Off-road with a topper
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaLife406, Jan 29, 2016.
  1. Apr 17, 2019 at 8:44 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you're into some serious frame flexing where you have 1 or even 2 wheels in the air it is possible for the cap to hit the cab. Of course by the time you do that the bed will also be hitting the cab too. It's gotta be some extreme off road driving to do any damage.
  2. Apr 18, 2019 at 7:03 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    With any kind of off roading you risk damage no matter what you have on your truck. I'm one of the taller vehicles when I go off roading and besides the height issue having a topper in back has never been a problem. I off road with the tent on and only had to clear a few widow makers to make it down the trails in NH. Obviously I don't hit super high angles since my center of gravity is much higher than a normal truck but my topper has never given me any issues.
    Jseda845, bax, Scott B and 3 others like this.
  3. Apr 18, 2019 at 7:07 AM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    You got a heavy rig there!
  4. Apr 18, 2019 at 7:09 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Weight maybe?
  5. Apr 18, 2019 at 7:21 AM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    What color alucab topper is best for offroad? I want to paint match my truck but I also need to stand out in the mall lot.
  6. Apr 18, 2019 at 7:22 AM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Tiger stripes.
    NYCTaco52 and AxisCab like this.
  7. Apr 18, 2019 at 7:27 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    With my limited experience offroading with a camper shell on my old Sierra -- it had a tendency to slowly slide backwards over bumps, with 4 traditional camper shell style style c-clamps. (It's do it on washboard too) I didn't have the sticky stuff between the bedrail and the shell, that may have made a difference. Also makes rear visibility worse, of course. And one off-camber situation over some tree roots nearly had it smack into said tree. Other than that, fine.
    Nice to be able to park, crawl into the back and go to sleep though
  8. Apr 18, 2019 at 7:37 AM
    Bruce988jl
    Southern NH
    I have additional camps on mine to alleviate this, for longer washboard trips I do have to loosen them and adjust it back into place but not as bad as when I only had 4 clamps.
  9. Apr 18, 2019 at 9:08 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Those windows are stupid expensive to replace. If I was going to go with a topper I’d go commercial style with aluminum doors / Alucab. For me a bed rack is cheaper, nothing to break.
  10. Apr 18, 2019 at 9:12 AM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Someone say tiger stripes?????
    rlx02, GillyLink, AKGSD and 1 other person like this.
  11. Apr 18, 2019 at 9:19 AM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Lol must be from Seattle, I lived by that guy in Fremont for years.
    rlx02 and GillyLink like this.
  12. Apr 21, 2019 at 10:31 AM
    onefastdaddy
    onefastdaddy New Member
    Dave
    2016 Tacoma TRD
    Rcho 5k Comp TAs on stock rims
    IMG_3105.jpg How about slippage?
    My shell slips every time I go up something steep...Not even that extreme I'm not in 4 low but I paraglide and the launch sites are often top of some hill [ Reno / Carson City area ]. I have 2 clamps that came with it when installed. I was surprised the first time it happened. I have small chips at the rear corners now from it shifting and the corners hitting on the truck corners.
    Installed professionally and they used a flat weatherstripping material
    I found this thread searching for what others do to secure theirs
    I am considering something with adhesive...surely you are not just using the 2 clamps like I am .. do tell
    Here's some photos.
  13. Apr 21, 2019 at 1:38 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I have six seriously beefy clamps on mine, 3 on each side. Could probably use just four since they are so beefy, but six is very confidence building.
  14. Apr 21, 2019 at 2:07 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    What rack did you put on your shell? Looks nice! I made my own to match my Prinsu.
    OP- we had some bed side shifting off-roading after going on a steep sidehill with my loaded ARE MX shell, which put the tailgate off square until I pushed it back, so do get some stiffeners as mentioned above. But I don’t think you can do much for it if you drive sideways like @rngr does with his! :)
  15. Apr 22, 2019 at 7:20 AM
    #35
    Bruce988jl
    Southern NH
    I have a front runner rack with a prinsu bed rack. I plan on swapping out for a front runner rack though, I find that the prinsu side panels give too much flex and is causing my gas tanks to flop around more than they should. I could reinforce the rack with more extruded aluminum but it would be nice to have a matching front runner rack as well.
  16. Apr 22, 2019 at 8:52 AM
    #36
    Teegs
    Teegs Well-Known Member
    I do some wheeling with mine, and intend to do more. Now that I have a huge awning attached to my cap, I intend to get bed stiffeners just to be safe.
    That said, I have had severe water and dust infiltration issues with my Leer 180. Its been a disappointing road and if I could do it over, I might have saved for an Alucab, or just gone a bed rack with an RTT.
  17. Apr 22, 2019 at 8:59 AM
    #37
    CMillTacoma
    CMillTacoma Well-Known Member
    Craig
    Colorado
    2025 TRD OR Hybrid
    Yes VERY expensive, I had the frameless glass on the backtailgate peice and it was $1100 to replace, the topper was only $2100 new. The frameless looks better but if I go with another topper it will be framed glass all the way around.
    TACOVRD[QUOTED] likes this.
  18. Apr 22, 2019 at 1:23 PM
    #38
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    I previously had a Leer topper which had the frameless rear window. It looked great, kept all my stuff under lock and key back there and kept everything dry but I always worried when I was out in the bush that I’d jab a branch through some glass if I was in somewhere tight.
    Don’t have to worry about that with the bed rack but for everything there are pros/cons.
  19. Apr 26, 2019 at 10:49 PM
    #39
    TacoWADude
    TacoWADude New Member
    Ben
    2018 Tacoma TRD Off-Road
    Teetering on pulling the trigger on my first topper with Alu Cab from OK4wd.
    1. How was the install?
    2. How did you seal your canopy?
    3. Is the brake light wiring messy? How did you deal with that?
    4. Leaks! I live in Seattle and as most people know, we get a lot of rain. Any issues with water seepage?
  20. Apr 26, 2019 at 10:52 PM
    #40
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Call mule expedition in Issaquah. They are alucab vendors and can do the install right there. @Jon@Mule will hook you up!
