OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Apr 28, 2016 at 10:44 AM
    #3541
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    This is the information I was referring to in my post above.
  2. Apr 28, 2016 at 11:56 AM
    #3542
    Tom0662
    Tom0662 Well-Known Member
    Tom
    Iowa
    2016 TRDORSB
    Appointment for Saturday. Gonna drive it some today and tomorrow and see if some miracle
    happens and it stops.
  3. Apr 28, 2016 at 12:15 PM
    #3543
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    Sometimes Toyotas fix themselves. True story.
  4. Apr 28, 2016 at 12:19 PM
    #3544
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    That stinks. I have to say, I have not heard of another owner experiencing the issue after installing the bushing. It would be very interesting to have a poll of those who've installed it, and what their results were post-installation.
    I have been contemplating putting 5100s on my 2013 for some time, and only setting the front at .85 with the stock OR springs. After following this thread for some time, I am very reluctant to even do that little of a suspension change. I think I will mod the heck out of my 2012 Wrangler instead. Those are very forgiving with suspension changes, due to the solid axle/coil spring combination...it's running a 2" spacer lift currently, and there were absolutely no issues with that after installation. It just sits higher...
  5. Apr 28, 2016 at 12:41 PM
    #3545
    4XO7544
    4XO7544 Active Member
    2016 Inferno TRD Offroad DCSB 4x4
    The root of the problem truly is the the sloppy tolerances between the carrier and spider gear. It creates the environment for the cv axle to move. Why Toyota choose to case the entire carrier instead of machining key elements is just them being cheap, lazy or both. Look at any Dana or ARB carrier, locker, etc. Quality and machined to exacting tolerances. Another fix/upgrade is to move to a ARB Locker. Expensive, but it will likely do the trick.
    BTW, my bearings showed no extreme wear or damage before I got the ECGS bushing. I think the cv axle vibrates against the bearings creating the sound and feel each of us has encountered.
  6. Apr 28, 2016 at 1:04 PM
    #3546
    hollandhunter
    hollandhunter Well-Known Member
    2015 Tacoma DCSB sr5 4x4
    If you can do mods like lifting your truck an wrangler. You can change this bushigg IF yours even does it. I have lifted a bunch of my yotas over the years. An my 2015 was the first that ever gave this issue. Its your truck do what you wish. But if your handy with a wrench dont let it scare you. Its a bad design anyway. Granted i let them fix mine under warrenty but i feel like i could have done it an will do it if it ever messes up again. Then call toyota an tell them what a shame it is an let them have it. Ha. Maybe if they get enough complaints they will fix it by the time to 5th or 6th gen comes out.
  7. Apr 28, 2016 at 2:26 PM
    #3547
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    camperof6 likes this.
  8. Apr 28, 2016 at 11:17 PM
    #3548
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    Well, the way my luck has been going with this does anyone want to make any bets that once it is back to stock and with the bushing that it still makes the noise?? :mad:
    If it does, well, don't know what I will do. Maybe go buy 1000 lottery tickets? Go to a casino and pop in a fresh credit card into a slot machine and do 100 bux a pull and just keep pulling till it won't let me no more?? lol :anonymous:
  9. Apr 29, 2016 at 5:54 PM
    #3549
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    Has anyone with a bad needle bearing noticed that the vibration will go away when turning left at speed? Like taking a curve on a road? Trying to diagnose my vibration
  10. Apr 29, 2016 at 7:48 PM
    #3550
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Any member need to borrow the tools in a week or two possibly? They are on loan (shipped today), could have them passed on to the next person. Respond here or send a message
  11. Apr 29, 2016 at 8:58 PM
    #3551
    camperof6
    camperof6 Well-Known Member
    TN
    2016 Taco 4x4
    Wow, that's nice of you.
    MTopp[QUOTED] likes this.
  12. Apr 29, 2016 at 10:50 PM
    #3552
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    As was said before if you put in 4x4 and noise goes away and comes back in 2 wd probably needle bearing otherwise sounds like maybe a wheel bearing. Try putting it in 4x4 and turn the same way you are talking about and see if it still does it.
    MTopp likes this.
  13. Apr 30, 2016 at 5:47 AM
    #3553
    zth25
    Zach
    Putting in 4x4 makes no difference. My wheel bearings are fine. Idk what else it could be.
  14. Apr 30, 2016 at 6:11 AM
    #3554
    MTopp
    05 SR5 4x4
    Oem wheel bearings? Lift? Hve you replaced the driver side differentialbushing yet?
  15. Apr 30, 2016 at 6:31 AM
    #3555
    zth25
    Zach
    As Far is I know they're OEM. I pulled the drivers side hub off and the wheel bearing was fine. I have 5100 at .85 that's it
  16. Apr 30, 2016 at 7:22 AM
    #3556
    MTopp
    05 SR5 4x4
    Hmm, did you jack up the truck and grab the passenger and driverside tires (not at the same time obviously) at 12 and 6, as if the tire was a clock, and then push and pull?
    If you have any play doing that it's a possible wheel bearing.
  17. Apr 30, 2016 at 11:58 AM
    #3557
    zth25
    Zach
    Tried that, no play
  18. Apr 30, 2016 at 7:30 PM
    #3558
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    I didnt notice you saying anything about what the vibration sounds/feels like? Is it constant or does it fade in and out, (cyclic type noise)?
    If it is constant, I am just throwing this out there, maybe start checking for a metal to metal contact between parts where say a rubber bushing may be like sway bar etc. I would also jack the right side and check that wheel bearing to to rule that one out also. How many miles on the truck?
  19. Apr 30, 2016 at 7:40 PM
    #3559
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    Well took my truck in today and had the lift remove and my noise is now gone. It was actually like the first day I bought the
    truck I was so happy that the noise was gone when I started driving it. All is well again for the time being. :fingerscrossed:
  20. Apr 30, 2016 at 8:37 PM
    #3560
    camperof6
    TN
    2016 Taco 4x4
    Too bad, I just knew it was going to fix itself. cough cough
    SIZZLE likes this.
