Off road with a FWC camper?
Discussion in 'Off-Roading & Trails' started by diver110, Feb 21, 2011.
  1. Feb 21, 2011 at 1:09 PM
    diver110
    diver110 [OP] Member
    The very fact that this subforum exists somewhat answers the question, but let me ask it anyway. I was all set to buy a 3/4 ton when I discovered that was going to pose a parking problem at work (1/2 ton is the same size, so same issue). So now I am kicking around the idea of a Tacoma. Some of the time I would likely carry the Four Wheel Camper campers.
    Good off road vehicle? I would be doing moderate off roading, more than forest roads, but no rock climbing.
    How about off road with the camper on board?
    Any idea what kind of mpg I can expect with the camper?
    Many thanks.
  2. Feb 21, 2011 at 1:12 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Pic or link to camper?
  3. Feb 21, 2011 at 1:14 PM
    diver110
  4. Feb 21, 2011 at 2:11 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Nice.
    I'm impressed they kept the weight so low.
    You might end up adding an "add a leaf" to your rear leaf pack to help with the load.
  5. Feb 21, 2011 at 2:13 PM
    S.B.
    Sean
    Like Bjmoose said, get an AAL to help suport the weight of the TSB leaf pack (covered under warranty).
  6. Feb 21, 2011 at 2:27 PM
    diver110
    Thanks, I'll keep that in mind. So you think it is an okay off road rig?
    Any mpg guesses?
  7. Feb 21, 2011 at 2:29 PM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    Expensive...
  8. Feb 21, 2011 at 2:34 PM
    S.B.
    Sean
    I can tell you that the tacoma will be much better offroad than the full size you were looking at, because of the size and weight.
    I can't guess at the mpgs. When I flat towed a Jeep Wrangler from SD to Flagstaff, AZ I averaged between 10-12. And I have 33" tires. I get 20mpg on the freeway and that is with about 600lbs in the back with my Bestop on.
  9. Feb 21, 2011 at 2:36 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
  10. Feb 21, 2011 at 4:06 PM
    diver110
    Thanks for the feedback. I am somewhat heartened that SB gets 20 mpg with 600 lbs in the bed. I would probably be doubling that and would be pushing more air, though not hugely more as the FWC is a pop-top camper. Hopefully I can do better than the guy on another thread who was towing 6000 lbs and got 8 mpg!
  11. Feb 21, 2011 at 4:12 PM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    youll be fine just throw in an add a leaf and take it easy on off camber stuff.
