OFFICIAL 2nd gen 4x4 front differential bearing vibration POLL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BassAckwardsDyl, Jan 24, 2012.
Front diff grinding/vibe... yes or no..
Poll closed Feb 23, 2012.
  1. 2005 YES - Stock or Lifted
    6 vote(s)
    4.2%
  2. 2005 NO - Stock or Lifted
    7 vote(s)
    4.9%
  3. 2006 YES - Stock or Lifted
    17 vote(s)
    12.0%
  4. 2006 NO - Stock or Lifted
    8 vote(s)
    5.6%
  5. 2007 YES - Stock or Lifted
    15 vote(s)
    10.6%
  6. 2007 NO - Stock or Lifted
    9 vote(s)
    6.3%
  7. 2008 YES - Stock or Lifted
    12 vote(s)
    8.5%
  8. 2008 NO - Stock or Lifted
    8 vote(s)
    5.6%
  9. 2009 YES - Stock or Lifted
    7 vote(s)
    4.9%
  10. 2009 NO - Stock or Lifted
    10 vote(s)
    7.0%
  11. 2010 YES - Stock or Lifted
    10 vote(s)
    7.0%
  12. 2010 NO - Stock or Lifted
    8 vote(s)
    5.6%
  13. 2011 YES - Stock or Lifted
    13 vote(s)
    9.2%
  14. 2011 NO - Stock or Lifted
    12 vote(s)
    8.5%
  1. Jan 24, 2012 at 3:24 PM
    BassAckwardsDyl
    BassAckwardsDyl [OP] The Red Bull
    Dylan
    Kapolei, Hi
    07 Sport DC 4x4
    She is no longer the same Sport that I bought!!!
    Here is the poll for those of us with 2nd gens who HAVE and HAVE NOT experienced the grinding/vibrations caused from the front diff bearing. If you have had the diff changed within the warranty period, please let us know here... trying to get real numbers to see how common this problem is.
  2. Jan 24, 2012 at 4:57 PM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2010 DBLC 4x4 Off Road
    I don't know if you need each year as I believe they all use the same front diff from 2005 to present. I think it should be a poll more so based on Stock, lifted .85-2" and 2" and higher. Just my opinion though. Somebody else will probably chime in.
  3. Jan 24, 2012 at 4:59 PM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    5100s up front set at 2 inches. Had small vibe before lift that dealer said was tires. After lift it got worse. Diff replaced but not under warranty at 45k. Its starting again at 65k. Pretty much the reason I will think twice before I buy another Toyota! Love the style But this issue with limited support from Toyota will likley push me back to ford. Please don't tell me to enjoy a ford as I've had 3 now and all had fewer issues.
    Rant over but the front diff is a known issue on some trucks.
  4. Jan 24, 2012 at 5:49 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Just to be clear, are we talking about a vibe felt on takeoff, betwen 1st & 2nd gears? If I push my stock O/R a bit between these two gears, it'll give a shudder.
  5. Jan 24, 2012 at 6:23 PM
    BassAckwardsDyl
    Dylan
    Kapolei, Hi
    07 Sport DC 4x4
  6. Jan 24, 2012 at 7:05 PM
    Maticuno
    Maticuno Weapon Mechanic
    California High Deserts
    08 DCLB Sport
    Pioneer AVIC-D3, SWI-PS, Sirius Satellite Radio, 2X In-Cab 110V Outlets, Constant Fog Light Mod, Inverter Always 400W Mod, Anti-Pack-Rat-In-Intake Mod, Eibachs on 5100's, 2" Toytec AAL, B.A.M.F Rear Diff Skid, 265/70R17 Goodyear Wrangler Authority tires
    2008, Slight diff vibration after 2" lift. Not bad yet, but I'm sure it'll get worse.
  7. Jan 24, 2012 at 7:09 PM
    Tdye82
    Tdye82 Well-Known Member
    I like the idea for the poll but im 99% sure the diffs are the same for all years (2005 up). I think it would be better info if we knew who had the vibration with stock ride height or lifted. just my two cents. [​IMG]
  8. Jan 24, 2012 at 7:40 PM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    i have about 1 inch of lift and have a mad vibe, but its intermittent.
  9. Jan 24, 2012 at 9:39 PM
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    Just my $0.2, to be of value for creating a case for a Toyota TSB, I think it may be better to have the poll be more specific. Maybe poll:
    Only for confirmed bad front Differential bearing diagnosis (either by Independent mechanic or Toyota, and NOT wheel bearings). If so, are you:
    Stock?
    Lifted?
    To make a case, we need to confirm that this is happening on stock trucks. They're not covering trucks if they're lifted, but we may have a case if it's happening on a significant percentage of stock trucks.
  10. Jan 24, 2012 at 11:19 PM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island--->Oahu, Hawaii
    10 AC TRD OR 4x4 BSP; 08 Reg Cab 5 spd 4x4
    TRD Off Road No. 401 off the assembly line! ~ 19k miles 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Smoked Eagle Eyes Ebay LED Tails | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    No front diff vibes here. 2010 O/R with Toytec Lift Kit.
    However, I do have the takeoff shudder coming from elsewhere.
  11. Jan 25, 2012 at 12:06 AM
    DATZ WEAKSAUCE
    DATZ WEAKSAUCE Well-Known Member
    Nor cal
    2011 MGM TRD SPORT
    all these vibe/noise horror stories makes me think twice about lifting my truck =X
  12. Jan 25, 2012 at 12:39 AM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Lifted. Especially after in disengages, seems like i can still feel a grinding & vibration. Engaged its a definite, yes.
  13. Jan 25, 2012 at 12:39 AM
    MQQSE
    MQQSE Chief Pal Guy, GOB
    Rob III
    Palmer, AK
    07 4cyl/5spd/4x4 AC SR5
    2007 Stock yes
  14. Jan 25, 2012 at 1:51 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    coilovers 3" up front and tsb with aal (total 1.5") No vibes or noises-quiet as a mouse
  15. Jan 25, 2012 at 3:34 AM
    Tdye82
    Yours is stock and your having the vibrations? Do they go away when engaging 4wd?
  16. Jan 25, 2012 at 4:20 AM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    Mine has a grinding sound when i do between 70 and 80 but it doesn't always do it......
  17. Jan 25, 2012 at 4:29 AM
    MQQSE
    Rob III
    Palmer, AK
  18. Jan 25, 2012 at 7:01 AM
    ZMan2k2
    ZMan2k2 Well-Known Member
    Richard
    Calgary, Canada
    06 DC LB SR5
    I've got an '06 that was stock for the first 65k Km's of it's life. I now have 5100's at 1.75" with TSB springs in the rear. So far so good, no noise at all at 71k Km's.
  19. Jan 25, 2012 at 1:01 PM
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    I have a 2" lift and on my second diff. I once again have the diff growl between 60-70kph. Tacoma's with the same vibe and no lift would be valuable info to have as well. Nice work starting up the poll.
  20. Jan 25, 2012 at 1:17 PM
    lundy
    Justin
    Reno, NV
    Ture. Yo OP!! Lets change this to "lifted vs non lifted" forget each individual year.
