OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Oct 14, 2016 at 4:35 AM
    #3701
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Quickest easiest way to tell is to drive it, wait for the noise, and kick it into 4Hi. If it goes away, it's the needle bearing.
  2. Oct 14, 2016 at 4:39 AM
    #3702
    toddwarren2
    toddwarren2 Gig 'em Ags!
    Todd
    Stuart, FL
    2006 2.7L 4-cyl Tacoma 4x4
    3" MotoFab strut spacer 3" SkyJacker Add A Leaf LiquidMetal 20" chrome wheels 275/55/20 Pirelli Scorpion tires TPMS hack (to turn off the blinking light) 1" filter for the 2ndary air pump (emissions control BS)
    I don't have any noise and the vibration doesn't go away when I switch into 4Hi. Actually can't switch into 4Hi when it's really vibrating b/c I'm at 70mph, which is when it's worse. At lower speeds the vib is there, but much more difficult to pin down as to what speed makes it the worst so I can do the 4wd switch and eval the results. Is it possible that all my vibration is coming from a bad wheel bearing on the same side? The bear is starting to click a little, but I can only hear that when it's quiet outside and I'm in my driveway spinning the wheel with my ear to the back side of the wheel. LOL.
  3. Oct 14, 2016 at 4:42 AM
    #3703
    toddwarren2
    Todd
    Stuart, FL
    Here's the best video I could get on the wheel bearing click. It sounds like a dry leaf is being slapped in there. Best description I can come up with.
  4. Oct 14, 2016 at 4:44 AM
    #3704
    js312
    Joe
    New England
    I doubt that's a needle bearing, then. Mine made noise at 30-40 MPH, and it seems like everyone else's did as well. It went away at lower or higher speeds.
    Clicks are usually a bad CV axle.
    MTopp likes this.
  5. Oct 14, 2016 at 4:50 AM
    #3705
    toddwarren2
    Todd
    Stuart, FL
    Thanks man. I guess if I'm going to replace the cv axle I should probably just do the bushing (or new Toyota bearing). I mean, why not, right?
  6. Oct 14, 2016 at 5:13 AM
    #3706
    js312
    Joe
    New England
    Yeah, you'll have everything apart anyway.
    I'd do the bushing. It's tried and true.
    toddwarren2[QUOTED] likes this.
  7. Oct 14, 2016 at 5:36 AM
    #3707
    Ubeslife
    Ubeslife Well-Known Member
    Eric
    Orrville, OH
    05 TRD Off Road
    Level 8 mk6 17" wheels, 265/70r17 nitto terra grapplers, Powerstop Drilled and Slotted Rotors and pads, 2015 New frame swap (courtesy of toyota), Dynomax SS exhaust, Carseat
    Any one have opinions about brands of CV shafts to buy? or not buy?
  8. Oct 14, 2016 at 7:53 AM
    #3708
    js312
    Joe
    New England
    I have 10,000 miles on the NAPA remanned axle I have on the passenger's side and it is doing fine. NAPA was the only place open with it in stock on the Sunday afternoon that I realized I needed it. I do generally have better luck with NAPA parts than other aftermarkets.
    I accidentally cut the boot on my original and didn't want to deal with replacing that. It's easier to swap the whole axle. Plus I drove on it a couple days before I noticed it and it lost a lot of grease, so I was concerned I may have done a little damage to it.
  9. Oct 14, 2016 at 7:59 AM
    #3709
    Ubeslife
    Eric
    Orrville, OH
    05 TRD Off Road
    Thanks!, I was looking at Rockauto cardone, but not sure.
  10. Oct 14, 2016 at 8:13 AM
    #3710
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Google "CVJ axles" they're reman'd factory axles. They also offer upgraded boots as well.
    Blackout14 likes this.
  11. Oct 16, 2016 at 7:12 PM
    #3711
    Bolt79
    Bolt79 Well-Known Member
    White Springs, FL
    2022 Lunar Rock Trail Edition
    Screen ProTech kit, JDMCAR center console organizer, JDMCAR Center Console Armrest Cushion, Toyota door sill protectors, Black Toyota tailgate letter inserts
    Giving this a bump, just to check once more before I place my order...
  12. Oct 17, 2016 at 1:58 AM
    #3712
    Stewball 00
    Stewball 00 Well-Known Member
    Waldport, OR
    06 Single Cab 4X4
    I have one. Pay shipping both ways and you may borrow it.
  13. Oct 17, 2016 at 5:56 PM
    #3713
    Bolt79
    White Springs, FL
    Cool! Can I pay pal you the money?
  14. Oct 18, 2016 at 12:17 AM
    #3714
    Stewball 00
    Waldport, OR
    06 Single Cab 4X4
    PM sent
  15. Oct 24, 2016 at 9:01 AM
    #3715
    toddwarren2
    Todd
    Stuart, FL
    I am getting ready to order the bearing-replacement bushing from ECGS, too. My issue is most likely a bad CV axle and not the needle bearing, but if I'm already that far into the job I might as well replace the bearing.
    I'm getting an up/down wobble/bounce and a slight steering wheel shimmy at low speeds. Like a tire is out of round or something. At highway speed (70mph exactly, actually) the steering wheel is vibrating/shimmying and the whole cab is shaking. I have ZERO noises. Last weekend I replaced both front wheel bearings b/c I was hoping that would fix my issues, but nope. Anyone have an other insight into this? Should I replace my ball joints/tie rod ends/etc while I'm at it? Seems like they are all fine(ish) but I have 186,000 miles on the rig. 06 4x4
  16. Oct 24, 2016 at 10:52 AM
    #3716
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    Did anyone notice the sound at a low speed....when you were coming to a stop?
    I just bought an 08 tacoma and noticed the sound at low speeds.... I definitely hear a womp, womp, womp when coming to a stop (like slowing down on short patches of rumble strip). It sounds like mud tires, but given that it's uneven and not a constant whir I'm confident it's not from the tires. The noise goes away when I engage my 4x4. I also have a slight left to right wheel shake at 60+ (Have not noticed it at ~40 yet). I'm not sure if I notice a 30-40 vibration because I'm still getting use to the truck.
    Think I need to replace the bearing with this bushing?
    MTopp likes this.
  17. Oct 24, 2016 at 5:29 PM
    #3717
    Bolt79
    White Springs, FL
    I'm certainly no expert, but this sounds more like either a front end/steeering component or tire balancing issue rather than a CV axle problem. Normally, with CV problems there will be noise such as clicking when the wheels are turned sharply. Also, you didn't mention whether or not you have visible CV damage such as busted boots.
    When you jack the front end up do you have any play in the steering components? I'd start there and maybe get my tires balanced.
  18. Oct 24, 2016 at 5:31 PM
    #3718
    Bolt79
    White Springs, FL
    If the noise goes away when you engage the 4x4, that's a good sign that it's the needle bearing. Is the truck lifted?
  19. Oct 24, 2016 at 5:50 PM
    #3719
    toddwarren2
    Todd
    Stuart, FL
    The vibration- which more like a wobble or hop at low speeds and a shimmy at highway speeds- started before my lift. The lift made ZERO difference in the shimmy. Yes, it is lifted about 2-2.5" (strut shims and AAL). The shimmy started when I had stock alloy rims and cheap tires that were about 40k worn. I balanced and rotated those multiple times with no change in shimmy/wobble. I recently put on some after market rims (larger) and good tires. ZERO change in shimmy. Yesterday I replaced both front wheel bearings b/c it felt like that might be the issue(s). Dammit if that made ZERO difference either. I had it back up in the air this aftertnoon to see if I could ID any rear end issues. No play in rear bearings. No obvious gear oil leaks. Drive shaft spins freely (replaced all u-joints front to back) and there is no obvious wobble. Center carrier bearing replaced recently, too. All steering components seem fine-ish. No cv boot blow outs, ball joints and tie rod ends don't have excessive play.
    I am freaking pissed that I can't ID the problem. No noises. No clicks upon steering. 4wd engaging makes no difference. What am I missing?!!
    Crom likes this.
  20. Oct 24, 2016 at 5:58 PM
    #3720
    toddwarren2
    Todd
    Stuart, FL
    Maybe it would be best to replace ball joints and tie rod joints first? I feel like it's in the driveline section somewhere and the steering wheel shake is just telegraphed wobble from something else, but could be wrong. My stick is virtually always shaking/wobbling at highway speeds even when I can't really feel the vibe. Where is the egg-shaped wheel feel coming from at low speeds? Feels like an out of round tire and is subtle most of the time but some roads makes it more pronounced. At highway speeds I feel it in the floorboard/seats and a shimmy on the steering wheel and stick shift. It's driving me mad!
