OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jan 15, 2016 at 5:51 PM
    #3101
    Cog
    Cog Well-Known Member
    Reno, NV
    I really can't say better things about the bushing. 0 vibes. Easy install with the right tools. Take your time and realize you will need force on the CV.
  2. Jan 16, 2016 at 5:13 PM
    #3102
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    Cog, I have ecgs bushing and the install tool that came with it. I Connot get it behind the bearing even with some raps! The bearing that is installed looks to be maybe 1/16 further in than flush. Do you have any tricks up your sleeve? The video that chase posted from ecgs shows a slight rap might be needed but I can see that it hangs up on the back part of the race. Soo close and yet soo far.
  3. Jan 16, 2016 at 5:30 PM
    #3103
    Cog
    Reno, NV
    Mine did get hung up a bit. Make sure it is wedged to the point that it will no longer go further into the groove and hit it (I hit mine with a sledge and a brass drift) obviously not going crazy but this is metal on metal, force will be needed. Once in you can tell as it is free to turn inside the groove etc.
  4. Jan 16, 2016 at 5:34 PM
    #3104
    Boneretreiver
    Tom
    Eastern WA.
    Thanks for the quick response, and...the flat side of the puller faces out? Correct? The one I got was used and the impact marks were on the stepped side. I thought I heard Shane say flat side out.
  5. Jan 16, 2016 at 5:41 PM
    #3105
    Cog
    Reno, NV
    Yes the step pointing towards the spider gear. I'm sure it would work the other way also but i like to follow directions lol
  6. Jan 16, 2016 at 6:23 PM
    #3106
    mike175gr
    mike175gr Well-Known Member
    Michael
    Anybody know the answer to this? "If one were to purchase the ECGS kit but was unable to do the work themselves, how many labor hours should it take a shop in my area to do the work?"
    I feel good about doing it, except not sure how hard it is to pull the axle off, and a little nervous about pulling th old bearing out. From the guys that have already done this repair, how long did it take you?
  7. Jan 17, 2016 at 6:04 AM
    #3107
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    I'd say it will probably take you anywhere from an hour and a half to 3 hours realistically if you've never done it before. Give yourself time and make sure you have the tools you need
  8. Jan 17, 2016 at 6:22 AM
    #3108
    wade9986
    wade9986 Well-Known Member
    Ross
    Stuart, Florida
    2020 TRD Sport 4x4 Supercharged
    Magnuson Supercharger OTT Tune TRD Pro Front End Conversion Old Man Emu Lift 285/70/17 Nitto Trail Grapplers 17x8.5 Black Rhino Duggers Fab Fours Front Bumper Smittybilt X20 Winch Rigid Industries Lightbar
    Just FYI for this thread, I've had good luck with Timken bearings in my differentials. They're good quality if you don't go with Toyota bearings.
  9. Jan 17, 2016 at 3:31 PM
    #3109
    MTopp
    05 SR5 4x4
    What bearings and where? Your front differential or your wheel bearings? Your info says you have a 2wd so...no front differential.
  10. Jan 18, 2016 at 9:11 AM
    #3110
    wade9986
    Ross
    Stuart, Florida
    I'm talking differential bearings. I used Timken when I had my 400 hp 5.0 mustang coupled with 3.73 gears. I never had any humming or vibration for the whole time I had the car, about 100k miles. Usually when bearings go out they will make a humming or vibration noise.
  11. Jan 18, 2016 at 11:16 AM
    #3111
    MTopp
    05 SR5 4x4
    Ohh yes, that'd be fine then. Haven't seen that problem here before, but is good to know
  12. Jan 18, 2016 at 2:48 PM
    #3112
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Lifted the front end 2" over the weekend, and now I, too, get to be a part of this exclusive club. Yea.
    Between 35-40 mph I witness an oscillating drone.... ....vtvtvtVTVTVTvtvt........vtvtVTVTVTvtvt........vtVTVTVTvtvt...... Turn on 4-hi and it goes away. Turn it off and after a few seconds it comes back.
    You guys having any luck with the TSB, or should I just go straight to ECGS?
  13. Jan 18, 2016 at 2:54 PM
    #3113
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Some do some don't, I am one of the ones that has had issues with the dealer doing this for me under warranty. I would still go to the dealer, its free and they change your front diff fluid as well. I have a call into Toyota corporate and they are working on getting another dealer to take care of me.
  14. Jan 18, 2016 at 2:59 PM
    #3114
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    What was their reason for the denial? Considering there's a specific TSB for this issue.
  15. Jan 18, 2016 at 3:17 PM
    #3115
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    I called it a vibration and not a groaning/grinding which is what the TSB says its for. They said its very specific and the tech flat out refused to do it, even though when you engage 4x4 its completely gone. I think what happened was they admitted an issue and tried some fixes to resolve it, but they didn't work and all along I was quoting the TSB and asking for it. They denied all along and now I think they don't want to admit they are wrong, so now Toyota will have to take care of it and send me to another dealer. Make sure you say you have a groaning and I wouldn't say vibration only.
    MTopp likes this.
  16. Jan 18, 2016 at 3:23 PM
    #3116
    mgw24
    mgw24 Well-Known Member
    Central Idaho
    2011 DCLB 4WD SR5, 1998 Reg cab 5 lug
    Crappy spacer lift w/AAL, Camburg Balljoint UCAs, Pioneer AVH-X2700BS
    TSB has fixed mine so far.
  17. Jan 18, 2016 at 3:32 PM
    #3117
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I called it vibration. My dealer said, "We found the grinding noise". They fixed it.
    It would seem it's more about the dealer than anything else.
    So far so good on my TSB repair.
    MTopp likes this.
  18. Jan 18, 2016 at 4:19 PM
    #3118
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    I guess I'm going straight to the ECGS. A local guy here, who's done this before and is very generous with his time, offered to do it for me. Has the tools and everything. So I ordered the new bushing. I'll report back with the results.
    MTopp likes this.
  19. Jan 18, 2016 at 4:55 PM
    #3119
    mgw24
    Central Idaho
    Can't go wrong there! Haven't heard anyone say it didn't work for them.
  20. Jan 18, 2016 at 5:05 PM
    #3120
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    lol. "Groaning" vs "Vibrations"?? That's some petty bullshit. Sorry to hear you have to deal with such a dealership.
