Official 2014 ROCK THERAPY picture thread!
Discussion in 'Moab' started by lotsoftoys, May 23, 2014.
  1. Aug 14, 2014 at 12:02 PM
    #801
    BradyT88
    BradyT88 Well-Known Member
    He won a voucher for a set of 4 free tires in the raffle down there.
  2. Aug 14, 2014 at 12:02 PM
    #802
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    yeah I would have loved that. only 35's are a bit small for my liking.
  3. Aug 24, 2014 at 1:38 PM
    #803
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Finally got my prize installed too!
  4. Aug 24, 2014 at 9:02 PM
    #804
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Does that have a drain hole on the bottom?
  5. Aug 24, 2014 at 9:56 PM
    #805
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    it goes around the bottom but doesent cover the drain plug
  6. Aug 25, 2014 at 7:18 AM
    #806
    rctoy
    konstantenos
    Pocatello Idaho
    my rear diff armor is my cover. just the factory one right now:eek: I have no clue what I want to repace it with.
  7. Aug 25, 2014 at 7:46 AM
    #807
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Yeah but Mark can't it fill up with mudd and water in the back there and rust or does it have drain holes on the bottom?
  8. Aug 25, 2014 at 7:54 AM
    #808
    BradyT88
    My Allpro one has holes in the bottom to allow it to drain. Though it is a bit strange the way it worked out. The wholes seem to be there more out of poor fitment than intentionally but maybe it was intentional. haha
  9. Aug 28, 2014 at 11:01 PM
    #809
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ok now I get what you guys are saying.
    Brady, are you saying that your all pro one has "drain holes" due to apparent ill fittment? If so then mine is the same way. When its all welded on the side pieces dont fully connect with the bottom middle piece. So it would act to drain, but I welded it up high enough I honestly cant see the pieces that "stick out" would ever be an issue, and if it was then oh well, I slide off em or bend em in a bit
  10. Aug 29, 2014 at 7:25 AM
    #810
    BradyT88
    It had some to do with the fact that we are using a square shaped object to cover a round object.
    But there was quite a gap at the bottom. Konsta stuck a couple welding rods in there and welding them in to fill that gap at the bottom. haha Like I said it very well could have been designed like this on purpose so you have gaps for drainage.
  11. Aug 29, 2014 at 7:27 AM
    #811
    rctoy
    konstantenos
    Pocatello Idaho
    those welds.. gross you need to find your self a better welder brady..
    Also id just like to point out I stomped around on 35's and never ran diff armor and never had an issue.
  12. Aug 29, 2014 at 7:30 AM
    #812
    BradyT88
    I only had an issue once. Got a little hung up on some rocks and had to back up and had a rock conveniently placed right behind my diff that dented it slightly.
    Caleb caved his rear diff cover in so bad you could see the shape of the ring gear:eek: and he did that on 40's. haha
  13. Aug 29, 2014 at 8:05 AM
    #813
    rctoy
    konstantenos
    Pocatello Idaho
    yeah ill have to get a better cover when I go to 40+ tires though my cover/ armor unbolts and can be replaced easily :taco:
  14. Aug 29, 2014 at 8:41 AM
    #814
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    I was discussing rear diff covers with someone on a trail one day and we were like "I've never actually seen anyone need them on the back" and not 30 seconds later a guy backed up and smashed his diff open haha
  15. Aug 29, 2014 at 10:00 AM
    #815
    rctoy
    konstantenos
    Pocatello Idaho
    im not going to lie I cant imagine you on a trail hard core enough for that to happen to anyone.
  16. Aug 29, 2014 at 11:37 AM
    #816
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Hahahahaha! That is exactly why I'm glad I have mine. The bottom is pretty stout. I'm not worried. But the rear is pretty thin, so I'm glad I have the protection just in case
    Coulda been in her dads krawlar
  17. Aug 29, 2014 at 6:21 PM
    #817
    lotsoftoys
    lotsoftoys [OP] pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    ive ran my tg diff armor, ive had a few scratches and dingers on it, who knows what would of happened if i didnt have it
  18. Dec 30, 2014 at 12:22 AM
    #818
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    X2. The trail run right after I welded on the diff cover Infact i backed straight into a rock and drug the whole diff cover off it. Whoops
  19. Dec 30, 2014 at 8:22 AM
    #819
    rctoy
    konstantenos
    Pocatello Idaho
    Debating on building a diff cover or just buying one for my rear diff. Seeing how as it's just 14 bolts and filling up the fluid.
