OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Nov 15, 2015 at 7:58 PM
    #2901
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Gotcha. ECGS, recommends another weight other than 75-W90. What did you put in the front Diff?
  2. Nov 15, 2015 at 8:06 PM
    #2902
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    I used 85W 140 as recommended, but I really don't know how necessary it is. Do you still have vibes?
  3. Nov 15, 2015 at 10:22 PM
    #2903
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I currently, have 75W-90 in the front diff now but will go buy 2 quarts of 85W-140 and replace it.
    Yes, I currently am experiencing vibes after the ECGS Bearing install. Mainly when I turn my wheel....especially to the right.
    Which I don't understand, because I replaced both cv axles, both hub assemblies, and did the needle bearing fix.....
  4. Nov 16, 2015 at 6:16 AM
    #2904
    Why J
    Why J I'm the master of my own domain.
    2012 DCSB V6 SR5 Prerunner
    OEM Roof Rack, 3" lift, 1.25" Spidertrax Wheel Spacer, Front skid plate
    If you are still experiencing the brake issue, check that you didn't twist the brake line when re installing. If you twist the brake line it can cause a pinch in the line and will result in the brakes not releasing.
    Vibration being more noticeable in a turn usually indicates a bad wheel bearing. But if your brakes have warped the rotor then you may be getting feedback from that. Also have the balance on the wheels checked.
    Are you running after market wheels?
  5. Nov 16, 2015 at 12:55 PM
    #2905
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I'll check to see if there is an obvious twist in the front break lines.
    I just installed brand new hub assembles from nj636...I don't think it's the wheel bearings.
    When I pulled the Rotors off, I didn't notice any abnormal wear or warpage...
    I will have my front 2 wheels rebalanced and see if it helps.
    Yes, I am running 16 x 8 Eagle Alloy wheels. I have what looks to be 1/4 inch wheel spacers on so they can clear the calipers.
  6. Nov 17, 2015 at 6:47 AM
    #2906
    boris7
    boris7 Member
    SL,UT
    Black 2015 Taco TRD Sport
    Shell, Debadged, OME 885 and Dakars, Camburg UCAs, SCS Stealth 6, 265/75 17 Cooper ST Maxx
    Just got the vibe, 14,000 miles and immediately after the first time 4hi was used. Anyone in SLC have the removal/install tool for rent? I'll wait for a week or so before ordering, after that I'll have it for anyone needing it.
  7. Nov 17, 2015 at 12:26 PM
    #2907
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I didn't use a C Clamp when reinstalling the calipers. They just snugly fit over the rotors.
  8. Nov 30, 2015 at 8:50 PM
    #2908
    Tako9
    Tako9 Well-Known Member
    Gatineau, Québec
    07 Trd offroad access cab SWB
    Hi all, I got vibrations after installing front bilstein adjustable shocks... When I am on 4x4 vibrations goes away. So that doesnt have to do with the cv axle since it turns when in 4x4???
  9. Dec 1, 2015 at 12:23 AM
    #2909
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Dealership replaced only rear trans mount since I'm at 59500 miles. They said that's all they can to do to try to fix the issue. I am not going to argue with them anymore and Just ordered the bushing. Who has the removal/install tools I can borrow?
  10. Dec 1, 2015 at 6:26 AM
    #2910
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    CV Axle turns in both 2wd and 4wd. Switching to 4wd changes the dynamics eliminating the vibration. You got the front diff bearing vibe.
    MTopp likes this.
  11. Dec 1, 2015 at 6:58 AM
    #2911
    Tako9
    Gatineau, Québec
    Ok so you are pretty shure? I guess I will have to do the east coast front diff bearing mod myself. Thanks.
    Kyitty likes this.
  12. Dec 1, 2015 at 8:14 AM
    #2912
    05Moose
    Jim
    If the vibe is cyclical, is strongest around 40 mph, and goes away in 4Hi, then that's pretty much a guarantee. Classic symptoms. Even two of the three is likely 99.99% the bearing...especially if it's felt immediately after lifting.
    You'll probably notice the vibe becomes less if you take a good 40 mph turn to the right.
    MTopp likes this.
  13. Dec 1, 2015 at 8:16 AM
    #2913
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    There is now an "upgraded" bearing available from Toyota as part of the TSB. See post #2645. Not sure if it's any better than the original, but that's what they're doing.
  14. Dec 1, 2015 at 9:51 AM
    #2914
    Old School
    Old School You are ignoring covfefe by this member.
    tsb 0026-15
    Had mine done 2 mo ago, still no issues!
  15. Dec 1, 2015 at 10:02 AM
    #2915
    PaulK
    Paul
    Pittsburgh, PA
    I'm interested to see how well it holds up over time. I had my entire front diff and carrier replaced under warranty at around 12K - it was covered because the Baja has a factory lift - but this was before the new bearing was available. I now have about 23K on the truck and the problem hasn't come back...yet. If it does I'll be getting the TSB bearing on warranty.
  16. Dec 1, 2015 at 10:33 AM
    #2916
    Tako9
    Gatineau, Québec
    Ok thats pretty much all the symptoms I got so should be good! Thanks guys.
  17. Dec 1, 2015 at 1:58 PM
    #2917
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    So after finding this forum thread this morning I dropped off my 2015 Tacoma 4x4 with 9,606 miles on it at Toyota. I've been experiencing a very faint rumble strip type vibration from the foot rest on my driver side floor board for months now but only at 35-45mph. Didn't notice it when switching into 4H. (Truck purchased Feb 2015). I did have an OME Suspension System installed but pretty sure the vibe came first.
    Anyhow, my Toyota dealer isolated the "grinding noise" as coming from the front diff. I was advised that Toyota does have a TSB (Toyota Service Bulletin) for this issue and they are ordering parts under that TSB.
    TSB #0026-15 (Tacoma/FJ/4Runner)
    Dealer tells me this TSB uses modified/altered parts and not the original to solve the problem. Said the fluid sample they took looks clean. They don't see any metal, etc.
    While it was in the shop I had them go ahead and do my 10k Toyota Care service since I'm so close. They put in my Mobile 1 Full Synth and a Fumoto Drain Valve for me. Should have my truck back today and will take it back in once parts arrive.
    MTopp likes this.
  18. Dec 1, 2015 at 3:06 PM
    #2918
    scottclarkinco
    scottclarkinco Well-Known Member
    Scott
    Denver, Colorado
    2014 MGM TRD Off Road
    A lot. Check out my build page.
    Just had my 2014 DCSB lifted a couple weeks ago and immediately got the notorious needle bearing vibes. Set my appointment with the dealership for next Tuesday to do the TSB work. Fingers crossed that solves it. If not, I will then look into the ECGS fix.
    MTopp likes this.
  19. Dec 1, 2015 at 3:06 PM
    #2919
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Nice, good to see Toyota caught on after 10 years
    samiam, TRoss and Kyitty[QUOTED] like this.
  20. Dec 1, 2015 at 6:05 PM
    #2920
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Copies from the TSB 0026-15 dated May 20th 2015
    MTopp[QUOTED] likes this.
