OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Apr 25, 2016 at 4:19 PM
    #3481
    Michgnxj24
    Michgnxj24 Well-Known Member
    Virginia Beach
    2010 DCSB
    Jeraco Cap, Viair OBA
    Actually, no. I picked up the materials, but also rented the pilot bearing puller from O'Reilly. Worked perfectly. Just make sure you tighten the puller so the jaws stay open. Once they are open, it isn't going anywhere. The little teeth on the ends fit between the carrier(?) and the needle bearing, holding it in place fairly well. It only took a couple slides on the hammer and the bearing was out.
    camperof6 likes this.
  2. Apr 25, 2016 at 5:26 PM
    #3482
    Tacoman11
    Tacoman11 Well-Known Member
    Josh
    Eufaula/Seminole, Oklahoma
    2011 Black Tacoma Reg Cab 4x4
    1 1/4" spacers, leveling kit 285/75/16 A/T ECGS Bushing installed
    True for the most part but it has a completely different bearing in the tube assembly (a large roller bearing) which is what takes out more play then the needle bearing, thus lasting longer and not having any problems
  3. Apr 25, 2016 at 5:50 PM
    #3483
    Dalton092
    Dalton092 Well-Known Member
    Thanks man, I appreciate it.
  4. Apr 25, 2016 at 6:00 PM
    #3484
    Tacoman11
    Josh
    No problem bud just trying to help keep a fellow Yotee on the road
  5. Apr 25, 2016 at 7:36 PM
    #3485
    t64mech
    t64mech Member
    Rick
    Riverside, Ca
    2014 Access Cab 4x4
    None yet, in the planning stages.
    Had the same amount of play in my half shaft as well as a "clunking" noise under certain conditions, this was after having driver's side half shaft replaced due to failure at 50K. Toyota is now replacing the front diff and rear springs on their dime.
  6. Apr 25, 2016 at 11:02 PM
    #3486
    Tom0662
    Tom0662 Well-Known Member
    Tom
    Iowa
    2016 TRDORSB
    Me = :pout: . Had the ECGS bushing done Monday and drove to work about 2 miles and "thought" it was ok. End of day drive home about 8 miles yippiee....noise and vibes. Approximately 2" lift with diff drop, got maybe 20 miles on it before made noise with oem needle bearing. Did bushing, no joy. Put in 4x4 noise gone. 2wd noise back. Sad part is I don't even have 500 miles on the damn thing yet. Am afraid I may have to remove lift, wasted money. If it weren't for bad luck, well you know the rest. What a bummer, was so excited to get this done and over with.
    I think I may have to get a dial indicator under there as I got under truck and move shaft up and down and still seems like quite a bit of movement is there. If something happens with the diff now since bushing install I do not think the dealer will cover it now. I know it has to be proven that that part caused the failure but the with combination of the bushing and lift I think I am screwed. All my cash has been spent on all this crap too.
  7. Apr 26, 2016 at 6:30 AM
    #3487
    Tacoman11
    Josh
    Here ya go bud
    mpm likes this.
  8. Apr 26, 2016 at 7:13 AM
    #3488
    Tacoman11
    Josh
    Sorry .752" is just a cunt hair over 3/4" my bad
  9. Apr 26, 2016 at 7:33 AM
    #3489
    camperof6
    camperof6 Well-Known Member
    TN
    2016 Taco 4x4
    I hate that for you, might sound dumb but I wonder if it is the bushing is causing the vibs or something else. You are the first person that I have seen with a issue after installing the bushing. Your old vibs should have been coming from the "needle bearing" from the original bearing, this being a bushing makes me wonder. Sounds like you have low mileage also. I had to remove my lift because of the vibs and had someone act as though I was stupid for taking it out. But hadn't installed the bushing at that time.
  10. Apr 26, 2016 at 7:53 AM
    #3490
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Take out the diff drop...
  11. Apr 26, 2016 at 8:01 AM
    #3491
    camperof6
    TN
    2016 Taco 4x4
    Was reading a post earlier and someone asked a question, and got the smart... answer "read the manual" And I'm thinking to myself, What is this wise guy doing on a web-site like this, where everyone asks questions? shouldn't he have his head in his "own" manual instead of nosing around on a web-site. Doesn't he not have better things to do? Sometimes you can spend a hour in your manual trying to find something OR sometimes you can ask on here and get a answer in five min. sometimes with pics to go with it. If you don't want to help others on these forums, get a life and stop "stalking" them. READ YOUR MANUAL OR SOMETHING. sometimes you get answers you wouldn't get if you were face to face I guarantee that!!!
    4WDTrout likes this.
  12. Apr 26, 2016 at 10:10 AM
    #3492
    Dalton092
    Appreciate it man, any way you could get how thick the lip is in it to? As in the thickness on the sides that would go behind the needle bearing?
  13. Apr 26, 2016 at 10:12 AM
    #3493
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    See and I thought the same thing that I am the 1st one as I havn't seen anyone have the issue after bushing. I still want to check the movement with a dial indicator. I am fairly positive it is at least double what Chase @ECGS showed in his video after bushing install. This whole thing has me disgusted and bummed out at the same time....directed at Toyota.
    I thought about doing that too. Actually wanted to go here shortly and do it but is getting windy and cooling off, supposed big storms moving in today. I wanted to check it closer when I did the drop I think it was on the right side bottom of the diff housing there is like a little nub that sticks out and after I dropped it I noticed that nub was awful close if not against that front to rear support brace. Was thinking maybe there is a little vibe which was carrying through that brace. :notsure:
  14. Apr 26, 2016 at 10:30 AM
    #3494
    Tacoman11
    Josh
    Hell yeah bro hang on a few minutes and I'll get it when I get back from lunch
    Tom0662[QUOTED] likes this.
  15. Apr 26, 2016 at 10:44 AM
    #3495
    Dalton092
    Man I appreciate it!!
  16. Apr 26, 2016 at 10:53 AM
    #3496
    camperof6
    TN
    2016 Taco 4x4
    Believe me I understand getting pissed at Toyota about this, but if you think you have double the play in it (going by the video of after the bushing is installed) then you may have a issue with ECGS. I hate it for you either way.
  17. Apr 26, 2016 at 10:54 AM
    #3497
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    Ok, went out and removed diff drop. The left diff support arm is actually what was up against the brace, could see a little wear mark on it already. Anyway took it out and drove it, may be a little bit better but definitely still there and goes away in 4x4. Don't think I mentioned it before but the issue IS better than it was with needle bearing.
  18. Apr 26, 2016 at 11:01 AM
    #3498
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    Yeah, is why I want to check with dial indicator to make sure, but just looks like it is more movement. When dealing with that small amount of movement is of course hard to actually judge it just by sight. I've never mentioned it because of all the flak people get but I am glad right now I did not get an expensive lift and went with the spacer and AAL first. When funds built up again was gonna upgrade but maybe not now, lol. Anyway the space I used was by BDS and they give a 5yr/60,000 mile warranty so I guess if I did have something happen they would cover it from what the installer tells me. :sandwich:
    camperof6[QUOTED] likes this.
  19. Apr 26, 2016 at 11:04 AM
    #3499
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    Thanks for doing that for him Tacoman. I forgot to take mine to work so I could mic it, oh well, you got him handled. :thumbsup:
    Tacoman11[QUOTED] likes this.
  20. Apr 26, 2016 at 11:29 AM
    #3500
    camperof6
    TN
    2016 Taco 4x4
    This is my first CV axle 4x4, and left stock it may be the best truck on the road, but I miss my straight front axle. Had someone say best selling mid-sized truck for 11 years. Well with so many of them being pre-runners (4X2) why wouldn't they be.
