Offets
Discussion in 'Wheels & Tires' started by Unchained 5150, Mar 6, 2015.
  1. Mar 6, 2015 at 1:15 PM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Should say offsets.
    So buddy of mine is looking at these 2 wheels in 17x8 and isn't syre what offset is and I am not sure either. I told to go with 4.5 BS but wasn't sure on offset. Or the Bore.
  2. Mar 6, 2015 at 1:15 PM
    Unchained 5150
    Rick
    Auburn Ma
  3. Mar 7, 2015 at 8:19 AM
    BradyT88
    BradyT88 Well-Known Member
    Offset and backspace are basically one in the same. An 8" wide wheel with 4.5" BS has a 0mm offset.
    BS measures how many inches is from the inside lip of the wheel to the mounting surface.
    Offset measures how many millimeters the mounting surface is offset from the center of the wheel.
    An 8" wheel measures 9" wide lip to lip. So the center of 9" is 4.5" which means the mounting surface is centered on that wheel so it has no offset so 0mm offset.
    An 8" wide wheels with 3.5" BS means the the mounting surface is offset 1" or about 25mm. The wheel will stick out 1" further than the 4.5" BS.
  4. Mar 7, 2015 at 8:58 AM
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    Offset for 17X8 is 0
    Offset for 17X9 is -12
    Bore is 106.4
