Off-Road Suspension Question
Discussion in '2nd Gen. Builds (2005-2015)' started by byronh11, Jan 29, 2018.
  1. Feb 8, 2018 at 7:43 AM
    #41
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Except that OME coils were never designed to work with 5100 shocks..
  2. Feb 8, 2018 at 7:46 AM
    #42
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    maybe not, but that doesn't mean it wont work. Most people I have talked to wish they went with Bilstein instead of going OME. I would argue that more people run 5100s with OME coils than OME shocks with OME coils. But this is not the point of this thread.
    Ultimately, for the OP, spacers on top of lift coils (with the exception of the taco lean spacer) are not ideal and you should avoid doing it if possible.
  3. Feb 8, 2018 at 7:49 AM
    #43
    geekhouse23
    FTFY
    The high spring rate of an 886 coil was not designed to work with a 5100 coil.
  4. Feb 8, 2018 at 7:53 AM
    #44
    BamaTaco56
    Trey
    If you want to get technical, the issue isn't as much of the spring rate of the 886 as it is the valving of the 5100.
  5. Feb 8, 2018 at 8:02 AM
    #45
    geekhouse23
    Correct (?) I am saying the issue, if you want 886 coils is to NOT use the 5100's but to use the OME shocks..
