OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Apr 24, 2015 at 7:27 PM
    #2321
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Better aftermarket (moog) greasable sway bar link is $30 each. Nongreasable is less.
  2. Apr 25, 2015 at 9:36 AM
    #2322
    Taco Diver
    Taco Diver Active Member
    Josh
    FW,TX
    06 BSP Sport DCSB
    Fox 2.0, Icon AAL, All Pro IFS Skid & U bolt flip kit, dash light mod, Grillcraft grill, rear diff breather mod, ECGS bushing install, SCS Stealth 6 Gunmetal with Falken SL 265/70-17
    I installed the bushing in my truck yesterday and now the 30-40 mph grinding feel and vibes are totally gone. I thought I may have waited too long to do the install and was worried that I may have some scoring in the CV shaft but it turned out to be pretty smooth and definitely reusable... kind of surprised me for having almost 99K miles on the truck.
    For the axle removal I used the slide hammer and hose clamp technique. One note of caution if you use the slide hammer is be careful with the CV boot. I used the 3 claw attachment with one claw attached and it was wanting to push into the boot. So, I just pushed the boot in as much as I could to minimize any sharp edges pushing on it. Pretty much self explanatory.
    For the bearing removal I had to chamfer the back edges of the small piece of the removal tool so it would slide into place. I just used a dremel with a grinder attachment.... easy enough to modify and worked perfectly.
    For install of the ECGS bushing I used the removal tool and reassembled it with 2 sockets (one to fit inside the bearing and another to press on the edge) and it worked great for keeping the bearing centered while tapping it in.
    To install the CV axle back in I used a long socket extension, putting the female end into the notch on the axle and tapping the male end with a hammer.
    This was the most involved work I've ever done on a vehicle and it took me almost 6 hours to finish. I'm extremely happy with the results of this bushing!
  3. Apr 25, 2015 at 12:43 PM
    #2323
    jasontojo
    jasontojo Well-Known Member
    jason
    west virginia
    SR tacoma 4x4 2.7L
    5100 Bilsteins, Toytec Fr coil lift springs, Deaver AAL packs, Mobtown tailgate reinforcement, Intermittent wiper switch, ECGS Fr Diff bushing
    Thanks ECGS. I bought a 2015 ac 4x4 and just bought a lift kit. I am glad that I did my research and found this. I am going to get this bushing in while I have it torn down, it will take a little longer but hey! I am glad that I spend some time on this forum. :mudding:
  4. Apr 25, 2015 at 8:57 PM
    #2324
    blacksandtaco
    blacksandtaco Well-Known Member
    Thanks guys! Had my mechanic install the ECGS bushing this weekend. Seems to have fixed the issue but now I have a new, smaller, steady and rhythmic rub/vibe in the 22 mph - 25 mph range. Totally different than the vibration prior to the bushing install and definitely was not there before. Anyone else have this?
    Edited: and now I've noticed a harsh ride/rub in the gas pedal and steering wheel in the 65 mph - 75 mph range. I can get it to go away when I turn the wheel slightly to the left. I'm wondering if tightness of the bushing is causing this.
    Seems like I've remedied one problem to create another
  5. Apr 29, 2015 at 5:59 AM
    #2325
    MTopp
    05 SR5 4x4
    I'm not sure. Could be the mechanic didn't install it 100% correct
  6. Apr 29, 2015 at 9:34 AM
    #2326
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    I have that same vibe but without the ECGS bushing. The 20 mph vibe does NOT go away in 4WD for me. I've been gradually lowering the carrier bearing which has gradually improved it. At this point I'm using the Streetacos CB bracket with two fender washers on each side and the vibe is very minimal.
  7. Apr 30, 2015 at 10:27 PM
    #2327
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    When I put my truck into 4HI I experience a constant humming noise that sounds focused towards the front diff on the drivers side, is this a bad sign? Because I'm not totally sure if It's a vibration in the bearings, just seems weird. I have a front diff drop and a OME 90021s in the front with 884s.
  8. May 1, 2015 at 12:25 AM
    #2328
    jasclair
    jasclair Well-Known Member
    joshua
    Bend oregon
    Current: BHLM, plasti dip badges/bumper, Satoshi homer taco style grille, custom TRD, pack rack Marshall fab, window tint,interior paint job, ome lift,wheels spacer, white light interior, retrofit headlights.
    I'm having this issue but it seems to start from passenger side to pedal. Is that normal? It does seem to stop when I put it in 4x4. So I'm assuming it's the same but I keep seeing that it's the driver side that vibrates.
  9. May 1, 2015 at 10:49 AM
    #2329
    skootx
    Erie, CO
    From what I've read, if the vibe does not go away in 4WD, then an ECGS bushing will probably not help. You may want to try a carrier bearing drop- which ranges from adding washers to drop the bracket a bit, to OME's kit which drops it about half an inch, to Streetacos bracket which drops it 1.5." I currently am using the Streetacos kit and 2 fender washers, and most of my vibes have gone away, except for the 40 mph one which DOES go away in 4WD.
  10. May 1, 2015 at 10:56 AM
    #2330
    jasclair
    joshua
    Bend oregon
    Ya I went down there to check it the this morning and my driver side moved slightly but my passenger side doesn't, so it is really tight right there so I might install my drop kit I purchased and see what happens.
  11. May 1, 2015 at 12:59 PM
    #2331
    skootx
    Erie, CO
    Yup, the driver's side is where the ECGS bushing will tighten things up, but that still may not be where your vibes are coming from. I've installed lifts before and have never had this much trouble. What makes it worse is that every truck is different, so there are no magic bullet solutions.
  12. May 1, 2015 at 3:11 PM
    #2332
    300AACTaco
    Alaska
    See mine doesn't start making the noise unless I'm in 4WD which I find to be weird.
  13. May 1, 2015 at 4:07 PM
    #2333
    skootx
    Erie, CO
    Probably totally unrelated, I haven't seen any mention of that and I've scoured the driveline vibe threads. BTW my good friend lived in Eagle River, he drives a blue 96 T100 with boggers that he's selling. He's in Anchorage now I think. Wondered if you know him.
  14. May 1, 2015 at 7:37 PM
    #2334
    phreddyfoo
    phreddyfoo Well-Known Member
    Indiana
    I have a vibe/rumble strip sound coming from my right front at highway speeds when I turn the wheel slightly left??? I have a non lifted 2012 4X4 Tacoma TRD
  15. May 1, 2015 at 8:26 PM
    #2335
    ECGS
    ECGS Well-Known Member
    Chase
    RALEIGH
    If you have noise, vibe, roar and you veer the vehicle and the noise changes or goes away it is tire or wheel bearing noise. When you veer the vehicle it changes the load on the bearing so the pitch of the noise will change or go away. The only time the noise does not change and its a wheel bearing is when the bearing is very bad. Very bad bearings are typically easy to diagnose by running the vehicle on jackstands/lift. Keep in mind the suspension should not be at full during this test or other noises will occur masking the bearing noise.
    If you are only experiencing noise in 4wd I suspect there is something actually wrong inside the diff (pinion bearings most likely however it is rare for these bearings to fail unless the vehicle has been operated in 4wd at higher speeds for extensive mileage). It could also be front driveshaft issues. Also keep in mind these are true 4wd systems that should be only used in low traction conditions. IE when you lock it into 4wd the front and rear are coupled with no slippage so operating them in a full traction system can produce noises.
    Chase@ECGS
  16. May 2, 2015 at 4:53 AM
    #2336
    phreddyfoo
    Indiana
    Thanks for the reply. I figured it was a bearing. Hopefully the CPO coverage I have will pay for that.
  17. May 2, 2015 at 6:55 AM
    #2337
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I'll just add one more diagnosis tip for the driver's front diff bearing in addition to it going away in 4wd. I found it would also disappear in 2wd when doing the typical 40 mph (when it was at its worst) and making a strong right turn because the truck would sink down on the left and straighten the CV angle on the bearing.
  18. May 5, 2015 at 8:08 AM
    #2338
    ECGS
    Chase
    RALEIGH
  19. May 5, 2015 at 7:58 PM
    #2339
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    Alright guys, I follow what's going on in this thread but I didn't read every post, and I have a question.
    I have 65000 miles on my truck, and had a 2.5" lift since ~42,000. Does anyone think that the cv that is in there now is going to need to be replaced when I install the bushing? I would answer my own question and pull it out before I order anything, that way I could order a cv from the cheap OEM cv thread if needed, but that's a lot of work to get "nothing" done. So who thinks that my cv is going to be worn badly?
  20. May 6, 2015 at 5:06 AM
    #2340
    MTopp
    05 SR5 4x4
    I'll hopefully be doing mine soon and I have a decent bit of miles with a similar lift height. I could tell you then what the outcome was for me.
