022 at 9:48 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Internal to Toyota there are only three grades: base, SR5, and limited. The rest of us are SR5 that spent a few extra minutes at the factory picking out heels and a dress followed by hours at port for hair and makeup. Varying degrees of success, talking about you Pro and Sport, sluts.
  17. Sep 7, 2022 at 10:56 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    2 or 4 wheel drive....look on the tailgate to see if it says 4x4
  18. Sep 8, 2022 at 3:33 AM
    TacoBuffet
    AL
    Correct but I didn’t want to get technical and confuse OP. Used to be a fancy SR5 badge next to the V6 on the tailgate of even TRD optioned prior gen trucks.
  19. Sep 8, 2022 at 4:11 AM
    outdoor frenzy
    outdoor frenzy Well-Known Member
    Aaron
    Roanoke, VA
    2021 TRDOR DCLB Super White
    Goodyear DuraTracs
    I cannot recommend these tires enough. They do mud, snow, rocks, dirt and water crossings with ease. The ride is very comfortable and they air down nicely. The side lugs grab and the tread lasts a long time. Your SR5 will take you where you want to go. Lockers will be helpful long before a light bar will be.
  20. Sep 8, 2022 at 12:59 PM
    StriderSnG
    22' Tacoma SR5
    do you use the rear locker on most trails or is it mostly only momentarily when things get really rough as far as terrain?
