OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. May 6, 2015 at 8:57 AM
    #2341
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    I had 37k mi on my lift with the vibe and my cv looked perfect. Go back a few pages and see my posts with pics about it. I also have about 2.5" lift. Other then the issue with the seal it was pretty straight forward
  2. May 6, 2015 at 6:01 PM
    #2342
    Pigpen
    Dan
    Northwest Montana
    It could be the diff drop which is causing your problem. The way I understand it, The diff drop angles the diff and the lubricant is no longer able to adequately bathe the gears - wearing the gears and putting undue stress on them. This could explain why you only hear it in 4wd.
  3. May 6, 2015 at 6:31 PM
    #2343
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    Thanks to both of y'all! Hopefully I'll be alright!
  4. May 7, 2015 at 3:11 PM
    #2344
    TRoss
    TRoss Web Wheeler
    NorJoJah
    '12 Reg Cab MGM 4 banger 5spd
    1.5" 5100 Billie lift, 1.5" AAL w/5125's, 265/75/16 Duratracs on SR8's, ECG diff bushing
    I call bs.. Same argument goes for changing the rear pinon angle (up), aint gonna hurt a dang thing as far as carrier and pinion bearings go....its like a blender in there, its gonna get lubed! ...key being properly filled diffs.
  5. May 7, 2015 at 5:26 PM
    #2345
    Pigpen
    Dan
    Northwest Montana
    It wouldn't be the first time I was wrong. I just know there were a bunch of 2nd gen guys who pulled out their diff drop. I have read many suggestions to not put one in a 2nd gen.
  6. May 7, 2015 at 6:19 PM
    #2346
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    I have the diff drop and have no intention of removing it. Anything to help the CV angles is good IMHO. Yeah, shouldn't matter if you rotate the diff, it's still the same amount of oil covering the gears.
  7. May 7, 2015 at 7:00 PM
    #2347
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Differential drops don't do anything on second gens except rotate the differential. Does it help cv angles? Maybe less than an inch no more than that. Does it make it structurally weaker? Yes, just like any spacer type thing whether it be for wheels, lift etc.
    Also, many times the transmissions and differentials have not been filled properly by toyota, kind of crazy, but it has happened many times.
  8. May 8, 2015 at 8:25 AM
    #2348
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I respectfully disagree with the emboldened phrase above.
    My diff drop spacers are larger than the original contact area of the differential mount, and to simplify, causes no stress riser to be created. The diameter for the bolt/screw is also small enough to prevent an unsupported lateral load.
    If the spacer has a smaller contact area, or allows for an unsupported lateral load, then your statement would be correct.
    The situation is different on suspension blocks, as a larger torsional moment is created while there is no increase in contact area, or additional lateral support for the U-bolts.
    You did manage to confuse me with the statement about the fluid levels.
  9. May 8, 2015 at 6:50 PM
    #2349
    MTopp
    05 SR5 4x4
    True, but I believe 2 members have had broken differential mounts from using a drop kit while offroad. If they didn't have the kit it probably wouldn't have happened, but that's all speculation and very rare.
    The fluid thing is literally certain things are not filled properly right off the lot from Toyota
  10. May 12, 2015 at 1:49 PM
    #2350
    jasclair
    jasclair Well-Known Member
    joshua
    Bend oregon
    Current: BHLM, plasti dip badges/bumper, Satoshi homer taco style grille, custom TRD, pack rack Marshall fab, window tint,interior paint job, ome lift,wheels spacer, white light interior, retrofit headlights.
    Anyone have a spare tool they can pass on or sell?
  11. May 14, 2015 at 7:22 AM
    #2351
    iflyils
    iflyils Well-Known Member
    chris
    Wa
    TRD OFFROAD
    HARROP FRONT ELOCKER, ARB BULL BAR, OLDMAN EMU SUSPENSION ARB INTENSITY OFFROAD LIGHTS, WARN 9.5XPS, 32 in BFG MUD TERRAIN KM2, ARE Overland canopy with ARB ROOF RACK Line X premium bedliner
    My 2 cents is since I have installed the Front Elocker I have had Zero Vibration and the benefits of a front locker!
  12. May 14, 2015 at 3:57 PM
    #2352
    MTopp
    05 SR5 4x4
    Lol at double or triple the cost
  13. May 14, 2015 at 5:59 PM
    #2353
    skootx
    Erie, CO
    SAS would fix the problem real good.
  14. May 15, 2015 at 5:16 AM
    #2354
    MTopp
    05 SR5 4x4
    That too
  15. May 15, 2015 at 10:19 PM
    #2355
    jasclair
    joshua
    Bend oregon
    How long does it take to to replace the needle bearing with product? And do you need the install tool?
  16. May 16, 2015 at 5:44 AM
    #2356
    jace1905
    jace1905 Active Member
    james
    East Tennessee
    2020 Tacoma 4 dr TRD off road
    Bilstein 5100s Method 305 wheels 17x8
    Just installed lift approx. 3 weeks ago. Instantly had the roar from front end of my truck.replaced front wheel bearings which helped but did not eliminate the noise so I got the clamshell bushing from east cost gear supply and installed it....noise is gone. Great big thanks to chase and guys at Ecgs.
    ECGS likes this.
  17. May 16, 2015 at 6:19 AM
    #2357
    jace1905
    james
    East Tennessee
    Oh and I must say that the help I have gotten from this and other threads on here is an awesome resource. Thanks to everyone
  18. May 16, 2015 at 6:03 PM
    #2358
    jasclair
    joshua
    Bend oregon
    So I installed my differential drop kit an my tacomas vibration and noise is pretty much gone. I still feel it but just barely AnD only when I try to feel for it... Definitly recommend trying the diff drop to see if it helps.
  19. May 17, 2015 at 8:41 AM
    #2359
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Been there, done that. It'll slowly get worse, so it's a temporary fix.
  20. May 17, 2015 at 7:07 PM
    #2360
    jasclair
    joshua
    Bend oregon
    Yup, you are right I spoke too soon... I can feel it getting worse. Still not as bad so I hope it doesn't get worse
