Off-Roading with your Daily Driver?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phdog, Sep 6, 2018.
  1. Sep 7, 2018 at 1:22 PM
    #121
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Yea, but what does that have to due with width? We are just saying compound makes the grip, but what does width have to do with it since friction isn't a function of contact area.
  2. Sep 7, 2018 at 1:24 PM
    #122
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    Because is not about quantity, its about quality. Compound and construction are more important than “rubber on the road”, as theu will create more friction = traction.
  3. Sep 7, 2018 at 1:28 PM
    #123
    jowybyo
    Joe
    Baltimore, MD
    My bad, I read your original post wrong. I thought you said wider WILL ALWAYS give you more traction. So then why have 30" wide tires on a top fuel dragster?
  4. Sep 7, 2018 at 1:32 PM
    #124
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I did find this. I’m still reading through it
    https://www.stevemunden.com/friction.html
  5. Sep 7, 2018 at 1:40 PM
    #125
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    P=W/A
    Tire Ground Contact Pressure =
    Total (W)eight on tire/Tire contact (A)rea
    It doesnt have anything to do with the PSI of the air inside the tire, and would be the same on a solid wheel with the same weight and contact area.
  6. Sep 7, 2018 at 1:43 PM
    #126
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    Not enough of that on the interwebs. :thumbsup:
  7. Sep 7, 2018 at 1:43 PM
    #127
    JoeCOVA
    Joe
    Colorado Springs
    So this article seems to imply that given two tires that are the same compound that the friction of the tire would be the same given the force applied regardless of skinny or wide
    So 250 pounds of force on a skinny tire would offer the same friction as a wider tire with the same 250 pounds of force.
    The advantage lends to other things like heat and strength of the tire.
  8. Sep 7, 2018 at 1:44 PM
    #128
    jowybyo
    Joe
    Baltimore, MD
    If does have "something" to do with the air inside the tire. If you lower the pressure in the tire, the contact patch gets larger and vice versa. But we determined it's heavily influenced by the tire construction so that average contact ground pressure is not equal to the internal tire pressure.
    JoeCOVA likes this.
  9. Sep 7, 2018 at 1:49 PM
    #129
    jowybyo
    Joe
    Baltimore, MD
    I'd guess it's a material strength and heat issue.
  10. Sep 7, 2018 at 1:49 PM
    #130
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Please not that on the rear, no matter how much you lift the truck, the only way to gain clearance is to fit larger wheels and that's it.
    The body of the truck may be higher off the ground with a lift, but your rear axle won't be any higher off the ground unless it's sitting on larger wheels.
  11. Sep 7, 2018 at 1:52 PM
    #131
    JoeCOVA
    Joe
    Colorado Springs
    So I guess large drag tires are large to handle both the heat and stress from the large amount of power applied to them and the grip is determined by compound.
  12. Sep 7, 2018 at 2:22 PM
    #132
    OnHartung'sRoad
    Theres a skinny vs wide tire debate foing on a different thread too, the smaller the contact patch, the more PSI the tires exhert on the ground. Thats why snow shoes vs stilletoes are so popular in snowy areas!
  13. Sep 7, 2018 at 2:28 PM
    #133
    airjammer
    airjammer Well-Known Member
    Paonia Colorado
    '17 Silver Sky TRDOR DC MT
    F:OME Nitrocharger Sport 90021 w/888 Coils R:OME Nitrocharger Sport 60091 w/CSO47R Dakar Spring Pack
    absolutely
  14. Sep 7, 2018 at 2:30 PM
    #134
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    That's for flotation. Snowshoes help you not punch through and make it easier to walk. You want a vehicle to "punch through" so to speak in order to make contact with the road. A skinnier tire is generally better in snow and ice all else being equal.
    tacogeorge likes this.
  15. Sep 7, 2018 at 2:33 PM
    #135
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    5100's, 285's, little trimming etc, then get yourself at least a front IFS skid. Shouldn't hurt you too much on MPGs and I found it rode better over TRD-Sport suspension with just the 5100s. Just don't max them out on height without aftermarket UCAs. I just need to get my 285's when these shoes need changing.
  16. Sep 7, 2018 at 2:36 PM
    #136
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks. This is the info I needed. Sounds like you are saying that with the 5100s you need the new coils up front. I just went to a local shop and they said I didn't. I didn't get the sense they really knew what they were talking about though.
    I was also under the impression that if I didn't 1.5" with the shocks that I wouldn't need to modify any other suspension parts. Sounds like you are saying I might need a couple things. How do I know for sure?
    EDIT: Also, what is the difference with the 3 leaf AAL vs the single? I assume 2 more springs, but when would you want the single vs 3 leaf AAL?
  17. Sep 7, 2018 at 2:37 PM
    #137
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Every truck is different. Every scenario is different. What works for one might not for another. There is no way to guarantee or know for sure.
  18. Sep 7, 2018 at 2:40 PM
    #138
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    FIFY :thumbsup:
  19. Sep 7, 2018 at 2:44 PM
    #139
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Just wheel it as you please. I have 3 other vehicles and prefer to daily my TRD OR.
    ColoradoTJ likes this.
  20. Sep 7, 2018 at 2:54 PM
    #140
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Isn't that true of the front as well? I mean, the front lift will lift some of the underbody stuff, but the axle parts would still be the same height wouldn't they?
