OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Mar 24, 2015 at 7:48 AM
    #2241
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I lifted at around the same mikes as that's when I bought it at. I never noticed any vibes or grinding but the CV Axel had a ton of play in it at the diff side, so I decided it need to be done. I installed it at about 105000 mikes and replaced the Axel as well. There was pretty deep groves from the needle bearing. Now thee is almost no play that makes me feel better, just knowing there is no play.
  2. Mar 24, 2015 at 7:49 AM
    #2242
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Shipped to offroadwonder, please pay it forward, when your done.
  3. Mar 24, 2015 at 9:08 AM
    #2243
    NWONTaco
    NWONTaco Well-Known Member
    Tony
    Thunder Bay Ontario
    2006 TRD crew cab V6 4x4
    265/70/R17
    Anyone have a 8" needle bearing puller for sale?
  4. Mar 24, 2015 at 10:29 AM
    #2244
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    So the guys with CV having a play and vibe? What mileage that happen at, anybody with that problem from factory ?
    I am wondering if people are driving with not enough gear oil in front differential and riding that idle bearing dry.
    I have to say I had been checking mine but at almost 90k miles my CV has 0 play.
    But I changed my gear oil at 12000 miles and overfilled front diff by alot, so I know my needle bearing (likes it or not) is always running in the oil bath.
  5. Mar 24, 2015 at 11:09 AM
    #2245
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    I can't remember what the mileage was when I first noticed it, but it was probably around 15k.
    I had taken the stock skid of and was crawling around under the truck just checking things out. For some reason I pushed on up on both the CV's where they exit the diff. Noticed the drivers side had way more play than the passenger.
    Seems like the next time I drove I started noticing a low key vibration intermittently. Searched here on TW and found a thread about this issue. Took it out and performed the four wheel drive test. I have had the issue pegged ever since, but it never got worse. So I didn't bother with the fix.
    Jumped to the lift install a few weeks ago. Figured I would do the lift and see if it got worse as some people seem to never have the problem, and my vibe wasn't bad. Well now it has gotten worse and it is time.
    I will be ordering the parts and pieces today and hopefully have them to do the install this weekend or early next week. Should have just done it when I did the lift.
  6. Mar 24, 2015 at 5:54 PM
    #2246
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    It was before we even knew for sure the bearing could be removed from outside. One (and I mean that literally) person had said they had done it but he never replied back to questions. So Toyota split the cost with me 50/50. If only I had waited another year. That's when we (TW) started investigating changing it from outside. A year and a half later, I ended up changing the needle bearing. There are picture in either this thread or the original front diff thread (no, this is not the original thread. It was created after we solved everything.). So I don't know what the first one looked like. The second bearing looked okay, so I think the noise was the axle. It was scored horribly. That's why I say be prepared to replace the axle too.
  7. Mar 24, 2015 at 8:06 PM
    #2247
    Hartford
    Maine
    2011 Acc Cab 5spd
    Thank you Moose.
  8. Mar 25, 2015 at 6:45 AM
    #2248
    Wpg07TRD
    Wpg07TRD Canadian Member
    Neal
    Winnipeg
    '07 TRD Sport, DCLB
    5100s and 885x coils, Trail Gear Add-A-Leafs/5125s, interior light LED swap, rcbs204 illuminated 4x4 switch
    PM sent..
  9. Mar 25, 2015 at 9:24 AM
    #2249
    Hartford
    Maine
    2011 Acc Cab 5spd
  10. Mar 25, 2015 at 1:56 PM
    #2250
    Pigpen
    Dan
    Northwest Montana
  11. Mar 26, 2015 at 5:31 AM
    #2251
    mpslaney
    mpslaney New Member
    New Brunswick, Canada
    10 Tacoma TRD Sport
    K&N Air Filter
    I had my 2010 tacoma leveled for a while and had the grumble noise, I was just wondering with out reading through 114 pages of comments if the issue still exists if you lift it rather than level it?
  12. Mar 26, 2015 at 5:34 AM
    #2252
    Hartford
    Maine
    2011 Acc Cab 5spd
    It would still be there.
  13. Mar 26, 2015 at 6:23 AM
    #2253
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    This ^^^
    doesn't matter if you even lift it. You could put new OEM suspension on if it was worn out and it could vibe. It could vibe after 50k miles with no lift, that's rare, but it can happen.
  14. Mar 29, 2015 at 1:40 PM
    #2254
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Just installed the replacement bushing sent by ECGS. The one I removed had the outside edge flared slightly and the inside had a score mark around the inside, so that's where my vibes were coming from again. Don't know if the first one was installed incorrectly or the CV caused the flare. Either way, vibes gone again. Let's see if this one holds tough.
  15. Mar 29, 2015 at 3:20 PM
    #2255
    Himynameisnick
    Himynameisnick 'Murica
    Nick
    Denver, CO
    07 White DCSB Sport
    Unfortunately need to do this...
    Going to go with the ECGS Bearing, but dont see the reasoning for $60 price tag on the removal tool. If anyone has one to give or for sale please PM me.
  16. Apr 1, 2015 at 9:17 AM
    #2256
    MTopp
    05 SR5 4x4
    Bump, I bought a used tool here too
  17. Apr 1, 2015 at 2:00 PM
    #2257
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    I just ordered a bushing and removal tool etc. Suspension is ordered so I figured even with less than 1000 miles I would just knock this out now.
  18. Apr 1, 2015 at 6:06 PM
    #2258
    MTopp
    05 SR5 4x4
    Good idea. Before the CV gets ruined
  19. Apr 1, 2015 at 6:17 PM
    #2259
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    you will be glad you did it when you already have the front suspension torn down. better than doing it 100 miles later like I did.
  20. Apr 2, 2015 at 8:15 AM
    #2260
    Aueehonda
    Aueehonda Member
    Jay
    Alabama
    13 trd sport dcsb 4x4
    2" AAL, billy 5100's set at 1.75" on front, body armor rear bumper
    looking at doing the ECGS Bushing install sometime soon, anyone in North Alabama (Huntsville area) done this? Free Beer on the table for anyone willing to give advice/ assistance. shoot me a PM if interested.......
