OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Aug 25, 2015 at 1:31 PM
    #2521
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Mine started when the truck was brand new 2015
  2. Aug 25, 2015 at 1:36 PM
    #2522
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    Did everyone else replace both? It sounds like its just my driver side that is bad.
  3. Aug 25, 2015 at 4:30 PM
    #2523
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    That's ridiculous. I hope you took it in to have them fix it.
  4. Aug 25, 2015 at 4:36 PM
    #2524
    YotaDriver631
    '18 Taco
    They said "no problem found" gonna try another dealer.. I have 3 within 10 miles of my house
  5. Aug 25, 2015 at 5:28 PM
    #2525
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    You might want to just pay a professional to diagnose it
  6. Aug 25, 2015 at 5:30 PM
    #2526
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Is there any play when lifted?
  7. Aug 25, 2015 at 5:34 PM
    #2527
    nj636
    Kev
    Jersey
    I helped a friend replace a wheel bearing recently. we really thought it was the passenger side with all of your same symptoms. we pulled the passenger side apart down to the hub and it seemed to be in good shape, minimal play. We checked the driver side with the tire on and it was tight. We tore it down to the hub and could immediately smell the burnt bearing. Replaced the bearing and found the torn cv dust seal. Drove the truck and all was good.
  8. Aug 25, 2015 at 6:37 PM
    #2528
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    So I just replaced mine along with the seal, I decided to replace the diff fluid while I was at it and now I've noticed a leak coming from where the axle goes into the diff housing. The only thing I can think of is I think I over filled it with oil a little bit. Anyone have any ideas?
  9. Aug 25, 2015 at 8:30 PM
    #2529
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Sounds like the seal isn't properly seated. I've heard they're difficult.
  10. Aug 25, 2015 at 9:15 PM
    #2530
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    ^^ This, gotta replace the seal if you haven't or reseat it probably
  11. Aug 25, 2015 at 9:30 PM
    #2531
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Do you know how to seat it properly?
  12. Aug 25, 2015 at 10:02 PM
    #2532
    samiam
    Sam
    Stinky Vegas
    I haven't done it yet, but very soon. I'm sure someone will pop in who has done it, but unfortunately I think you'll need to remove the the axle again.
  13. Aug 26, 2015 at 4:37 PM
    #2533
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    When you take it out, pay attention to the way it was seated. Use a 2" PVC coupling to drive it in. Be patient and drive it in even. The seal was the easiest part IMO. Although getting the old one out was a pain without a puller. I believe it only drives in so far.
    Taco Suave[QUOTED] likes this.
  14. Aug 31, 2015 at 11:33 AM
    #2534
    Old School
    Old School You are ignoring covfefe by this member.
    I saw a thread on TW yesterday, can't find it today, OP was talking about a TSB at Toyota about the needle bearing in the drivers side front diff.
    So I went by the dealer today, and helped my service advisor find the TSB 0026-15 I think.
    The advisor ordered all the parts, will call me and schedule an appointment when the parts come in!
    We'll see, I don't know if or how the needle bearing would be different, but if this doesn't work, they may have to put a bushing in to get me off their back!:laughing:
  15. Aug 31, 2015 at 2:19 PM
    #2535
    J4m3z420
    J4m3z420 Active Member
    James
    Keystone, CO
    09 DCBS TRD Off-Road V6 4x4
    Front: OME 884x | 90021 | Light Racing UCA’s Rear: CS047R (minus top overload) | 60091 FN Six Shooter 17x8 6-139.7 (20lbs) BFG KO2: LT265 /70 R17 112S C1 RWL (45lbs) ECGS bushing front diff
    Installed my ECGS bushing 2 weeks ago. Came out super smooth, but found my old needle bearing was broken. A small piece of the edge was broken off. Not sure if I did this during removal or if it broke before or after lifting. I had fast vibrations, humming, and growling from 32-50mph that went away in 4WD. After install, I took for a test drive and had 0 humming or vibrations. Over the past 2 weeks I feel it has come back ever so slightly, but without the growling noise. Could just be my imagination, however I do feel a slight buzzing at random speeds now that I didn't really have before. Still have driveline vibrations in the rear that was almost fixed with a 3deg shim, skinny forward.
    Starting to think my wheel bearings are going bad. Upon removal of my CV axle from the spindle, I noticed the seal at the back of the spindle/hub, and the little silver ring, spring, had slightly come out, so I put it back around the edge before reinstalling the CV axle into the spindle and hub. Going to do new bearings before the winter or maybe next spring.
    Anyone else found their stock bearings broken? Anyone still experience slight vibes?
    Stock Needle bearing
  16. Aug 31, 2015 at 2:43 PM
    #2536
    06tacodude
    06tacodude Well-Known Member
    IG: @go_nesw
    Morgan Hill, CA
    06 TRD Sport 4x4
    Icon Stage 4, TC UCA, K&N filter, SG-II, Relentless Fabrication bumpers, RCI Sliders and tank skid, BajaDesigns LED, URDMAF, 4.56 Yukon Gears, Rear ARB locker, ARB dual air compressor, RLD cap, Prinsu cab rack, FNWheels Six Shooter.
    When I removed the needle bearing, I also broke it in a very similar way. I had forced the bearing puller tool in which caught the needle bearing housing(facing the differential) and broke it. Later, I was able to fish out the broken piece with a magnet.
  17. Aug 31, 2015 at 7:39 PM
    #2537
    MTopp
    05 SR5 4x4
    I also broke mine in the same way, but it broke after I pulled it all the way out I'm pretty sure.
  18. Aug 31, 2015 at 9:07 PM
    #2538
    sleestak
    sleestak Active Member
    Quick question for those of you that have done the ECGS bushing swap - did you see a need to purchase the $45 bearing/race driver install tool? If not, what is commonly used to create a striking surface to drive the bushing flush to the carrier without causing damage? I see a lot of folks talking about the removal tool, but none referring to the bearing/race driver tool so I figure most aren't finding it necessary.
    I have a leaking axle seal so figured I'd attempt to just swap the bushing while I'm in there in a couple weeks.
  19. Aug 31, 2015 at 9:10 PM
    #2539
    MTopp
    05 SR5 4x4
    I bought the driver tool from harbor freight for ~30 bucks and used a coupon. I liked it, probably easier to use than a socket or similar
  20. Sep 1, 2015 at 6:57 AM
    #2540
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    I agree. Do it right and use a driver tool. Rent one from an auto parts store or pick up a set from harbor freight.
