Off topic jeep question
Discussion in 'General Automotive' started by hunter.tom, Sep 10, 2017.
  1. Sep 10, 2017 at 3:46 PM
    hunter.tom
    hunter.tom [OP] Well-Known Member
    2016 tacoma trd off-road
    My wife has a 2014 grand Cherokee. Last month the radiator split and was leaking. We had it replaced, and an A.C. test performed.
    A.C. is holding the Freon with no leaks, the air is cold.
    The problem is there is a increasingly louder darth Vader breathing noise when the air is on. Also, it developed a band aid smell as well.
    Any ideas?
  2. Sep 20, 2017 at 6:34 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Did you resolve this? A piece of foam could have dislodged in the air ducts and gotten stuck on the evaporator.
  3. Sep 20, 2017 at 6:50 PM
    hunter.tom
    No I haven't. Going to bring it to a mechanic next week. Is the evaporator accessible to check? Thanks for the reply
  4. Sep 21, 2017 at 6:31 AM
    KenLyns
    Belly of the Beast
    It should be possible to snake a borescope through the vents to inspect the evaporator. Physically accessing the evaporator requires taking apart the dash (several hours labor by a mechanic experienced with interior work).
  5. Sep 21, 2017 at 6:44 AM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    You might want to have a look at the cabin filter. Its in behind the glove box. Also check to see if there is water dripping out of the bottom of the jeep in around the passenger side fire wall. If not your drain could be plugged
    hunter.tom[OP] likes this.
