OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Feb 17, 2017 at 10:09 AM
    #3941
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    a length of 2" pipe will give you the reach you need and you can hammer on it.
  2. Feb 17, 2017 at 10:10 AM
    #3942
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I'll pick some up...gotta remove the shock anyway...my needle bearing was actually fine...never had any issues besides one of the needles was broke. Less slop for sure though.
  3. Feb 17, 2017 at 4:48 PM
    #3943
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    Ok figured out my issue. Long story short ..... took a good hard hit on the left front. When I took off the tire found where the control arm hit the c/v axle. My suspicions are the ECGS bushing and axle seal where damaged. The axle has quite a bit of slop.
    Going to try and replace the axle , bushing and seal .... keeping my fingers crossed.
    Has anyone removed the ECGS bushing with the removal tool ??
  4. Feb 17, 2017 at 4:54 PM
    #3944
    anthony250f
    Anthony
    San Diego, CA
    I wonder if there's enough room since its longer ? I think @blackhawke88 did
  5. Feb 19, 2017 at 6:00 AM
    #3945
    Jtaoj0
    Jtaoj0 Well-Known Member
    Ok this fix is kicking my butt. That said I am ready to put the cv back in. I won't go into what a pain it was to get the tool to seat into the diff.....madness!
    The cv slides part way in but I am sure the c clip is stopping at the splines. Spent probably an hour last night trying over and over...no luck. Any tricks? I had a nightmare that it was something with fit on the bushingBut I looked this morning and pretty sure it is the clip. Help a brother out with getting this together!
  6. Feb 19, 2017 at 6:23 AM
    #3946
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Turn the c clip to where the ends are facing down. This will make sure that as little of it is coming in contact with the housing. Then, with the cv as straight and as compressed as possible, have a helper hit the end with a hammer and a block of wood. Block of wood is important because it protects the cv.
  7. Feb 19, 2017 at 7:36 AM
    #3947
    Jtaoj0
    Thanks, got'er in with a punch. I appreciate your quick reply!
  8. Feb 19, 2017 at 8:29 AM
    #3948
    anthony250f
    Anthony
    San Diego, CA
    Now just hope the seal doesn't leak...as I have found out if you struggle at all you most likely messed up the seal lol
  9. Feb 19, 2017 at 12:43 PM
    #3949
    Jtaoj0
    Hi I replaced the seal as well. Figured while I was in there, best to not chance messing around. But agreed...took it for a drive, got back and thought, huh, leak? Near as I can tell, just really shiny from all the leakage. Ended up do a gear oil change as well since I am st 26200 miles. Anyway crossing my fingers glad it is done, pain in the ass project :)
  10. Feb 21, 2017 at 11:45 AM
    #3950
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    I'd consider myself fairly well versed on the needle bearing issue, but what's the consensus on the amount of lift it takes to have issues? Some say 1.5" on the 5100's does it, others say 2.5" of lift does it. F'n Toyota.
  11. Feb 21, 2017 at 11:52 AM
    #3951
    anthony250f
    Anthony
    San Diego, CA
    It doesn't take lift to have this issue.
  12. Feb 21, 2017 at 11:56 AM
    #3952
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    ^ this. if there's a tsb for it, then it happens to stock trucks
  13. Feb 21, 2017 at 12:03 PM
    #3953
    Larueminati
    Western MA.
    No kidding... jeez i think I already have the problem then though very minimal. No difference between 2WD & 4WD though. Always chalked it up to my ST MAXX tires.
    I'm outside warranty, around 70,000 miles. Going to have to do the ECGS install myself.
  14. Feb 21, 2017 at 12:25 PM
    #3954
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    They have issues with or without a lift,its bullshit Toyota design that's the problem,I test drove a brand new Tacoma off the lot,and can feel a ton of vibrations even a brand new truck !
    hueman562 likes this.
  15. Feb 21, 2017 at 12:37 PM
    #3955
    Larueminati
    Western MA.
    So then yeah i'm assuming I already have this issue and have been living with it. Some of the needle bearing video's I've watched were more of a growl sound where you can hear the needle bearing humming so I was expecting it to be alot worse and louder. Mines barely noticeable now. Hope mine doesn't get worse when it goes up 2" this weekend.
  16. Feb 21, 2017 at 4:27 PM
    #3956
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    I have the ECGS needle bearing removal tool. Used once $30 priority shipped to your door! PM if interested
    That's 50% off
  17. Feb 21, 2017 at 4:51 PM
    #3957
    lynlan1819
    Tacoma
    Lifted
    I will take the tool,pm sent
  18. Feb 21, 2017 at 7:39 PM
    #3958
    Jtaoj0
    That is way better than 50%. Shipping would be another $10!
  19. Feb 21, 2017 at 7:43 PM
    #3959
    KILLINTIME
    KILLINTIME Like a Villain
    The tool I used, and several more, are floating around for free. All you do it use it, and send it to the next person that needs it.
    MolonLabeTaco and Taco Jax like this.
  20. Feb 21, 2017 at 8:00 PM
    #3960
    06TXED
    Tony
    Aurora CO
    Anyone ever remove the ECGS bushing ? Think I may have damaged it. I have the removal tool for the needle bearing but don't know if it will work to remove the bushing ?
