Off-Roading with your Daily Driver?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phdog, Sep 6, 2018.
  1. Sep 7, 2018 at 12:35 PM
    #101
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  2. Sep 7, 2018 at 12:38 PM
    #102
    Rvd9431
    Rvd9431 Member
    18 tacoma trd off road inferno
    Ac drain mod
    I will be taking my 100% stock OR through a muddy trail or 2 for sure. I know the stock tires arent up for any more of a serious task, and thats fine with me. This thing will never see a suspension lift either, its high enough as it is for my wife.
  3. Sep 7, 2018 at 12:41 PM
    #103
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    You will miss out. A simple tire upgrade to a decent A/T will open up capability to your truck that you never knew it had.
    ColoradoTJ likes this.
  4. Sep 7, 2018 at 12:45 PM
    #104
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    After some research, sounds like the Cooper AT3 4S could be a good option. Any opinions on that?
    As for size, I was thinking 265/75/16 as that's the largest that fit stock. Not sure I want to go much bigger anyway as I'd rather not affect torque too much or MPG.
    Thegenerik1 likes this.
  5. Sep 7, 2018 at 12:48 PM
    #105
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Eh, I agree that I'm incorrect, but not because of that article. It's kinda sloppy and I think him ignoring that the sidewall becomes part of the contact patch sorta helps his conclusion. This is a good read:
    http://road-transport-technology.or...E TYPES AND ROAD CONTACT PRESSURES - Yap .pdf
    Also, as with all things in life, we should have checked Wiki:
    https://en.wikipedia.org/wiki/Contact_patch
    It appears tire construction has a larger impact on the contact area than I assumed.
    Thanks to @JoeCOVA for teaching me something today.
    Hawco636, Mike O, Spare Parts and 5 others like this.
  6. Sep 7, 2018 at 12:49 PM
    #106
    OrangeJulius
    OrangeJulius Well-Known Member
    2017 Orange TRD off-road WIP
    Off-Road. The mall parking lot is Off-Road. lol.
    If you do a 2" lift with the 5100's and an add a leaf in the back, you'll be golden. That's what I did. The truck rides better now than it did on the stock suspension.
    All said and done, under $800.
    http://www.headstrongoffroad.com/store/p401/Coil/Bilstein_5100_Kit_(HS16BK-1).html
    887
    Add strut assembly
    No UCA
    Deaver Single AAL
    $733
    You'll need 2.5 degree axle shim kit
    http://www.headstrongoffroad.com/store/p120/Axle_Shim_KIT.html
    $32
    and maybe
    http://www.headstrongoffroad.com/store/p126/Old_Man_Emu_Carrier_Bearing_Drop_Kit_-_FK29.html
    $19.99
    eddyizm likes this.
  7. Sep 7, 2018 at 12:56 PM
    #107
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Likewise brochocho, got me digging pretty deep on information and learned a bunch from this convo. :cheers:
    Spare Parts likes this.
  8. Sep 7, 2018 at 1:01 PM
    #108
    ZYBORG
    TX / S. FL
    3G TRD OR
    It ilustrated the point we are making perfectly fine. There are a lot of variables that affect contact patch but generally speaking a wider tire has the greater contact patch (with all other factors being the same).
    Tis be the reason drag cars utilize wide / big tires in the rear for maximum traction contact patch and narrow / small tires up front for less drag / rolling resistance.
    zlajoie likes this.
  9. Sep 7, 2018 at 1:03 PM
    #109
    ZYBORG
    TX / S. FL
    3G TRD OR
    Well shit, don’t nobody give a “cheers” or “thanks”!
    :anonymous:
    JoeCOVA[QUOTED] likes this.
  10. Sep 7, 2018 at 1:03 PM
    #110
    JoeCOVA
    Joe
    Colorado Springs
    haha you too man, that was a great article you posted :cheers:
    I bookmarked these links cuz it will come up again.
  11. Sep 7, 2018 at 1:09 PM
    #111
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Sell it and buy a truck you can offroad + car.
  12. Sep 7, 2018 at 1:11 PM
    #112
    jowybyo
    Joe
    Baltimore, MD
    I risk starting another debate, but the friction between the tire and the ground is only depended on weight on the tire and the coefficient of friction(mhu). Friction = Fn x mhu . And mhu is independent of contact area, how does having a wider tire give you more grip when you are drag racing?
  13. Sep 7, 2018 at 1:13 PM
    #113
    ZYBORG
    TX / S. FL
    3G TRD OR
    Haha... thanks for the emoji beer.... I could use one right about now!
    :cheers:
  14. Sep 7, 2018 at 1:16 PM
    #114
    JoeCOVA
    Joe
    Colorado Springs
    Without getting scientific I know from racing that a wider tire has more grip than a skinnier tire. A formula 1 car with wide tires will have better acceleration and cornering than the same car on skinnier tires.
    I don’t know the formulas so I guess I have to dive into the interwebs.
    After lunch though, I’m burned out haha.
  15. Sep 7, 2018 at 1:16 PM
    #115
    ZYBORG
    TX / S. FL
    3G TRD OR
    Having a wider tire will not always give you the most grip when drag racing. Grip will be mostly dependant on friction which will be ultimately decided by compound.
  16. Sep 7, 2018 at 1:17 PM
    #116
    Wesintex
    Wesintex Well-Known Member
    2017 Blazing Blue Tacoma TRD OR
    255/85R16 Toyo Open Country MT, Customish bed rack, CB radio
    @phdog For what it is, I went with 255/85R16 on a stock OR. Thus far no rubbing and have been on trails like your showed. Limited contact made with rocks. I have the predator tube steps so the drop down stops hit periodically but nothing major. Worked out to about 2" of lift as my stock tires under weight measured near 29" at replacement and the Toyo M/T's measure right at 33" under weight. Lost some MPG, sitting around 18 MPG average at nearly 4k miles. They aren't too loud and make a world of difference being a more aggressive tread than the stock.
    As a side note since I know some reading this, @JoeCOVA , point out some of the logical misunderstandings about the "skinny" tire vs the equivalent wider tire (255/85R16 VS 285/75R16), I did not chose the the skinny tire for some belief that it was somehow superior. Rather, it was the tallest tire I could fit without spending a bunch up front for lifts and cuts. I knew the truck needed better tires and higher clearance, got both with in one. The Toyo's also measure in at only 0.25" narrower than stock tires based on tire websites.
    JoeCOVA likes this.
  17. Sep 7, 2018 at 1:17 PM
    #117
    JoeCOVA
    Joe
    Colorado Springs
    Oh ya this is true. A soft compound with be faster than a hard compound but will wear faster.
    Perfect example is Formula 1. Tire size is standardized for all cars but softer compounds are much faster
  18. Sep 7, 2018 at 1:19 PM
    #118
    ZYBORG
    TX / S. FL
    3G TRD OR
    The width of the tire can be an advantage to gain traction due to the larger contact patch, but most importantly than width, it is the compound of the tire and construction that will give the most grip.
  19. Sep 7, 2018 at 1:20 PM
    #119
    jowybyo
    Joe
    Baltimore, MD
    That's anecdotal. I know that as well, but I need you to research sir. Answers, we need scientific answers.
  20. Sep 7, 2018 at 1:21 PM
    #120
    jowybyo
    Joe
    Baltimore, MD
    But, why?
