Off-Road Tips and Gear List
Discussion in 'Off-Roading & Trails' started by Agent475, Sep 26, 2008.
  1. Jun 1, 2015 at 9:18 AM
    #41
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Heres what i take with me:
    • A plethora of recovery straps (two tree savers, a 30ft, 2 20ft, and some ratchet straps)
    • Hi lift
    • snatch block
    • factory jack (one of the most useful tools on the truck)
    • a spare CV, 2 if I'm going somewhere that is very hard or will be gone a long time
    • my 2wd conversion kit, its an outer cv stub shaft so i can immobilize the front diff
    • spare drive shafts
    • set of tools, including crowbars to get the cv out
    • spare spider gears for the rear axle in case my locker explodes
    • spare belts
    • spare crawl box mainshaft and input shaft (impossible to find at auto parts shops and vital to get me home if one of those breaks)
    • Spare tcase front output shaft
    • my old lower ball joints as spares
    • spare tire
    • torch
    • I have a set of spare rear axle shafts, ill only carry those if going somewhere very far away/difficult
    • Usually someone in our group has a welder, someday im going to buy a ready welder
    • Spare u joint and yoke for the driveshafts
    • Spare hoses
    • A bunch of random spare bolts
    • A few qts of various fluids, i have scaled back a bit since i started wheeling with people who also wheel toyotas, we all tend to have a few qts of something
    • tarp, that item right there is SOOOO helpful!!
    • Oil collection tub
    • tub of grease
    • Spare drive shaft flange bolts
    All that fits in my tool box and in the compartments in my xtra cab. All the parts on that list will allow me to get my taco home unless my engine blows, trans completely fails (like breaks the case open or something like that), if an upper BJ or steering rack fails. I have had to use quite a few of those at one point or another. When packing try to look at the truck and decide "what do I NEED to get this truck home" and go from there. People tend to overpack useless items and underpack on the important stuff. Always pack a bunch of spare bolts. My buddy broke his upper control arm bolt last time we were wheeling and we found a bolt in my spare parts bag that worked, it was old bolts that i randomly tossed in there.
  2. Jun 8, 2015 at 10:52 PM
    #42
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Why do you say that? Not being a smart ass, am genuinely curious.
  3. Jun 9, 2015 at 10:46 AM
    #43
    slander
    Hickory, NC
    It can be used as a makeshift press, a clamp, a spreader, you can bend metal with it, its a sweet little tool. Last trip out my buddy broke his upper control arm bolt on his zj and his axle flipped forward. He also bent his control arm bracket in when that happened and was using my factory bottle jack to bend it back into place and to shift his axle over so he can bolt the upper control arm back up. Its one of those tools that you truly don't realize how useful it is until you actually need it.
    Zoot likes this.
  4. Jun 9, 2015 at 12:02 PM
    #44
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Thanks
  5. Jun 9, 2015 at 7:26 PM
    #45
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Where did you pick up your spare parts? That's an expensive list.
  6. Jun 9, 2015 at 8:15 PM
    #46
    AMC
    AMC Well-Known Member
    Fullerton
    4x4 TRD Sport
    None yet.
    No jumper cables?
    Tucker771 likes this.
  7. Jun 9, 2015 at 8:34 PM
    #47
    Tucker771
    Tucker771 Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    Subbed! Now I just have to heed the advice I have learned :thumbsup:
  8. Jun 10, 2015 at 6:52 AM
    #48
    slander
    Hickory, NC
    CVs i bought from various forums, same with the driveshafts. The rear shafts i got free from a wheeling buddy that upgraded to chromo shafts. The tcase outputs i got from cases that i tore down for crawlers, extra ball joints were old ones i pulled off that were still usable, Crawler couplers were old ones that i pulled out when i rebuilt my crawl box but still useable.
    It comes from not throwing anything out, and buying old parts from people cleaning out their garage on forums. You dont need new stuff for spares, just stuff to get you home!! I need to pick up a spare power steering pump, those are a bit harder to find.
  9. Jun 10, 2015 at 6:55 AM
    #49
    slander
    Hickory, NC
    I have a 5spd so ill bump start it if i have to or bank on someone in our group having some. I never had any now that i think about it. Around town ill call AAA. I should probibly pick some up one of these days.
  10. Jun 19, 2015 at 2:13 AM
    #50
    DrFunker
    DrFunker Well-Known Member
  11. Jul 26, 2015 at 7:35 AM
    #51
    SquirrelyPatriot
    SquirrelyPatriot Well-Known Member
    Looks interesting. Would like to see a video on how it works.
    DrFunker[QUOTED] likes this.
  12. Jul 26, 2015 at 7:53 AM
    #52
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    You put it on the high lift and it cradles a sliders tube to make jacking up from the slider more stable. Pretty self explanatory.
  13. Jul 26, 2015 at 7:57 AM
    #53
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Sub for later
  14. Jul 26, 2015 at 7:59 AM
    #54
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    This. Simple and effective.
    But here is a video:
    http://youtu.be/XxsBTyht9xI
  15. Aug 4, 2015 at 5:20 PM
    #55
    Ryan Collings
    Ryan Collings Well-Known Member
    Ann Arbor, MI
    '14 Taco TRD Sport DCLB
    ARB Bumper, OME 886 & Dakars, LR UCA, Engo 10k lb Winch, Relentless Alum Skids, KBVoodoo Bed Rail Caps, Right-Foot Weight Reduction Mod
    Ok I gotta know. I tried searching and didn't see anything. What is the pickle fork for in a winch kit?
  16. Aug 4, 2015 at 5:29 PM
    #56
    DrFunker
    Assuming you mean this:
  17. Aug 4, 2015 at 5:30 PM
    #57
    DrFunker
    or this?
  18. Aug 4, 2015 at 5:31 PM
    #58
    Ryan Collings
    Ann Arbor, MI
    Yes. I think. It's listed in the recommended items for a winch kit and I can't imagine what it would be used for while winching.
  19. Aug 4, 2015 at 5:31 PM
    #59
    DrFunker
    Wonder if it is misplaced.
  20. Aug 4, 2015 at 5:33 PM
    #60
    Ryan Collings
    Ann Arbor, MI
    I found it mentioned in Ford Explorer forums in the off road section and in a few jeep forums. None of them gave an indication as for why it's there either.
