OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jan 28, 2012 at 5:19 PM
    #201
    Underpressure
    Underpressure INJECTION IS NICE BUT I'D RATHER BE BLOWN
    Jim
    Iowa
    07 TRD Sport
    5100's set at 2.5 in. , 2 in. AAL, CBI hidden front hitch, 2 Ramsey 8000LBS. winches, ECGS front diff bushing, TRD supercharger, TRD boost gauge, URD headers, URD pulley, T-stat, fuel pump, Methanol Injection system, "Coupe" custom TRD CAI cover, 2 PLX A/F gauges, PLX AIT and Oil pressure gauges, Autometer Pro Comp fuel pressure and Trans. temp gauges, custom built transmission and shift kit, NST overdrive SC pulley kit, TRD Ivan Stewart wheels with Firestone M/T tires, ARB compressor, front and rear lockers, more in time.
    Thanks Chase for all you have done for everyone here!!!!
    Please put me down for 2 bushings.
  2. Jan 28, 2012 at 5:20 PM
    #202
    IslandBoy86
    IslandBoy86 Well-Known Member
    Las Vegas, NV
    Put me down for a bushing please!
  3. Jan 30, 2012 at 9:53 PM
    #203
    tacobronco
    tacobronco New Member
    Just out of curosity, what is the material of the replacement bushing? Is it something soft like PTFE, or is it an impregnated rigid bronze?
    Thanks
  4. Jan 30, 2012 at 10:03 PM
    #204
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    So after reading through this I have came to two conclusions the bronze bushing will fix the problem or an ARB air locker will fix it as well... Am I correct?
  5. Jan 31, 2012 at 8:47 AM
    #205
    Eldo
    Eldo Well-Known Member
    Calgary
    TRDoffroad Double Cab
    a few
    I would also like to be "on the list" for a bushing.
    If it matters, I can install w/ a review / pics if needed.
  6. Jan 31, 2012 at 10:05 AM
    #206
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I've always wondered why my driver side shaft had so much play in it. Now i know! Mine doesn't cause any vibrations though but i am not lifted.
  7. Jan 31, 2012 at 10:06 AM
    #207
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Put me on the list
  8. Jan 31, 2012 at 6:58 PM
    #208
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    So you had the lift on when they warrantied your diff?
  9. Jan 31, 2012 at 7:00 PM
    #209
    tacomtn
    These next two weeks will be long. It seems each day, the growling is getting worse. I'm afraid to open it up and see what's going on in there. I'll likely need a new CV axle too I'm guessing.
    You boys doing this fix, are you going with a factory CV or aftermarket? I know the factory one is going to be ridiculously expensive. There's a Group Buy on now for aftermarket CVs. I'm hoping those will be okay to use.
  10. Jan 31, 2012 at 8:03 PM
    #210
    clcoyle
    clcoyle Well-Known Member
  11. Jan 31, 2012 at 8:59 PM
    #211
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Tacmtn, go aftermarket. OEM is around $400+! Even the parts guys at my dealership said to go aftermarket.
  12. Jan 31, 2012 at 9:36 PM
    #212
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Im in for one. Had this mess since I lifted the truck at 30k... 86k miles now. I think ill need a new CV :eek:
  13. Feb 1, 2012 at 8:06 AM
    #213
    pintokiller79
    pintokiller79 Member
    Kyle
    Dallas, GA
    TRD Sport 4x4 6speed
    Box Stock right now
    i too would like to make the list, good job Chase!
  14. Feb 1, 2012 at 11:06 AM
    #214
    KColoTaco
    KColoTaco Well-Known Member
    Kevin
    N. Colorado
    08 TRD O/R DC
    3 inch OME complete lift, Light racing UCA's, Bed comp. locks.
    Hey just wanted to post a little response to all the current progression of the aftermarket fix. Definitly glad to hear Chase ans ESGS are going to start turning some bushings.
    I did alot of posting on the old thread that was deleted when I tore my front diff down a while back. After seeing that the spiders support most of the CV wieght and mothion I'm glad there will be a way to thighten up the 'actual' load support.
    Chase - If there is a list I'd love to be on it, or another way to purchase. If not I understand somthing like this may take a while.
    Thanks again for everybody's ongoing interest. If I can help let me know.
    Kevin
  15. Feb 1, 2012 at 4:53 PM
    #215
    Skadumz
    Skadumz Well-Known Member
    Lehigh Valley, PA
    2008 tacoma dual cab, long bed, 4x4, TRD Spor
    3" lift 265/70/17 nitto, Grille Craft Grille, Tinted windows, 17x9 Moto Metals Matte Black, Carrier barring drop
    just read all of this great info. I am glad to hear and man from somewhere is smarter then TOYOTA and is able to fix this problem. I have had this problem for since I bought my tacoma. 2008 Double cab 4x4, 3 inch lift. Have gone round and round with two different dealers and they just blame it on the tires and lift before they even LOOK at it.
    THANK YOU CHASE FOR SHUTTING UP MY TACOMAS FRONT END>
    oh and i would like to be on the list too.
  16. Feb 1, 2012 at 7:56 PM
    #216
    mdw5
    mdw5 Member
    Mitch
    Clovis, NM
    2010 Double-cab Tacoma 4x4
    3" Toytec Lift, Westin Bull and Nerf Bars, 285/75 x 16" BFG's, 2008 FJ Cruiser TRD Alloy wheels
    tacomtn; yes I had the lift on when they worked on the front end. I had checked before I installed the lift to make sure it would not void the warranty. For this particular dealership to pursue fixing the vibe again in the future, they would want me to prove to them that the problem is not due to the lift, by removing the lift and demonstrating that the vibe is still there.
  17. Feb 1, 2012 at 8:56 PM
    #217
    tacomtn
    That is one of the few dealerships that covered with a lift already on. As soon as they saw the lift, mine said no go.
    To remove the lift and verify vibe/no vibe, that's a lot of trouble and work. I think most of want to keep the lift. For myself, that was the whole point of getting this truck.
    Hopefully, Chase gets back to us soon. The line is getting long for his bearing.
  18. Feb 1, 2012 at 10:03 PM
    #218
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    does anyone know if it is just the drivers side bushing being made or will the passenger side need one as well?
  19. Feb 1, 2012 at 10:25 PM
    #219
    tacomtn
    Driver's side only.
  20. Feb 1, 2012 at 10:28 PM
    #220
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    cool thanks
