Offical Gears and Locker Group Buy!! NOW OPEN!
Discussion in 'Automotive Group Buys' started by Blackdawg, May 10, 2017.
  1. May 21, 2017 at 4:50 AM
    #101
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    Rpms are too high on freeway. Truck is around 3000 rpm at 70. I did it before I installed a supercharger. Also have a 4 banger.
  2. May 21, 2017 at 5:56 AM
    #102
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I've also considered the same change. I did the same as you w 4.88 and 33s, just went turbo instead of S/C. Rpm feel a bit high now.
  3. May 21, 2017 at 5:59 AM
    #103
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Yeah it's not very comfortable on long trips. I'm still averaging about 20 mpg highway but would be nice to cruise a little faster. Think I would notice much of a difference from 4.88 to 4.56?
  4. May 21, 2017 at 6:24 AM
    #104
    boostedka
    James
    NM
    According to grimmjeeper it would lower RPMs by ~200 at 70-75 mph. 70mph would be 2800rpm and 75 would be 3000rpm
  5. May 21, 2017 at 8:57 AM
    #105
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    I sooooooo want to, but ima have to wait for next year. Even though this is a screaming deal. I literally got the 285s this week. I have only driven the truck a couple times, and initial thoughts are that I can live with it......for now:anonymous:
    Though I would love to be locked up front/regear for 2/3 of the normal cost
    Wadar[QUOTED] likes this.
  6. May 22, 2017 at 7:04 AM
    #106
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Do we have enough people for the discount?? If so I'm in for a set of 4.88s. Took a trip to Moab this weekend just after putting on 33" tires and my truck was screaming in 3rd gear to maintain 70mph up rt. 6.
  7. May 22, 2017 at 7:45 AM
    #107
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    That's cause we only have 190 ponies stock in these little trucks:anonymous:
  8. May 22, 2017 at 7:56 AM
    #108
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Thought I'd share this formula for those that haven't seen the episode of Power Nation with the 2011 Tacoma they are working on...
    New tire size/Stock tire size X Stock gear ratio = Recommended gear ratio to keep stock feel
    seoulja99 likes this.
  9. May 22, 2017 at 11:03 AM
    #109
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Only enough people if people commit.
  10. May 22, 2017 at 12:39 PM
    #110
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bump! This is the last week to get in on this.
    Discount on all parts!
    @Sub-Zero didn't you want in?
  11. May 22, 2017 at 1:53 PM
    #111
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Yes I was very excited for this. Unfortunately I will be backing out bc im hopefully transitioning careers! Sorry guys, I've never been "that guy" before but gotta save for the move
  12. May 22, 2017 at 2:43 PM
    #112
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Next time :(
  13. May 23, 2017 at 10:51 AM
    #113
    Blackdawg
    Monte
    Wyoming/St. Louis
    4.56 most likely.
  14. May 23, 2017 at 8:26 PM
    #114
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Hey fellas, I have a 2005 manual taco and running 285/65R18 tires and was wondering if one of these gear ratios would improve the extreme torqueness experienced with the stock gears I'm currently running? Also, what is the benefit of the front gear locker over the stock system? Thnx
  15. May 24, 2017 at 3:48 AM
    #115
    Boomkanani
    Goldsboro, NC
    Some stuffz
    I'm not sure what torqueness feels like. To me that means too much torque, but you're running bigger tires than stock and it's a Tacoma...so you couldn't possibly mean that :rofl:
    If you mean it feels like not enough torque...you want a higher gear ratio so your transmission doesn't work as hard. Plenty of information out there to research that.
    Front differential air locker basically locks the independent axles so the driveshaft moves both axles. If you have front and rear differentials locked and 4wd engaged...all 4 wheels will be getting torque applied.
  16. May 24, 2017 at 4:48 AM
    #116
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    What all would I need to get to chane my rear 4.10s to 4.88s. I do have the oem locker
  17. May 24, 2017 at 6:58 AM
    #117
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Alright, so I made up Torqueness but thought it sounded good dammit! :D But your right it feels like I have to shift into 2nd gear instantly and not going anywhere fast when doing so. So does the 4.56 gear ratio improve that issue or some other combination you can reccomend? As for the Locker, I've read a lot about it but could never really get a definitive answer on how its an improvement over the stock system and what is required I.e. other equipment and labor needed for the install. So I appreciate any insight you can provide, so I can join the group buy! Thnx
  18. May 24, 2017 at 7:00 AM
    #118
    boostedka
    James
    NM
    Probably just need the 4.88 ring & Pinon and the rear master install kit.
  19. May 24, 2017 at 7:36 AM
    #119
    Blackdawg
    Monte
    Wyoming/St. Louis
    4.56 would be the choice.
    Front locker works like your rear locker. That said, unless you're doing some pretty hard offroading you'll never use it.
    One reason it's nice is it makes the front diff stronger as well. Something I'm looking forward too.
    Just a ring and pinion and install kit. So Lindsey pinion spacer is recommended. Then someone to install it.
  20. May 24, 2017 at 7:42 AM
    #120
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Just wanna give a shoutout to @Low Range Off-Road - I was in Moab and ruined my spider gears so I wanted to go ahead and do a rear locker instead of just putting stock spider gears back in. The shop (Moab 4x4 Outpost) and I called like 40 vendors and nobody had access to an ARB air locker they could get us within a short time frame. Once I called Low Range they gave me a list of vendors to try and one of them (Fat Bob's Garage) was able to get me a locker within 2 days to get me back home to Alabama. A few vendors simply said no they couldn't find me anything and ended the conversation, but Low Range (wish I knew who I spoke with) spent time on the phone with me and even made calls to vendors for me as well. Customer service speaks volumes for me personally and they helped me find who I needed to get me home, with no personal gain on their part. Props to Low Range and this is a great deal if anybody is looking to buy this stuff!
    Vanguard, Braves95, Digiratus and 2 others like this.
