OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Dec 30, 2014 at 2:26 PM
    #2081
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    The dealer confirmed the issue was the front diff with the chassis ears, and the fluid change did nothing. They are ordering a new carrier and diff, as well as a driver's side axle since the original showed some wear. He said it was $2600 in parts, plus a full day of labor...all under warranty. He agrees that this may not resolve anything, but that's what Toyota is telling him to do for now. At least we're on the same page, and everything is documented. He couldn't say for sure, but he got the impression from the service support folks at Toyota that a fix is in the works. Hopefully I won't have to go through several diffs before they start using the ECGS bushing or their own in-house solution. Warranty claims cost money, so hopefully that will get their attention.
    The truck will go back for the swap next week. More to follow...
    Have a Happy and Safe New Year!
  2. Dec 30, 2014 at 3:31 PM
    #2082
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Spend 60 bucks... have them put the ECGS in the brand new diff and never have to go back to the dealer again..... as the design from toyota has not changed!
  3. Dec 30, 2014 at 3:36 PM
    #2083
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Dealer offered to put a new diff in mine, (extended warranty) but agreed the problem would likely come back.
    My time was worth more to me, ordered the ECGS solution and its done in one step.
  4. Jan 2, 2015 at 8:53 PM
    #2084
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    Which way do you install the ECGS bushing ? it looks like the bushing is different on either end
  5. Jan 3, 2015 at 6:23 AM
    #2085
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Can't remember, watch the ECGS video, pretty sure its on there.
  6. Jan 3, 2015 at 6:24 AM
    #2086
    MTopp
    05 SR5 4x4
    In other news, I'm getting my frame replaced, should I do the ECGS bushing before it or after? I don't want it to get screwed up by the dealer.
  7. Jan 3, 2015 at 6:32 AM
    #2087
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    I think 1side has steel on it thats the side you tap on when putting the bushing in
  8. Jan 3, 2015 at 7:10 AM
    #2088
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  9. Jan 11, 2015 at 6:55 AM
    #2089
    303tacoma
    Rebecca
    Had the bushing done yesterday glad to report vibe free..:D
  10. Jan 11, 2015 at 8:17 AM
    #2090
    codyb1
    codyb1 Well-Known Member
    Cody
    Utah
    2015 TRD Sport DCLB
    Toytec Boss Coilovers set at 3" with AAL's,Toytec Boss Rear shocks, LR UCA's, Swaybar Relocate, Diff Drop, 265/70 Nitto Trail Grapplers, 17" KMC wheels, K&N, Limo Tint, 4.7" Shorty Antenna
    Well i was hoping i would never have to come back to this thread (I was in on the first batch of bushings that chase sent out).. Sold my 2011 and bought a 2015. 3" lift went on with less than a 150 miles. Dealer did install the lift and so they lift will be covered in my 7 year/75,000 mile warranty. But honestly i don't think i will even waste my time trying to get the Toyota dealership to understand what is happening again. I was going to just order the bushing and get it over with but i decided to wait and see how long tell i get vibes. I currently have a little over a 1,000 miles and nothing, i will keep you guys up to date when i start to feel anything. Crossing my fingers i never feel anything.
  11. Jan 11, 2015 at 8:48 AM
    #2091
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    I would say you have a 50/50 chance. Mine started about 1k after my lift with 15k on the odometer. Good luck
  12. Jan 11, 2015 at 1:00 PM
    #2092
    SolarNut
    SolarNut Thin Wallet (TW) member
    2014 Toyota Tacome TRD Off Road
    he can definitely have more than one truck. LOL Mods are at $10084 and going ...
    I currently have no vibrations at 9000 miles on a new truck. This spring I am about to lift 3" the rear (Allpro Expedition springs + 2.0 Rear Fox Shox IFP, Non Reservoir - w/2-3" lift) and 2-3" the front (FOX 2.5" Non-Reservoir IFP Coil-Overs, 0-3" + All-Pro 4130 Chromoly Upper A-Arms) on my 2014 DCSB OR. I will replace the needle bearing with the ECGS bushing at the same time just to avoid future vibration issues. Question is:
    Does anyone have the needle bearing removal and bushing install tools laying around to sell at a good price? I am on the East coast in CT. PM me please. Thank you.
  13. Jan 11, 2015 at 2:52 PM
    #2093
    NicNac
    NicNac Well-Known Member
    Southern Dakota Territoy
    11 DCLB TRD Sport
    Fixed mine today. Problem solved.
    Big props to ECGS and Chase.
  14. Jan 11, 2015 at 3:42 PM
    #2094
    06TXED
    Tony
    Aurora CO
    Same here very happy about the result and the crew at ECGS !
  15. Jan 11, 2015 at 7:10 PM
    #2095
    dglove
    dglove Weekend Warrior
    Dan
    Denver, Colorado
    2013 TRD Sport 4x4 DCSB - Nautical Blue
    Toytec Boss 3" lift (LR UCA's, OME Dakars), FJ Trail team wheels, Duratracs, BAMF sliders, Camper shell, sleeping platform, Weathertecs, Pop n Lock
    I'll have the removal and install tools available in a week or so, will sell both for a total of $60 shipped. PM me if you want em.
  16. Jan 12, 2015 at 3:51 PM
    #2096
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    i gonna get a new diff and axle for my 2010 taco under warranty with my lift kit installed.
    if the vib comes back im gonna order the bushing. a guy at my work said my vib is cause the lift and diff drop. but i had the vib before i installed my lift and new leafs
  17. Jan 12, 2015 at 4:26 PM
    #2097
    codyb1
    Cody
    Utah
    2015 TRD Sport DCLB
    We can all say "yes" to the lift but I'm not too sure why the dif drop kit would help cause the vib... If that's what you meant by it?
  18. Jan 12, 2015 at 7:42 PM
    #2098
    Blacktaco2042
    wisconsin
    he said say it rotates the axle and less oil or something dumb like that.
    toyota FTS looked at my truck and told me the lift kit had nothing to do with it. they have had many complaints bout this problem. theres a tsb for the 4runner with this vib issue. and the tsb says r&r diff and axle and it has a new part number so maybe they changed something. ill keep yall updated
  19. Jan 13, 2015 at 5:17 AM
    #2099
    PaulK
    Paul
    Pittsburgh, PA
    Does anyone have a copy or link to the above 4Runner TSB front diff vibration issue? Are the diffs/carriers the same?
    My Baja is at the dealer now getting its first replacement diff, carrier, and DS axle. My dealer is being cool about the situation, and we both understand that this will likely not be a permanent fix for the problem. We're hoping that Toyota will come up with something, and I'm holding out for a factory fix for a little while longer. The TSB might be helpful to them. And yes, I know the ECGS bushing would resolve the issue, but I want to keep it all Toyota while it's under warranty.
  20. Jan 13, 2015 at 10:37 AM
    #2100
    Blacktaco2042
    wisconsin
    when i get back to work ill email it to myself and post it.
    i replaced a 4runner diff and axle and took it apart and looks the same as a taco. im the same way i wanna keep my toyota toytota till the warrantys are done then ill do the bushing. wonder how long the new diff will last? you lifted?
