Off-roading for Beginners
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ukee Jules, Aug 31, 2017.
  1. Sep 1, 2017 at 7:41 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Agreed. People on motorcycles do this all the time. No different in the truck
  2. Sep 1, 2017 at 8:01 AM
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    1. Always be prepared to spend at least one night if not two in your truck. water food clothing basic survival gear.
    2. Then be ready to walk out if it is a MUST but don't put yourself in any more danger by doing this.
    3. like stated above if unsure of terrain walk the line and make sure you have a place to turn around.
    4. keep your ego in check. If your unsure turn around. Don't compare yourself to others and make sure you are comfortable. You can push the limits and get uncomfortable once you don't feel like a rookie have the proper gear and are with other good people and good vehicles.
    5. know where your going and inform somebody even if your in a group. always have somebody to call search and rescue if you don't return pick a time
    Ukee Jules[OP] likes this.
  3. Sep 1, 2017 at 8:12 AM
    Cable
    Cable Well-Known Member
    California
    2017 TRD Off Road 4x4 Quicksand
    When traveling in a convoy, KEEP YOUR DISTANCE. When getting over certain obstacles or climbing hills, it's important to give your friends some space, both to maneuver if they need to back up and take a different line, or in case they roll back. There's no reason why you need to be 2 feet away from the next rig's rear bumper.
    In dusty areas, turn on your lights, especially if the area is heavily occupied. Helps with visibility and prevents unnecessary accidents. and of course, WATCH YOUR SPEED.
    When stuck in sand, do not step on the accelerator. You'll bury yourself deeper. What you might want to try instead is rocking the truck forwards and backwards, and using that momentum to wiggle you out. Takes some quick shift work, but even a little bit helps a lot better than spinning your tires and burying it to the frame.
    When stuck in mud, you can try gunning it to see if your wheels will grab. The high rotational speed will fling the mud from the tread/sipes and provide traction (sometimes)
    When spotting, or using a spotter, use "driver" or "passenger" to indicate direction of turn/travel. Rights and Lefts are confusing. Your left, or my left?!
    Make sure you know where your recovery points are. Sometimes you might be buried in mud and won't be able to locate it at a glance. It's useful to know where you can hook a strap or a winch line without having to dig around for it. It may be beneficial to attach shackles or hitch mounts beforehand as well.
    Understand that your differential is the lowest point on the truck. When traveling through rocky terrain, pick a line that does not have very many high points in the center.
  4. Sep 1, 2017 at 8:15 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    IT'S GONNA GET SCRATCHED/PIN-STRIPED by (weeds, bushes, sticks, rocks, mud...etc)
    so harden up well before you take it offroad. it's a truck not a Rolls Royce
    AND
    all those people you see in videos mashing through mud holes and rivers...above axle height...you can do that too, but at the end of it all you have to commit to popping all 4 wheels off and cleaning up all the crap, or else it will erode bearings, brakes, and whatever else if you just ignore the fact you've been dipping wheels and axles in wet mud w/o that added cleaning and maintenance.
  5. Sep 1, 2017 at 8:22 AM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    Great thread OP.
    A lot of common sense stuff that we hopefully know, but airing down is something I haven't done yet. What PSI? I'm assuming this thread is aimed at those of us driving a stock Taco so how low do we go with the stock tires and not risk damaging them?
    As for airing back up, I do have a compressor but it's more for work around the house. I assume I could toss that in the back and run it of the inverter unless it pulls more than 400 watts.
    tcjacado likes this.
  6. Sep 1, 2017 at 8:24 AM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    I always think about this when I go off road.
  7. Sep 1, 2017 at 8:42 AM
    BananaPeelOut
    BananaPeelOut Well-Known Member
    Ben
    NH
    2005 silver access cab TRD Off-Road
    Kenwood Headunit, CB radio setup, wind deflectors.
    You should be in 4lo pretty much the entire time you're on the trail.
  8. Sep 1, 2017 at 8:46 AM
    Cable
    California
    I'd argue it depends on what type of trail and/or obstacle.
    Example, I'll sometimes be in 2WD when just going through some dirt, or a fire road. No reason to go 4WD if there isn't a need for it. Same for 4L, I only engage low-range if I need the extra torque and response, just like I'll only lock the diff if my wheels are spinning.
    PNWTacoma, tcjacado and trdsupreme like this.
  9. Sep 1, 2017 at 8:52 AM
    Trucko
    2005 Tacoma
    yea but i think what should be said is be in either 4 hi low locked whatever before the obstacle not in the middle of it. I would much rather be in 4lo and not need it that halfway up a hill need to stop put in N and shift. can make an ok climb into a nerve racking one.
    OZ TRD likes this.
  10. Sep 1, 2017 at 8:53 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    Around here, that will just end up with you being stuck ASAP. In the sand/mud of FL, you gotta keep moving.
  11. Sep 1, 2017 at 9:04 AM
    BananaPeelOut
    Ben
    NH
    2nd tip...off-roading changes depending on where you are, not all tools/techniques are universal.
  12. Sep 1, 2017 at 9:08 AM
    TheReal_amocaT
    TheReal_amocaT Well-Known Member
    Annnnd.... Most important!
    -------Make sure to bring plenty of good craft beer and some TP-------
  13. Sep 1, 2017 at 12:36 PM
    SSCHUU
    SSCHUU Well-Known Member
    Eric
    Southern California
    2017 Tacoma 4x4
    Best tip of them all, lol!
  14. Sep 1, 2017 at 1:16 PM
    Khrolar
    Khrolar Well-Known Member
    Vancouver Island
    4 door 2017 trd off-road,
    None... :(
    A tow strap was the first think I bought for my truck. During the weekend after I got my truck I was heading to a local snowshoeing trail, its all gravel roads and steep grades to get there. I got stuck in snow, but i worked myself out of it after about an hour. On the way down and out I pulled 2 other cars and a jeep Cherokees out of the ditch.
    It really should be one of everyones first purchases, you can get stuck in any situation. It can be hard to get out of if you don't have a strap to get towed with...
  15. Sep 1, 2017 at 1:48 PM
    #35
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    :eek:The tree? What was he Popeye?:rofl:
  16. Sep 1, 2017 at 1:49 PM
    #36
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    After that l bet he wishes he was, lol
  17. Sep 1, 2017 at 1:51 PM
    #37
    Captqc
    Tigard, OR
    I can't begin to imagine how bad that life lesson hurt!!!!!
    shakerhood[QUOTED] likes this.
  18. Sep 1, 2017 at 1:56 PM
    #38
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Awesome thread so far. Thanks to everyone for the contributions.
    This is something I would like to learn more about.
    Maybe a "Sticky"??
    G.
  19. Sep 1, 2017 at 2:04 PM
    #39
    shakerhood
    Southern Ohio
    Im gonna have to try to search for that video to see if I can find it, his arm breaks so easily.
    TeecoTaco likes this.
  20. Sep 1, 2017 at 3:00 PM
    #40
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Must be this guy, and its a 4runner (close enough)
    https://www.youtube.com/watch?v=Am_qEIvCoGw
    TWTaco and nartmot like this.
