OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. May 17, 2015 at 7:07 PM
    #2361
    jasclair
    jasclair Well-Known Member
    joshua
    Bend oregon
    Current: BHLM, plasti dip badges/bumper, Satoshi homer taco style grille, custom TRD, pack rack Marshall fab, window tint,interior paint job, ome lift,wheels spacer, white light interior, retrofit headlights.
    So anyone have a tool for sale?
  2. May 17, 2015 at 9:38 PM
    #2362
    ttran076
    ttran076 Well-Known Member
    Orange County, CA
    2014 Tacoma Sport 4x4
    Kings, TC UCA, Dakars, Prinsu rack, ARB Snorkel, Method NV, Wildpeak AT3
    @jasclair You in luck! I got an install tool that I will pay it forward to you. Just shoot me a pm and we can work out the details.
    Also a quick shout out and thank you to @kmcivor for paying it forward to me first.
  3. May 19, 2015 at 2:38 PM
    #2363
    Naturallm6
    Naturallm6 Well-Known Member
    Northern California
    15 Tacoma TRD Sport 4x4
    I also need a tool if anyone has one. Need to do mine soon.
  4. May 19, 2015 at 3:15 PM
    #2364
    jasclair
    joshua
    Bend oregon
    Idk how long you want to wait but once I get my tool and install the bearing I'll pay it forward to you.. But idk how long it will take...
  5. May 19, 2015 at 5:57 PM
    #2365
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Not to undermine ECGS but you can fab up a puller with a bunch grinder and some basic hardware. I am reluctant to foward mine because the first bushing failed due to a incorrect install and I have a habit of holding o to tools. A tip on the install tho, be sure the correct driver is used, not "close enough" but just right.
  6. May 21, 2015 at 8:56 PM
    #2366
    SpicyTacoSteez
    SpicyTacoSteez Well-Known Member
    Denver
    2005 TRD OffRoad DCSB
    2016 TRD offroad Suspension, RCI Sliders, RCI IFS Skid, RallyArmour mud flaps, Magnaflow, ultra gauge, ECGS bushing, SCS F5, BHLM headlights, Jason Cab high topper
    Anyone else have an extra puller tool they wanna pay forward or even sell? Instantly got the notorious growl only after an 1.5" of lift. Any help is appreciated!
  7. May 26, 2015 at 9:10 AM
    #2367
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    Looks like I need a tool too if anyone wants to sell one or pay it forward!
    Thanks Jared
  8. May 28, 2015 at 5:53 PM
    #2368
    justinalldredge19
    justinalldredge19 Well-Known Member
    Justin
    Arab, Alabama
    How long did it take for your bushing to go out? I've had my installed for about 20k miles on the factory cv due to the fact it looked and felt fine. The growl was gone for a long time but about 4k miles ago it seems worse than before. Wondering if it just might be the cv or I might have installed it wrong....or both. Did ECGs send you another one or did you pay for it?
  9. May 28, 2015 at 9:42 PM
    #2369
    blacksandtaco
    blacksandtaco Well-Known Member
    Not to jack this question but I'd like to know more about this as well along with the symptoms (aside from the initial vibration) that turned you onto thinking the install was done improperly.
  10. May 28, 2015 at 10:26 PM
    #2370
    jasclair
    joshua
    Bend oregon
    Mine went out after around 250 miles after my lift
  11. May 31, 2015 at 5:30 AM
    #2371
    justinalldredge19
    Justin
    Arab, Alabama
    Ok so something else i noticed yesterday. My vibration/growling starts at about 50 and continues on through 65 mph which is mostly what i drive since I'm on the highway so much. Well yesterday while mowing some lawns i noticed that with the trailer and lawn mower on the truck the vibration and growling sound were almost gone. I guess because its maybe letting some pressure of that CV and bushing??
    but to answer the question, i installed the bushing myself and I'm in no way a mechanic. Knowing the luck i have more than likely i installed it wrong which is causing the vibration/growling to come back after.
  12. May 31, 2015 at 7:07 AM
    #2372
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Everything you just said points to it not being the bushing. Those speeds aren't correct and adding a trailer would make it worse because that would raise the front end and increase the CV Angles. Sounds more like a wheel bearing especially when you add the trailer which will raise the front a little taking some of the weight off the front wheels.
  13. May 31, 2015 at 7:29 AM
    #2373
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Yea, that doesn't sound like the bushing. While driving at your posted speeds, turn left and right to load/unload each wheel bearing. The bad one will growl when loaded. Then quiet when unloaded.
  14. May 31, 2015 at 8:12 AM
    #2374
    Sideways1
    Sideways1 Old Dirt Rider
    Dan
    Portland Oregon
    2015 TRD Sport 4x4 DCLB Pyrite Mica
    ADS 2.5 with Extended travel/ADS 2.5 Piggyback rear. Dakars. Pelfreybilt Aluminum front bumper,Skid and Brute Force Fab HC rear bumper. 5 x SCS Stealth 6's in Matte Bronze wrapped in Nitto Ridge Grapplers. Wet Okole front and rear seat covers. Wilco Bed Rail Tire Carrier. Light Racing Upper Control Arms. Marshall Fabrications sliders with kick out. Mobtown Tailgate Reinforcement Skin. hyper15125 retrofits. And many many odds and ends.
  15. May 31, 2015 at 12:15 PM
    #2375
    justinalldredge19
    Justin
    Arab, Alabama
    If the wheel bearing is bad shouldn't there be some play in it?
  16. May 31, 2015 at 12:18 PM
    #2376
    justinalldredge19
    Justin
    Arab, Alabama
    That's kinda what I was thinking. Just after reading some more I started to question if I installed it correctly.
  17. May 31, 2015 at 4:17 PM
    #2377
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    [QUO
    "justinalldredge19, post: 10310619, member: 107672"]If the wheel bearing is bad shouldn't there be some play in it?[/QUOTE]
    yes. You are hearing the play in the sound of the growling noise. Early indication of wear out. Just take it to a shop.
  18. Jun 1, 2015 at 7:57 AM
    #2378
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    This or some rear driveline vibration
  19. Jun 1, 2015 at 8:59 AM
    #2379
    jasclair
    joshua
    Bend oregon
    So took a 6 hr trip to whiskeytown and noticed the vibrations seem to always occur when giving gas. Is that normal? I have my part coming in today and might install tomorrow but just curious if this is normal.
  20. Jun 1, 2015 at 9:23 AM
    #2380
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    Truck has been having some slight vibrations under breaking and highway speed. Jacked it up over the weekend and noticed some growling coming from where the CV goes into the Diff along with some play in the bearing... Needless to say just ordered the whole kit to replace it. Thank you East Coast Gear for the fix on this.
