OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jan 26, 2012 at 7:42 PM
    #181
    Tacomablue
    Tacomablue Member
    Rob
    Arvada,CO
    07 TRD Offroad
    ECGS Bushing Mod, 3" Leveling Kit, Rosen Nav, Alpine Sub/Speakers/Amp, fog light always on, bushwacker pocket fender flares, spidertrax wheel spacers, dash cluster white LED mod, interior LEDs and 4x4 lighted switch.
    Same here, can't wait to hear the outcome! Hopefully he's ready to start mass producing! Sound like there's a lot of us sitting on the edge of our seats.:D
  2. Jan 26, 2012 at 9:17 PM
    #182
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Any updates on the potential bushing fix???
  3. Jan 27, 2012 at 5:47 AM
    #183
    tim allan
    tim allan Well-Known Member
    Wv
    2017 double cab trd offroad
    Ill repsond in about an hour
  4. Jan 27, 2012 at 6:22 AM
    #184
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
  5. Jan 27, 2012 at 7:34 AM
    #185
    tim allan
    Wv
    got the truck back, no vibes and it rides a lil smoother,
    700cinema likes this.
  6. Jan 27, 2012 at 7:51 AM
    #186
    Tacomablue
    Tacomablue Member
    Rob
    Arvada,CO
    07 TRD Offroad
    Excellent! Any plan on trial time with yours before they start producing the bushing for the rest of us to purchase?
  7. Jan 27, 2012 at 9:10 AM
    #187
    codyb1
    codyb1 Well-Known Member
    Cody
    Utah
    2015 TRD Sport DCLB
    Toytec Boss Coilovers set at 3" with AAL's,Toytec Boss Rear shocks, LR UCA's, Swaybar Relocate, Diff Drop, 265/70 Nitto Trail Grapplers, 17" KMC wheels, K&N, Limo Tint, 4.7" Shorty Antenna
    Tim, did your truck have the vibes before Chase @ ECGS got a hold of it? and how bad was it? Or were you just preventing the growling before you lifted it?
  8. Jan 27, 2012 at 11:05 AM
    #188
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Exact same situation/conversations here in Montreal. Frustrating for sure.
  9. Jan 27, 2012 at 11:31 AM
    #189
    tim allan
    Wv
    had no vibes before, but now I am lifted 1.75 and the only vibes I am feeling is from my new duratracs
  10. Jan 27, 2012 at 4:00 PM
    #190
    ECGS
    ECGS Well-Known Member
    Chase
    RALEIGH
    the bushings are in production and we are hoping to have a small batch in about 2 weeks.
    As for a scored grooved shaft yes it needs to be replaced, i was merely saying that the dealer need not replace it if it was not bad. if it is bad then yes it needs to be replaced its spinning in a bearing so it needs to be a clean polished surface.
    As for the spider gear design itself I see no feasible solution based on cost. There is no known case that would install in the carrier with out significant machine work to try to eliminate the problem. The added machine work and cost of the case and say a lockright installed would be more than an ARB. And a bushing would still also need to be used.
    This spider gear design has been in play since 1986 and has only now become an issue. With the spider gear bore not being machined the needle bearing is needed to support the CV shaft, however needle bearings do not like side load where as the sintered ptfe bushing we are using will take the load and all will be well.
    We are also looking at tools and trying to find the best tool for removal of needle bearing and we will make that available if we can.
    Thanks, Chase @ECGS
  11. Jan 27, 2012 at 4:07 PM
    #191
    BenWA
    Boston burbs
    Thanks for the update Chase. If all goes well with that first batch, reserve one for me please!! :) I want one as soon as you have one available for me. Thanks again for working on an affordable solution.
  12. Jan 27, 2012 at 4:23 PM
    #192
    Tacomablue
    Tacomablue Member
    Rob
    Arvada,CO
    07 TRD Offroad
    Same here, I've got all the other parts and tools required and ready to give this a try. ECGS Rocks!! Thanks Chase.
  13. Jan 27, 2012 at 5:54 PM
    #193
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Chase, if you haven't created a tool and want to contact Ryan (06RadiantRed), he'd probably be willing to ship his out to you (like how I'm volunteering him when I haven't even asked him:D). He created it when changing his, and we used it to replace mine too. Worked perfectly. Here's a post where he has pics:
    http://www.tacomaworld.com/forum/2n...e-bearing-replacement-done-4.html#post3205856
  14. Jan 27, 2012 at 6:33 PM
    #194
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
    I just want to say a big thanks to Chase and his efforts in resolving this problem that it seems many of us have. I still can't believe Toyota hasn't addressed this issue and taken the time to listen to just one of us that tried to explain the problem. I'm going to my dealer next week and I'm going to explain to him how I will be changing out my diff bearing myself (that is under warranty) and installing an aftermarket part that fixes the problem. Also thanks to Tim Allan for bringing this issue to Chase. :)
  15. Jan 27, 2012 at 6:35 PM
    #195
    superbikedad
    superbikedad Active Member
    Jeff
    Lake Stevens, Washington
    07 sr5 trd dbl cb 4x4
    Bilstein 5100's, 1.75 lift front, 1' block rear,265/70/16
    07 dbl cab trd off road. Lifted 3yrs ago with 3" spacer lift. Had vibes... and no idea what was going on, so lift was removed. Found Tacoma World and learned of the front diff problems. Figured screw it...installed 5100's at 1.75 2yrs ago and 1'' block in rear. Vibes came back. Recently moved the 5100's to 2.5 front, removed 1" block and installed 2" add a leaf in the rear. Vibes are worse. 86,000 miles on truck. First lift went on at 36,000. Please put me on the order list. Thanks Chase for your hard work.
    Jeff
  16. Jan 27, 2012 at 8:56 PM
    #196
    mdw5
    mdw5 Member
    Mitch
    Clovis, NM
    2010 Double-cab Tacoma 4x4
    3" Toytec Lift, Westin Bull and Nerf Bars, 285/75 x 16" BFG's, 2008 FJ Cruiser TRD Alloy wheels
    First post here; Add me to the vibe club. 2010 dbl cab, Toytec 3” lift up front withAAL and diff drop, BFG TKO 285/75’s on FJ TRD wheels. My first onset ofvibrations was at about 7k. The vibration started distinctly after using thetruck in 4wd for a day of driving on considerable snow and ice. As soon as Ireturned to 2WD, the vibes were distinct. Local Toyota dealership (Clovis, NM)replaced spider gear and left side bearing and all seemed well until approx. 17K,when I again used the truck in 4WD. As soon as I returned to 2WD, the vibes haddistinctly returned. My dealership was very reasonable the first time aboutcovering everything under warranty, but I’m reluctant to wear out my welcomeasking for any additional work as I think he really had to convince hisregional rep to work with me the first time. As the circumstances stand rightnow, I think my local dealer would still provide warranty work if thebearings/cv got really bad but my question is whether installing the newbushing from ECGS would void all front end differential related warranties? Don’tget me wrong, I’m thrilled about the prospect of a solution to make my Tacomafeel like a Toyota should again, but I certainly want to know the consequenceson warranty in advance. Anyone have information on that? Thanks!
  17. Jan 27, 2012 at 9:01 PM
    #197
    codyb1
    Cody
    Utah
    2015 TRD Sport DCLB
    Count me in on the order!! Thanks Chase!
  18. Jan 27, 2012 at 10:46 PM
    #198
    black_hawk8888
    black_hawk8888 Member
    Not sure if Chase is taking orders via the forum but if there is a list going, please put me on it!
  19. Jan 27, 2012 at 11:03 PM
    #199
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    Chase is the man! Thanks for fixing Toyota's problem. I don't know who you are, but you're now on my Christmas list.
  20. Jan 28, 2012 at 3:03 PM
    #200
    Hard
    Hard Well-Known Member
    H
    4X4X4
    Put me on the list if there is one. Thanks for putting in the effort.
