Official 1995.5-2004 5lug tacoma lifted/lowerd suspension guide and general info
Discussion in '5 Lug' started by Sperrunner, Apr 21, 2018.
Was this thread helpful?
  1. Yes
    67 vote(s)
    95.7%
  2. No
    3 vote(s)
    4.3%
  1. Dec 3, 2019 at 12:41 PM
    #81
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    That's what I figured as well. I'll be buying the full rear from a part out/junkyard, and taking it to someone to install likely. I'm sure it isn't too hard to complete but I live in an apartment with no garage so I'm limited with work. Still have a lot of tread on the tires and a ways to go, but glad to hear the idea of a 6 lug rear end w/ e locker is feasible
  2. Dec 5, 2019 at 10:45 AM
    #82
    jruiz555
    jruiz555 Well-Known Member
    cool good move, you can get one with 4.10 from a tacoma. I think if you wanted to go 4.30 the 4runners have the center locking diff with 4.10 and 4.30 but the housing wouldn't work just the center diff.
    anyone interested in my old fabtech add a leaf? I think they add like 1.5-2" in the rear, I removed them 2 weeks ago.
  3. Dec 5, 2019 at 10:59 AM
    #83
    Das it mang
    Az
    1996 T100 SR5 MT
    I'll prolly chill with the 4:10 for now unless I can find someone still making reinforced LBJ brackets. I heard people had issues with them snapping when they went bigger tires. Wish I could do the jump to 33's, but those people make me worry saying that. you end up changing your add a leaf to shackles?
  4. Dec 5, 2019 at 11:50 AM
    #84
    jruiz555
    I dont think u can fit 33" without a body lift
  5. Dec 5, 2019 at 11:51 AM
    #85
    jruiz555
    I have 31" and rub while i turn the steering to go up a incline. I think with a 2" body lift then maybe, but that would be with the lift spindles and fabtech uca
  6. Dec 5, 2019 at 11:56 AM
    #86
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    With 33" you'll need a lift spindle n trim your fenders or go fiberglass, and pinch weld mod is a must.
    Stay away from body lifts.
  7. Dec 5, 2019 at 12:00 PM
    #87
    Das it mang
    Az
    1996 T100 SR5 MT
    But, with your experience, would 33's be okay on stock LBJ's? have people overhyped them not being strong enough?
  8. Dec 5, 2019 at 7:02 PM
    #88
    BikerinBlak909
    SoCal
    96 LT 5 lug
    I have not broken the bracket. But I couldn't fit a 33" with stock arms. Even with fabtech spindles, uppers, coils, fiberglass n pinch weld mod it rubbed too much when I cranked the steering all the way.
    Das it mang[QUOTED] likes this.
  9. Dec 5, 2019 at 7:07 PM
    #89
    BikerinBlak909
    SoCal
    96 LT 5 lug
    I have seen the bracket break with 31". A guy on here broke 1 while driving down the street with 31
    Das it mang likes this.
  10. Dec 6, 2019 at 7:11 AM
    #90
    Das it mang
    Az
    1996 T100 SR5 MT
    HMM maybe people were beating up too much on their mini taco's then. Glad to hear there's not too much worry then, bc I'm sure you mobbed ur 5 lug harder than I will and had no issues. I probs wont go above 32's or like a 265/75/16.
    P.S.
    When I replace my lbj's, would u say moog isn't that bad for our 5 lugs? seems everyone on the 1st gen forum is oem or bust, but some on here had good results with moog.
  11. Dec 6, 2019 at 8:17 AM
    #91
    pwrslide2
    pwrslide2 Well-Known Member
    AZ
    07' 2.7 2wd auto
    In process
    are the moog Upper and lower control arms any good?
  12. Dec 6, 2019 at 9:32 AM
    #92
    BikerinBlak909
    SoCal
    96 LT 5 lug
    I used their ball joints with no complains. Control arms Idk. I know they make coils for 1st gen 5 lugs that are a bit stiffer to level out the front. I saw 1 guy tgat had am n loved it
  13. Dec 6, 2019 at 9:57 AM
    #93
    Das it mang
    Az
    1996 T100 SR5 MT
    thanks for your response, guess moog will be the route I go with the LBJ's. And yeah v6 coils are what I plan on getting for my truck soon, was gonna stack the daystar spacer with it for now; unless I find a cheap set of used fabtech/doestch spindles. no idea where to look, never see em on the TW marketplace
  14. Dec 6, 2019 at 10:05 AM
    #94
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    Got it. I'm surprised Koni doesn't have something for this vehicle. I know people that can get them made and help select the right valving. I feel like the fronts should be simple enough to get done with single adjustable Koni yellows and get an added 2" or so of travel with same compressed length.
  15. Dec 6, 2019 at 12:36 PM
    #95
    BikerinBlak909
    SoCal
    96 LT 5 lug
    The prerunner coils are not an exact fit n if i we're to do it again I would get moog 5 lug coils just cuz they are exact fit n they have several options.
    If your looking spindles I'd just buy new. Like around $300. If you get a used 1 you dont know if it abused, N it's cast. And if you get it new you'll have it right away instead of waiting n hoping to find one on Craigslist
  16. Dec 6, 2019 at 3:08 PM
    #96
    Das it mang
    Az
    1996 T100 SR5 MT
    Lol yes the moog coils are what im referring to. They are for the 5 lug v6 model which is why it lifts our 2.4l 5 lugs to level. Unless there's other moog coils besides the 81070 model that level/lift the front?
    I Won't look used for the spindles then, that is a good point thank you
  17. Dec 14, 2019 at 1:53 PM
    #97
    Tikibutt
    Tikibutt Well-Known Member
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    JBA UCAs, Radflo Coilovers, Lockrite mechanical Locker, All-Pro Offroad Skid Plates, 4x Innovations Sliders, Dakar Rear Springs, 37x13.50r17 Cooper SST Pro on Beadlocks
    Anyone ever swap to a 6-lug hub? Really like the 5-star wheels on 3rd Gen T4R Limiteds and would like to see what all is involved in putting some on my '99.
  18. Dec 15, 2019 at 2:29 AM
    #98
    BikerinBlak909
    SoCal
    96 LT 5 lug
    Idk if it's possible. I only know 4x4 pick up spindles allow for 6 lug
  19. Dec 15, 2019 at 10:20 AM
    #99
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    more pain than it's worth most likely. 5x114 has a lot of options out there. just a lot less gaudy fake 3pc and fake bead-locker styles
  20. Dec 15, 2019 at 2:26 PM
    #100
    jruiz555
    Wouldnt work, 4x4 and prerunner totaly differential suspension.
