OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Apr 13, 2015 at 7:34 PM
    #2281
    blacksandtaco
    blacksandtaco Well-Known Member
    Tyler
    Kansas
    07 Access TRD Sport 4X4
    Viper remote start/alarm, Kenwood Excelon DNX 9140 in -dash Nav and DVD, Anzo black headlight, FoldaCover tonneau cover, BedRug carpeted truck bed, Pop-A-Lock electric tailgate lock, Level 8 MK6 (16x8), Toyo Open Country AT2 (LT265/75R16), Fold-A-Cover Tonneau, Bilstein 5100s front, Rear Leaf Suspension TSB, AVS in-channel front window vents, AVS Aeroskin hood protector,
    My eyes are bleeding from reading the first 50 pages of this thread but I'm glad I did. Thanks for all the info.
    Replaced the front shocks with 5100's at 1.75 to level out the rear leaf TSB at a local shop over the weekend and sure enough, vibrations between 30-40 mph not less than 100 miles after the shocks were installed. Goes away when I put it in 4H.
    Checked out ECGS website and will be picking up the 8" bushing and axle seal but curious if I should replace anything else while I'm at it given the high mileage on my truck. Good thing is I haven't been riding with the 5100s long but who knows what other wear and tear might exist.
    I'm no mechanic and the closest thing I've done on my truck myself is replace the front brake pads :confused:. Anyone have any suggestions on how to tell if I should replace anything else while I'm replacing the bushing?
    Like 4mytaco, I'd be willing to pass on the removal tool to the next guy if anyone is up for donating.
    Greatly appreciate any and all suggestions. Thanks in advance.
  2. Apr 13, 2015 at 10:43 PM
    #2282
    BenTheMan
    BenTheMan Well-Known Member
    Ben
    Portland
    2012 TRD Sport 4x4 AC
    Truck Nutz
    I installed an OME 3" lift this last weekend and immediately got the vibes. I have an alignment scheduled for Wednesday. I won't be able to do the bushing install for a couple weeks. Will I have to get an alignment again after it's installed?
  3. Apr 14, 2015 at 1:18 PM
    #2283
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    No you will not have to re-align your truck after the bushing install.
  4. Apr 14, 2015 at 2:06 PM
    #2284
    rsj78
    rsj78 Well-Known Member
    Scott
    Virginia
    2012 Tacoma TRD Sport 4WD
    Bilstein 6112's, Icon progressive AAL, Specialty Products Upper Control Arms, TRD Catback, Alpine head unit, Husky Liners mats, AVS in-channel visors, Husky Liner Mud Guards, Bullaculla Trailer harness Relocate Bracket, TRD shift knob
    Gotcha! Now I imagine the entire axle has to be removed and you can't get by with just removing from the diff, correct?
  5. Apr 14, 2015 at 2:14 PM
    #2285
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    I don't understand the trouble some of you guys are having with removing the CV from the diff. A small pry bar into the gap between the CV and the diff housing and thump it. Pops right out. No sledge and cable, no slide hammers. Takes 10 sec. Pry toward the center of the truck, pushing the CV out. If you pry out toward the hub, you may damage the diff oil seal.
  6. Apr 14, 2015 at 2:16 PM
    #2286
    MTopp
    MTopp Professional bear handler
    North NJ
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    X2
  7. Apr 14, 2015 at 4:29 PM
    #2287
    2012SilverSport
    Guam
    That was how I made my first attempt at removing my cv axle. I even had a buddy help me and we had a pry bar on both sides for an even pull with no luck. I Had to resort to the slide hammer which actually worked well for me. A couple of knocks and it popped right out. Guess we all can't be as lucky. :rolleyes:
  8. Apr 14, 2015 at 4:44 PM
    #2288
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Maybe my disregard to changing the C clip every time I removed the CV has somethng to do with it?
  9. Apr 14, 2015 at 4:52 PM
    #2289
    MTopp
    North NJ
    05 SR5 4x4
    Where is this c clip you speak of? I may try the slide hammer idk yet. Can I do it without renting a tool?
  10. Apr 14, 2015 at 5:03 PM
    #2290
    manethon
    manethon TTAS
    Toronto
    Many
    pry bar it, easy, safe and fast.
  11. Apr 14, 2015 at 5:25 PM
    #2291
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    The retainer clip/ring on the end of the shaft that goes into the diff. What tool would you rent?
  12. Apr 14, 2015 at 6:33 PM
    #2292
    bark beetle
    bark beetle Member
    NM
    13 Leased D Cab Taco
    Full custom skids, Front receiver, Bull bar, Allpro Springs, TC UCA Fox coilovers/bypass shocks, bumps, flatbed, so it begins
    Tried multiple ways with pry bars for a couple of hours, mini sledge on prybar, etc ........ all failed Glad you didn't have the trouble I did.
  13. Apr 14, 2015 at 6:48 PM
    #2293
    MTopp
    North NJ
    05 SR5 4x4
    The slide hammer thing. I guess I could use the wire and sledge method too
  14. Apr 14, 2015 at 7:28 PM
    #2294
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Exactly! When I changed out my needle bearing for another needle bearing (pre ECGS fix), jberry813 helped me out because I couldn't get it. He tried and tried and tried. It took a ton of pounding and a helluva lot of swearing before it finally came out (the latter probably made the difference :lol: ). Anyone that knows Jason's work will realize it must have been a real bit&& to remove. Now popping the new axle in was a breeze.
  15. Apr 14, 2015 at 7:46 PM
    #2295
    MTopp
    North NJ
    05 SR5 4x4
    Lol sheeiiiiitttt. How'd y'all remove it in the end? What method?
  16. Apr 14, 2015 at 8:36 PM
    #2296
    05Moose
    Jim
    Pounding on the pry bar with a BFH. The dust shield on it was all bent to hell, but I was able to mostly straighten it. If I ever have to replace the latest needle bearing with the bushing, I'll use a slide hammer with the hose clamp method.
  17. Apr 15, 2015 at 5:57 AM
    #2297
    MilesToEmpty
    MilesToEmpty Well-Known Member
    Charles
    Frederick Co, MD
    '13 Baja TX
    Wheelers Progressive AAL, Firestone RideRite airbags.
    Just wanted to post that I just had my front diff bearings replaced (due to the vibrations) under warranty at Toyota. My truck is a stock TX Baja with 23k miles. They ended up replacing my driver side axle as well as the teeth on it were in bad shape or something... dont have the paperwork with me at the moment.
  18. Apr 15, 2015 at 6:09 AM
    #2298
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    Ok , I'm confused ...
    How is some say the front has to be re-aligned ? If you pull the bottom 2 bolts that hold the lower ball joint the settings on the front should not change when assembled together ?
    Sarge
  19. Apr 15, 2015 at 7:52 AM
    #2299
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Beng overly cautious? I have had mine apart 3 or 4 times now with struts, springs, boot replacements and what-not, alignment still fine.
  20. Apr 15, 2015 at 5:29 PM
    #2300
    2012SilverSport
    Guam
    unless you remove your lower control arm, loosen your caster bolts, adjust your coilovers, etc your alignment will not change.
