OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Apr 16, 2015 at 6:14 PM
    #2301
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    OK, I've read through more threads than I can count but I'm stumped.
    2014 DCSB 6sp TRDOR 9000 miles, with an Icon Stage 1 lift set at just under 3" of front lift. Wheels and tires are OEM. I had a very good shop do a 4 wheel alignment after the lift and the numbers look good.
    Since installation I've had a rumble at 20 mph that can be heard and felt, and an oscillating hum at 40 mph- about 4 seconds of hum then 4 seconds of no hum. There is also a high pitched ringing sound right around 25 mph.
    The 20 mph vibe has gotten better as I've dropped the CB. First I installed an OME drop kit, then added washers one at a time. With each 1/4" the rumble lessened. I got to over 1" of drop, ran out of bolt length. I also installed a Toytec front diff drop, which had no effect on any of these issues.
    I then installed 3 degree axle shims, and the 40 mph oscillation got a little better.
    Then I installed the Streetacos CB drop, which put it at 1.5" of drop. The 20 mph vibe is much less but still there. It had no effect on the 40 mph oscillation or the ringing.
    The 20 mph vibe and the ringing remain in 2WD and 4WD, but the 40 mph oscillation happens only in 2WD.
    So... where to go from here? I can live with the vibes and ringing if it's not damaging anything. I looked at the ECGS bushing but there's no way mine could be worn out.
  2. Apr 16, 2015 at 7:18 PM
    #2302
    4myTaco
    4myTaco SmaSh it Up
    Lucas
    Plainfield, IL
    06 DCLB Sport
    OME 3" lift up Front, LR UCA's, All-Pro Expo leafs in back, 17" XD Addicts with 285/70/17s, OEM Roof Rack, Westin Light Bar, Relentless Tailgate plate, Weathertech's, Blue Sea Fuse Box, Iggy's Switch Holder, Pioneer avh-3300bt Radio, LED Interior/License Plate Lights
    From what I understand, the vibration that is caused by the needle bearing doesn't necessarily have to do with it being warn out, but more with the length of the bearing. The only way to see if that is your issue is to put it in 4wd and drive and see if the vibration is gone. If it is gone, the sleeve will fix it, if the vibes are still there it is another issue.
  3. Apr 17, 2015 at 5:23 AM
    #2303
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Try the ECGS bushing and 3° axle shims with no cb drop.
    But you may be in for a fight on the ringing. Did it only occur after the lift? Does it happen only at certain speeds? Where does it sound to be coming from?
  4. Apr 17, 2015 at 8:18 AM
    #2304
    skootx
    Erie, CO
    Yes, the 40 mph vibe does go away in 4WD but not the 20 mph vibe.
    The ringing happens around 20-30 mph, in both 2 and 4WD. Seems to be coming from the front right.
  5. Apr 17, 2015 at 11:11 AM
    #2305
    blacksandtaco
    blacksandtaco Well-Known Member
    Has anyone had any success at all with the differential drop? Seems like there have been mixed feelings and most have not been able to get rid of the vibration caused by the needle bearing design with the diff drop alone. Recently purchased the ECGS bushing and removal tool but wondered if would also be a good idea to apply the diff drop along with the bushing.
  6. Apr 17, 2015 at 12:35 PM
    #2306
    skootx
    Erie, CO
    The diff drop made no difference at all for me, I get the vibes with and without it. Personally, I installed it to ease the angle on the CVs.
  7. Apr 17, 2015 at 1:40 PM
    #2307
    MTopp
    05 SR5 4x4
    Differential drops do NOTHING on second gens except rotate the diff. Doesn't help angle significantly. Also, if you have a diff drop, do not go offroad because your diff is now more exposed and the mounts have broken before on a members rig here.
  8. Apr 17, 2015 at 1:40 PM
    #2308
    MTopp
    05 SR5 4x4
    PM'd
  9. Apr 17, 2015 at 8:35 PM
    #2309
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Wanted to post this here as well. It's from the cheap oem axle thread.
    Also If anyone wants a removal tool for the needle bearing I will gladly send mine out. I just have one stipulation, it won't be sent if you don't agree to this, and that is I want it back when you are done. I may need this tool again and I also want to make sure it is available to send to others. I will pay shipping to you and expect you to pay shipping back. Hope that sounds fair. I will be traveling in the truck for the next few months and I don't have an internet phone so it may be a few days to a week between check ins with the computer. I will try to be prompt.
  10. Apr 18, 2015 at 6:08 AM
    #2310
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    Got mine done yesterday , bearing was a bit of a pain but it worked out . No axle shaft damage yet , just polished where the bearing rode on it . Bearing was amazingly sloppy , way tighter with the new bushing .
    Thanks to ECGS for doing this .
    Thanks to Toyota for crappy engineering and letting Corporate profit margins cheapen an otherwise potentially great truck - I'm looking to get rid of it after seeing how it's built .
    Vibes gone at least , 32,520 miles on the clock , wow .
    Sarge
  11. Apr 18, 2015 at 6:43 AM
    #2311
    MTopp
    05 SR5 4x4
    Haha, I agree. Stupid design, but every truck had flaws, you'll sell the tacoma and get another truck with a whole new set of problems that don't have near as many solutions available like the tacoma does
  12. Apr 18, 2015 at 6:48 AM
    #2312
    WeberSarge
    Kevin
    Ohio, Illinois
    Stock for now...
    I'm headed late 70's to early 90's Dodge w/big block - not exactly the same mileage on the highway but you can't break them , either . I see a whole new movement of guys rebuilding older domestic trucks with new crate engines , ect - not a bad idea and some have gotten pretty decent fuel mileage even on 3/4 ton trucks . Problem is finding a good extended cab - they are pretty rare .
    Wonder if there has been anyone that's tried to adapt the older IFS gear housing into a 2nd Gen Taco , such as '86 and up Mini trucks ?
    Sarge
  13. Apr 18, 2015 at 6:51 AM
    #2313
    MTopp
    05 SR5 4x4
    Ah, I see. That'd be a good way to go, but many older trucks I see have rust rot everywhere, so kind of a restoration job.
    I have never heard of a front diff transplant on a second gen. There have been some SAS done though
  14. Apr 22, 2015 at 9:56 AM
    #2314
    ECGS
    ECGS Well-Known Member
    Chase
    RALEIGH
    · All bushings are for the driver’s side of vehicle only. The passenger side uses a ball bearing that normally does not go bad.
    · If you have a vibration and put the vehicle in 4wd and it goes away you likely have a bad needle bearing and need the bushing.
    · Most symptoms exude themselves once the vehicle has been lifted past stock
    · The stock needle bearing was never designed for side load, once the vehicle is lifted this puts side load on the needle bearing causing it to fail
    · 96-04 Tacoma, 02 and older 4runner, 2000-2006 Tundra are 7.5” differentials
    · 05 and newer Tacoma, 03 and newer 4runner, 07 and newer FJ Cruiser are 8” differentials
    · 07 and newer Tundra are 9” differentials
    · Works on all current Tacoma, 4runner and FJ Cruiser models
    · The bushing does not fit AWD (Non-Selectable 4wd) differentials in 4runners and FJ Cruiser’s
    · The bushing does not fit 7.5” manual hub vehicles
    · We have sold over 1300 8” bushings and over 100 7.5” bushings since their introduction with great success
    · The life expectancy of the bushing is 500,000 miles
    · We recommend 85w140 Non-Synthetic Lucas differential oil
    Question: Do I need to replace my CV axle when I replace the needle bearing?
    Answer: No, unless your CV joint is damaged or pitted upon removal.
    Question: How far do I drive in the bushing?
    Answer: Flush with the carrier
    Question: What side of the bushing goes into the differential?
    Answer: Install replacement bushing with steel face out. The steel face protects the bushing while it is being driven in
    Question: Do I need the axle seal?
    Answer: We recommend replacing the seal as they are generally damaged upon removal. We use OE Toyota seals like used from the factory.
    Question: How hard is the bushing to replace?
    Answer: If you can replace a CV joint you can easily replace the bushing
    http://eastcoastgearsupply.com/c-1025774-toyota-clamshell-bushings.html
  15. Apr 22, 2015 at 11:36 AM
    #2315
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Hey Ben, can you (or a moderator) add a link in your first post on this thread pointing to Chase's post above? I'm sure that would be helpful for new people visiting this thread.
  16. Apr 23, 2015 at 9:03 AM
    #2316
    rsj78
    rsj78 Well-Known Member
    Scott
    Virginia
    2012 Tacoma TRD Sport 4WD
    Bilstein 6112's, Icon progressive AAL, Specialty Products Upper Control Arms, TRD Catback, Alpine head unit, Husky Liners mats, AVS in-channel visors, Husky Liner Mud Guards, Bullaculla Trailer harness Relocate Bracket, TRD shift knob
    I don't get why Toyota would use a different type of bearing side to side??
  17. Apr 23, 2015 at 12:51 PM
    #2317
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    The length of the axle tube on each side is different isn't it? That could be it
  18. Apr 24, 2015 at 10:13 AM
    #2318
    Firehots
    Firehots New Member
    jason
    illinois
    2012 dc longbed trd sport 4x4
    BHLM, CLAZZIO SEST COVERS, CARBON FIBER WRAPPED DASH, HEATED SEATS, BILSTEIN 5100S, PROGRESSIVE 1.5AAL, Blacked out emblems, 1.25" wheel spacers
    Anyone have a removal tool that they want to sell? If so shoot me a pm...thanks
  19. Apr 24, 2015 at 11:38 AM
    #2319
    WeberSarge
    Kevin
    Ohio, Illinois
    Stock for now...
    I have a removal tool that could be cycled from person to person that I made - it's just a tig welded pair of grade 8 washers that are cut down to barely fit .
    Sort of a "pay it forward" type of thing if folks want to go that route .
    First one in line would PayPal shipping cost , and so on....I would like it back someday . USPS Priority Mail would run $5.95 ...
    Another thing - mine is totally stock except running LT265/75/16 Toyo ATII's - the vibration showed up at 28K on the clock , bushing fixed the issue completely . I was amazed at how sloppy that stock bearing fit and luckily my axle shaft was not damaged yet . Shame on Toyota for a crap design - they should and do know better .
    On a side note - during the reassembly , I noticed the driver's side upper sway bar link rubber boot is torn pretty badly and the grease is leaking out . Looked it up on ToyoDIY and no love - that is a complete part and not cheap , the boots are not sold separately . Anyone had this issue ? Suppose I could just run it until it eats the joint and replace the link but hate crap like that . My old Suzuki had replacement boots available for the tie rods and such but they are a different size head and won't fit - still actually had one in the tool box , lol....
    Anyone take off a stock sway bar for a lifted offroad truck and have a link for sale ??
    Sarge
  20. Apr 24, 2015 at 11:43 AM
    #2320
    typeone
    typeone Well-Known Member
    central MA
    2013 TRD Off-Road 4x4 DCSB BLACK
    2.75" Rancho QuickLIFT Loaded coilovers, LR UCAs, Wheelers 1/4" poly top plate spacers, FBG diff drop, Toytec swaybar relocate, Wheelers 2" AAL, LRO 1" tapered blocks, RCD Bilstein 5100 rear shocks, OME carrier bearing drop, OEM roof rack, Access Literider tonneau, SCS Stealth 6 wheels, 285/70r17 Nitto Terra Grappler G2 tires
    EDIT: Sold.
