OFFICIAL 2nd gen 4x4 front differential bearing vibration POLL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BassAckwardsDyl, Jan 24, 2012.
Front diff grinding/vibe... yes or no..
Poll closed Feb 23, 2012.
  1. 2005 YES - Stock or Lifted
    6 vote(s)
    4.2%
  2. 2005 NO - Stock or Lifted
    7 vote(s)
    4.9%
  3. 2006 YES - Stock or Lifted
    17 vote(s)
    12.0%
  4. 2006 NO - Stock or Lifted
    8 vote(s)
    5.6%
  5. 2007 YES - Stock or Lifted
    15 vote(s)
    10.6%
  6. 2007 NO - Stock or Lifted
    9 vote(s)
    6.3%
  7. 2008 YES - Stock or Lifted
    12 vote(s)
    8.5%
  8. 2008 NO - Stock or Lifted
    8 vote(s)
    5.6%
  9. 2009 YES - Stock or Lifted
    7 vote(s)
    4.9%
  10. 2009 NO - Stock or Lifted
    10 vote(s)
    7.0%
  11. 2010 YES - Stock or Lifted
    10 vote(s)
    7.0%
  12. 2010 NO - Stock or Lifted
    8 vote(s)
    5.6%
  13. 2011 YES - Stock or Lifted
    13 vote(s)
    9.2%
  14. 2011 NO - Stock or Lifted
    12 vote(s)
    8.5%
  1. Feb 2, 2012 at 6:27 PM
    #41
    maxamillion2345
    maxamillion2345 Go home if you don't like guns liquor and whores.
    Max
    Nevada
    Ferd Fteenthousand 6.4
    Tuner.
    Dude... did you watch the videos or read the thread?
    Wrong carrier bearing !
    The differential carrier bearing is the problem. Can't fix that with a spacer or shim.
    Toyota just cast the slot for the side gear into the carrier rather than machining so instead of .005 of an inch we have .050
  2. Feb 3, 2012 at 12:29 AM
    #42
    Tdye82
    Tdye82 Well-Known Member
    wish there was a licking windows smiley... :facepalm:
  3. Feb 3, 2012 at 5:07 AM
    #43
    MaloneS
    MaloneS Well-Known Member
    Steven
    The Woodlands, TX
    08 Tacoma 4x4 TRD Offroad
    Wet Okole, OME 2.5" lift and front bearing drop, leaf shims, Xtreme HID's, 33" tires on 17" MT Locks
    Oh. When I said diff, I meant front diff.
  4. Feb 3, 2012 at 7:55 AM
    #44
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Little but I dont fully agree with Moose on what vibes are. From what CHase showed its a side gear that becomes so loose that allows axle to wiggle. Needle bearing is not made to hold axle in one location all it does it makes sure axle can rotate. Its the side gear that supposed to not let axle move. (and vibe) Still that does not answer the question how side gear gets loose enough to move, and how come some trucks have side gears that seem to be better machined..
  5. Feb 3, 2012 at 9:46 AM
    #45
    maxamillion2345
    Max
    Nevada
    Tuner.
    That's still not really the fix or issue. A diff drop will angle the diff forward dropping the front and lessening the angles on the cvs but the problem behind the vibration is that toyota cast the slot for the side gears into the carrier rather than machining so you have lots of slop inside the carrier. Lifting doesn't help it for sure but regardless it's an issue of manufacturing. Other carriers are machined to accept the side gears.
  6. Feb 3, 2012 at 9:53 AM
    #46
    maxamillion2345
    Max
    Nevada
    Tuner.
    I'd imagine that it's not easy to get precision when you cast the carrier to accept the side gears rather than machine to close tolerances. So some might be .005 and some might be .002 and some might be .0015 etc etc
    or maybe it really is the side gears out of spec but I wouldn't think so.
  7. Feb 3, 2012 at 10:04 AM
    #47
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2010 DBLC 4x4 Off Road
    It makes the most sense to me because when lifted 3" I had really bad vibes, Dropped down to just Eibachs (1.5") up front and they got a lot better. Then just to see dropped down to stock height up front and it was gone. Seems to me the less the pressure the less the vibe until flat angles with no pressure and no vibes. Probably why the RCD club is vibe free
  8. Feb 3, 2012 at 2:58 PM
    #48
    MaloneS
    Steven
    The Woodlands, TX
    Gotcha! :smack:Thanks for the beating...I mean teaching.
  9. Feb 3, 2012 at 3:03 PM
    #49
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Check the build
    2010 stock no lift
  10. Feb 3, 2012 at 6:56 PM
    #50
    maxamillion2345
    Max
    Nevada
    Tuner.
    Hope I didn't come across mean. Cheers.
    -Max
  11. Feb 3, 2012 at 8:37 PM
    #51
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    You didn't come across mean....your truck does though!
  12. Feb 3, 2012 at 10:12 PM
    #52
    maxamillion2345
    Max
    Nevada
    Tuner.
    Thanks! I like your color matched ARB.
  13. Feb 3, 2012 at 11:45 PM
    #53
    Koby
    Vancouver
    06 access trd
    Killer ride and cool pics dude. I guess I need to start taking some.
  14. Feb 4, 2012 at 4:45 AM
    #54
    MaloneS
    Steven
    The Woodlands, TX
    Guess I could of watched the videos first...installing my lift this morning with some friends; hope all turns out well. Not mean Max, just educational. :)
  15. Feb 4, 2012 at 10:25 AM
    #55
    maxamillion2345
    Max
    Nevada
    Tuner.
    :cool: good luck!
  16. Feb 5, 2012 at 11:31 PM
    #56
    Tacomatrd2010
    Tacomatrd2010 Well-Known Member
    Jimmy
    Colorado
    2010 TRD Sport 4wd
    ARB bull bar,wheather tech mats,trail fx low pro toolbox,dynomax super turbo muffler,
    X2
  17. Feb 6, 2012 at 12:31 PM
    #57
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Spokane, WA
    incredibuild in progress
    modded the F*ck out
    it's not horrible but it's annoying
  18. Feb 6, 2012 at 3:01 PM
    #58
    MaloneS
    Steven
    The Woodlands, TX
    Installed my OME this past Saturday and everything went good. A bit higher, just need wheels and tires. Not aligned yet, but did notice a very slight shutter on initial take off. But not noticed at any other speeds so far.
  19. Feb 7, 2012 at 8:05 AM
    #59
    Koby
    Vancouver
    06 access trd
    Your takeoff shudder can be fixed with either the CB drop or going to a one piece DS. No biggie.
  20. Feb 7, 2012 at 1:06 PM
    #60
    MaloneS
    Steven
    The Woodlands, TX
    Did the carrier bearing drop and front diff. drop. Guess I will try to one piece drive-shaft (ds)?? Hope that is what you mean. Thanks for info.
