OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Oct 7, 2015 at 10:00 AM
    #2721
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Same here. Been meaning to fix it. But I hate pulling the skids...
  2. Oct 7, 2015 at 10:17 AM
    #2722
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    That's what I was thinking.
  3. Oct 7, 2015 at 10:25 AM
    #2723
    roguetrader
    roguetrader Well-Known Member
    Only if I want it to drive right
    alignment after any front end work is cheap tire insurance
  4. Oct 7, 2015 at 11:02 AM
    #2724
    Ellman605
    Ellman605 Well-Known Member
    Elliott
    Glen Dirty, MD
    No alignment afterwards on mine. You're not messing with any geometry. Just Unbolting and rebolting
  5. Oct 7, 2015 at 1:24 PM
    #2725
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Yea, most people do not touch the LCA eccentrics(alignment bolts).
  6. Oct 8, 2015 at 3:41 AM
    #2726
    doorsidedown
    doorsidedown Well-Known Member
    I'm having my local shop (trick trucks - mostly a lift installer) install the bushing tomorrow. They've never done this exact install, but have extensive experience re-gearing and replacing diffs. I don't have the time to do it myself, any tips I should tell them before they crack it open? I bought the bushing, seal and tool to pull the old bearing out. After the install, I'll send my tool out for loan to anyone who needs it... Thanks for any advice.
  7. Oct 8, 2015 at 1:11 PM
    #2727
    Ellman605
    Elliott
    Glen Dirty, MD
    Maaaaaake sure they are fully aware to make the tool completely centered. I think that's where I messed up the first time.
    MTopp likes this.
  8. Oct 8, 2015 at 2:16 PM
    #2728
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Just over 20k on mine in the double cab. Still nice and smooth :woot:
    MTopp likes this.
  9. Oct 9, 2015 at 4:30 PM
    #2729
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
  10. Oct 9, 2015 at 7:05 PM
    #2730
    07Speedway4X4
    07Speedway4X4 Active Member
    Seattle, WA
    2007 SWB AC 4WD TRD Sport
    Bilstein 5100's set at 2.5 w/ 1.5" block in rear ATX Mojave II 17x8 with Wrangler DuraTracs
    Just received my bearing today. I'll plan on being after you for Unchained's set of tools. I'll let you know if I find another set.
  11. Oct 9, 2015 at 7:28 PM
    #2731
    MTopp
    05 SR5 4x4
    It's good to see people still saying subd like back in the day
  12. Oct 10, 2015 at 12:35 PM
    #2732
    doorsidedown
    Install is done. Vibes aren't gone - going to try replacing all 3 u joints next. If anyone needs to borrow my install tool, PM me.
    Edit - I do not have a bearing driver, just the puller from ECGS.
  13. Oct 11, 2015 at 6:44 PM
    #2733
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    Got my bushing installed today and two seals, one in diff and one in hub. Should've done the seals on the cv axle too as they didn't look very good either. Has anyone serviced their CV axles, like taken off the boots, cleaned the knuckles of old grease and repacked it then replaced the seals on the axle? Or is it more time and cost effective to just replace it?
    Anyways the bushing wasn't too hard but would've been easier with a race/bearing driver. I spent the majority of my time trying to get out the stripped diff drain plug (thanks previous owner/mechanic). Tried a a bolt extractor first which didn't do anything because the only wrench that would fit it was a 12-pt 5/16 which is tiny, wanted to bend and rounded off the closed end. Tried combination wrench too but it only rounded off the extractor. So went to drill and tried every torx head socket until 10 mm by drilling and pounding it in with a hammer. Finally got the T55 to go in after drilling all the way through the drain plug and pounding the whole torx socket into it. Finally gave, even after aggressive use of PB blaster, which seemed to have no effect on it. Replaced both fill and drain plugs with non-hex headed bolts, drain from Goldplug and fill from autozone. Also managed to damage both the tie rod end and upper ball joint from trying to break them free (rookie mistake), they were probably on their way out anyways. In the end, the noise was better but I still heard the noise I thought was either the wheel bearing or spindle bearing. Replaced both front wheel bearings and needle bearing, but still heard a brwaaapp sound between 30-40 mph. What could it be?
    Below was the result of hours of trial and error on the drain plug:
    Now all my drivetrain fluids are finally replaced. Next up will be coolant, but probably leave that to the professionals, unless their is a DIY here. I have the bearing removal tool available too.
  14. Oct 11, 2015 at 7:29 PM
    #2734
    beavis87
    El Paso
    '10 Silver TRD OR
    Sorry I meant needle bearing. No, i dont have a coolant removal tool but I do have the bearing removal tool.
  15. Oct 11, 2015 at 7:47 PM
    #2735
    Taco'09
    Taco'09 Well-Known Member
    TSB is a JOKE
    And the joke is on us. Toy is using the same needle bearing for the TSB.
    Way to go Toyota. Not.
  16. Oct 11, 2015 at 8:39 PM
    #2736
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you hit up a parts fiche of the replacement part number it states "needle bearing" for the description.
  17. Oct 11, 2015 at 9:26 PM
    #2737
    Taco'09
    I Eat (Partial) Crow
    T-SB-0026-15 was issued May 20, 2015
    The old part number is 90364-35010, needle bearing
    - For 2007-2014 FJ Cruisers and 2005-2015 Tacomas the new part number is 90364-35008, needle bearing
    - For 2004-2014 4Runners the new part number is 90364-35010, needle bearing.
    So the 4Runner guys get our junk needle bearing and the FJ Cruisers and us get a different part number.
    I'll order one and see what, if anything, is different. Tough luck 4Runners.
  18. Oct 15, 2015 at 5:19 PM
    #2738
    mbroughton02
    mbroughton02 Well-Known Member
    Michael
    Cortland, NY
    07 DCLB
    OME 884, 5100s, Wheeler's 1.5" Progressive AAL, Firestone Ride Rite, Fisher Homesteader 7'4" Plow, Heated Seats, Viper 5806v Remote Start / Alarm.
    Just a tip for those replacing the axle seal when you change out the bearing for the bushing:
    Several people here mentioned using 2" pvc pipe to drive in the new seal. I could not get this to work for the life of me. It would always go crooked to one side or another. I went searching around the shop for other things with the correct diameter and found a 2" galvanized end cap:
    It fit around the seal much better, had some weight to it, and had a nice surface to pound against. The seal went in right away.
    samiam and MTopp like this.
  19. Oct 15, 2015 at 5:21 PM
    #2739
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    That's why I included the driver tool with the kit I lent out
  20. Oct 15, 2015 at 5:22 PM
    #2740
    mbroughton02
    Michael
    Cortland, NY
    07 DCLB
    I'm a douche. I said bushing. I meant seal. This is for the seal.
