Recommended PSI for Off-Roading?
Discussion in 'Wheels & Tires' started by sbrates, May 20, 2021.
  1. May 20, 2021 at 9:54 AM
    sbrates
    sbrates [OP] New Member
    Good morning all!
    I need some guidance..
    I recently put the Toyo Open Country AT3s on my 2016 TRD and I was wondering what the recommended PSI for going up FSRs (Forest Service Roads) and gravelly/ off-roading type roads.
  2. May 20, 2021 at 9:59 AM
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
    The load rating of your tires will help you determine how low you can go. You can go down lower with a E-load vs Passenger/SL. For something like FSR id personally probably only go down to like 20 psi.
  3. May 20, 2021 at 10:01 AM
    Tacoma1192
    Tacoma1192 GD MOTORSPORTS
    Kyle
    Boise, ID
    2015 DCSB Sport
    39's, LT, 4 Link, Spidertrax 9"
    I run 3.5 to 5 psi. everywhere.
    Just experiment with different pressures until you find what you like.
    theesotericone likes this.
  4. May 20, 2021 at 10:05 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    I aint airing down for a gravel road. :notsure:
  5. May 20, 2021 at 10:07 AM
    714reyesj
    Danny
    Orange County, CA
    Dont need it for traction but for more of a comfort ride. Especially when you have a wife that gets motion sickness easily.
  6. May 20, 2021 at 10:20 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I air down to 15 to 18 when I hit frs
  7. May 20, 2021 at 10:39 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Ideally you want to run as close to listed recommended psi as possible. Going lower than needed allows sidewall flex. The faster you are traveling, the faster the flex occurs. This builds heat. Heat isn’t good for tires in the long run.
    Personally, If I were to air down. (On FSR) I’d try to stay close the the mid-low 20’s and take it slow.
  8. May 20, 2021 at 10:42 AM
    NWTacoTime
    NWTacoTime Well-Known Member
    Nate
    WA - Seattle/Kent
    Cement SB 2019 TRD offroad -
    Car Seats
    if its just basic FSR i'm usually just runnning around 20 psi
    TnShooter likes this.
  9. May 25, 2021 at 5:23 PM
    Sierra Trail Pro
    Sierra Trail Pro The more I play with it, the Bigger it gets!
    Kelly
    Cameron Park, CA
    2020 TRD Pro, Magnetic Grey Metallic
    Upgraded REM Polished 5.29 Revolution Gears Dobinsons 2.5 MRA/MMR adjustable remote reservoir front coilovers w/732lb springs, 35x12.5 BFG KM3 MTA tires on Moto Metal 16" wheels, incl. full size spare Bushmaster bolt on wheel well flares CaliLED full cab length DOM Steel Rock Sliders w/kickouts, Total Chaos welded spindle gussets, & LCA Cam Tab Gussets, Welded "Runnin 4 Tacos" Cab Mount Relocation Bracket, C4 Fabrication front steel hybrid bumper incl. heavy duty steel bumper support add-on's, C4 Fab Rear overland high rise steel bumper w/steel rear qtr panel wrap armor and side tube upgrades, 12k Smittybilt XRC Pro Comp Winch w/Factor 55 Flatlink Expert shackle mount assembly, Dobinsons heavy duty rear leaf spring pack, Timbren Off Road Racing bump stops (F&R), Fox 2.5 TRD Pro OEM rear monotube shocks, OEM Factory TRD Pro front aluminum skid RCI Steel skid plates (tucked in to factory engine skid)@ transmission, transfer case, lower A arms, and rear diff; CBI steel gas tank skid, ARB Twin Compressor in an M.O.R.E. engine bay mount, ARB Front Air Locker w/ Stainless Steel Air Lines Diode Dynamics 30" LED light bar @front bumper, RIGID front fog lights tied into factory wiring harness, Odyssey Group 31 AGM battery in a CBI Steel battery tray, Decked Slide-Out lockable Bed Drawer System, Yaesu FTM-400XDR HAM Radio (c/s:K6TOY), FreeSpirit Recreation "Evolution" Aluminum Hard Shell RTT w/Accessory Rails X2, FreeSpirit Recreation 270 Degree Swing-Out Self Supporting Awning w/Tent Mount Brackets, Cab Rack Mounted shower/changing tent, CBI corner to corner Steel Full Bed Rack, Prinsu Cab Rack w/extra rails, UpTop Overland upTAKE Snorkel (Functional & self draining), iPOD Bantam X touch screen switch panel control module, Dometic CFX3 95DZ Dual Zone Electric Refrigerator/Freezer w/dedicated electrical circuit & outlet, Dometic Refrigerator Slider Bed Mount, (4) 4 Gal Roto Pax Gas Cans w/locking Bed Rack Mount, MaxTrax Extreme Recovery Boards w/locking bed rack mount, Valley Runner custom ECU tune, TRD Advanced Cold Air Intake, Escort Radar Detector, hard wired w/RVM mount ALL K&N cleanable filter media installed, Only use Mobile One Full Synthetic Oil, changed every 5K miles, All Major Mods Professionally Installed
    I run 15-17 psi off road with my BFG KM3's... They grip the slick rock faces better when aired down properly
  10. May 25, 2021 at 5:25 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Exactly. 20 PSI is my street pressure. lol
