OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jul 19, 2015 at 8:41 AM
    #2461
    NewfoundlandTaco
    NewfoundlandTaco Well-Known Member
    Newfoundland, Canada
    06 TRD Offroad Indigo Ink
    Billy 5100 at 2.5", 1.5" blocks, tailgate theft mod, extra bed D-rings. General Grabber AT2's.
    Are you sure you have it set up right? I can't see how the threaded plate could pop off the threaded rod? take a picture of your set up
  2. Jul 19, 2015 at 9:00 AM
    #2462
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Screw it on before before sticking it in the diff to see if it's stripped.
  3. Jul 19, 2015 at 9:13 AM
    #2463
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Re-tapped and pulled. All is well.
    Edit: Not sure what happened. Maybe nicked the first 2 threads when I punched it in. Tap went in smooth then bolt threaded on fine right after... :notsure:
  4. Jul 19, 2015 at 8:52 PM
    #2464
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Good to hear man. Never fun to have those moments
  5. Jul 20, 2015 at 9:12 AM
    #2465
    clear4dep
    clear4dep Member
    Vacaville, CA
    08 Silver Dcab LB TRD Sport
    Gater Saver Pop N' Lock electric tailgate lock Wet Okoles Weathertech Floor Liners ScanGauge II Dashmat signature series
    Any tips on removing the axle assembly from the differential? I tried the slide hammer but didn't have a hose clamp so couldn't keep the claw engaged. Tried prying at the mating surfaces also, but to no avail. I'm sure I'm being too gentle and need to just muscle up a bit. I intend to pick up a couple hose clamps on my way home and give the slide hammer another try. But let me know if you guys have any additional tips or if it's just a matter of more force.
  6. Jul 20, 2015 at 9:53 AM
    #2466
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    Get a heavy crow bar that won't flex and a 5 pound shock hammer. Brute force and swear a lot. That's how I got mine off.
  7. Jul 20, 2015 at 11:08 AM
    #2467
    NewfoundlandTaco
    Ditto. Had a 2 foot pry bar and just pushed until it popped out. Came first try, it'll come with enough force.
  8. Jul 20, 2015 at 12:11 PM
    #2468
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Big heavy pry bar. Work your way around and it will pop off. Don't be as gentle as you want to be.
  9. Jul 20, 2015 at 9:09 PM
    #2469
    06tacodude
    06tacodude Well-Known Member
    IG: @go_nesw
    Morgan Hill, CA
    06 TRD Sport 4x4
    Icon Stage 4, TC UCA, K&N filter, SG-II, Relentless Fabrication bumpers, RCI Sliders and tank skid, BajaDesigns LED, URDMAF, 4.56 Yukon Gears, Rear ARB locker, ARB dual air compressor, RLD cap, Prinsu cab rack, FNWheels Six Shooter.
    Update 7/20/2015: Drove approximately 900 highway miles. No issues; only wished I had done this sooner. Definitely have been enjoying the quiet vibe free ride at city streets. I have just re-installed the top plate spacer (5100+885) which puts me back to 3" lift and no issues at all; smooth quiet vibe free ride. Big Smiles!
    Alignment and new tires this Thursday. Bigger Smiles.
  10. Jul 20, 2015 at 9:12 PM
    #2470
    06tacodude
    IG: @go_nesw
    Morgan Hill, CA
    06 TRD Sport 4x4
    Rotate the axle 1/4 turn then pry; repeat. There is a sweet spot where the CV axle just pops out. I used a 32" Pry bar and was pushing(not kicking) with my foot. TYhe trick is to rotate the axle and pry, rotate and pry, I also lifted the inner CV axle so that it was centered and clunk it just popped out without much effort. It came out on the third try.
  11. Jul 20, 2015 at 11:21 PM
    #2471
    clear4dep
    clear4dep Member
    Vacaville, CA
    Thanks guys. I was able to get the axle out with a few strategic prys. Like you said, gets to a spot and finally just pops. I used the ECGS removal tool to remove the needle bearing. After that, I quit for the evening. Tomorrow's tasks are to remove the old seal, install the ECGS bushing, and then start putting things back together.
  12. Jul 21, 2015 at 1:49 AM
    #2472
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    I ended up not installing my bushing, rather I installed a new clamshell from ECGS with an ARB locker in it. I need to post the tool and bushing up for sale when I get home.
    But I'm glad to see I'm not the only one who struggled with the CV. My passenger side popped right out, but I spent hours on the drivers side. Different pry bars, hammers, lots of cursing! Finally I went to harbor freight and got a thin 24" pry bar with a big handle and it magically popped out. I think every front diff has worked that way for me. One side is easy, the other side causes hell until it just slides out like nothing. Frustrating to say the least.
  13. Jul 21, 2015 at 11:50 AM
    #2473
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    What's the best way to pop the CV Axles off then? Pry Bar? Slide Hammer? Have all of the above readily available?
  14. Jul 21, 2015 at 12:09 PM
    #2474
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Slide hammer and big hose clamp. I used a steal cable and 5 lb hammer and hose clamp and that worked great.
    Hartford likes this.
  15. Jul 21, 2015 at 4:41 PM
    #2475
    briximis
    briximis New Member
    Frank
    2015 Tacoma TRD offroad
    ready lift leveling kit
    2015 Tacoma trd offroad. ReadyLift SST leveling kit. 20 000km. Guess what?
    I'm part of the front diff vibration club.
  16. Jul 21, 2015 at 4:43 PM
    #2476
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Welcome and congratulations! :wink:
  17. Jul 21, 2015 at 10:25 PM
    #2477
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Replaceing the bearing with the bushing is not as bad as it might sound. And that smooth ride feeling. Priceless
  18. Jul 22, 2015 at 4:51 AM
    #2478
    MTopp
    05 SR5 4x4
    Yes it is priceless for sure
  19. Jul 22, 2015 at 5:13 AM
    #2479
    briximis
    briximis New Member
    Frank
    Well the dealer is going to repair under warranty. They are going to replace the needle bearing. But this could be a temporary solution. Once the trucks warranty has expired I will have the bushing installed. Only if it acts up again. I don't think the dealer would want to put a third party part in under the manafacturer warranty. Although this dealer is very good and is all about service. They sell leveling kits and lift kits as a dealer option and honor the manafacturer warranty.
  20. Jul 22, 2015 at 6:50 AM
    #2480
    Dilleytech
    Jakob
    07 AC SR5 4x4
    You should mention it since ECGS claims there biggest costumer is Toyota dealers. Yours might not, but some others have.
