OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Apr 25, 2012 at 3:02 PM
    #501
    SummitCo.Skier
    SummitCo.Skier Active Member
    Keystone, CO
    08 Tacoma...3in lift...TRD Off-Road
    ohhhhhhhh....that's easier said than done........I can barely change the oil myself :rolleyes:
    and as I read before....going to the dealership and having a new diff wont work, or it will for just a while???
    This is TOTALLY unacceptable from Toyota, it would be different if they were a "new" company
  2. Apr 25, 2012 at 3:15 PM
    #502
    codyb1
    codyb1 Well-Known Member
    Cody
    Utah
    2015 TRD Sport DCLB
    Toytec Boss Coilovers set at 3" with AAL's,Toytec Boss Rear shocks, LR UCA's, Swaybar Relocate, Diff Drop, 265/70 Nitto Trail Grapplers, 17" KMC wheels, K&N, Limo Tint, 4.7" Shorty Antenna
    New diff will only fix the problem for a couple of thousand miles (Maybe).. There has to be someone in Colorado that has done the swap for the bushing that can help..
  3. Apr 26, 2012 at 6:59 AM
    #503
    tacobronco
    tacobronco New Member
    Chase, can you clarify the seal depth? I think you actually do install the structural part of the seal (rubber coated metal part that you pound in) flush with the inset, which leaves the smaller rubber lip flush with the outer step, or even protruding a bit. At least this is what a cross section drawing in the FSM shows. I think if the structural part of the seal was only flush with the outer step it wouldn't be securely installed, and the smaller rubber lip would run into the axle dust shield when it is installed.
    Chase, does this sound right?
  4. Apr 26, 2012 at 8:37 AM
    #504
    SummitCo.Skier
    Keystone, CO
    well.....4hi doesn't really seem to do that much, if anything MAYBE a 10% improvement....I'll 'thankfully' just chalk it up to 2 bad balances :-/
  5. Apr 26, 2012 at 12:23 PM
    #505
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    If the vibration only started after installing the new tires, then I would say it is simply your new tires. If you had new wheels installed as well, it could simply be that as well. If you find that it is not the diff, just get your tires road force balanced and ensure you're using extended thread acorn style lug nuts.
  6. Apr 26, 2012 at 12:40 PM
    #506
    BlackSeven
    BlackSeven Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    All trucks have the problem, it's just a matter of time until it shows up. If you watch the video from Chase it explains the problem. Your true 33's just made the problem finally shine it's head.
    Put the bushing in. If you can't do it yourself, have a local 4x4 shop do it. You'll be much happier with the bushing installed.
  7. Apr 26, 2012 at 1:59 PM
    #507
    SummitCo.Skier
    Keystone, CO
    So, I'm going to sound real stupid but I don't know what that is...sorry?? Is that different than the machine balance that they have been doing??? This was done at Discount Tire btw :eek:
  8. Apr 26, 2012 at 8:28 PM
    #508
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Discount Tire should have a RF balancer. But if your running aftermarket rims you may need the right lug nuts to center the wheels also. Most likely just a balance issue. If it happens around 60-65mph for sure. Many threads on that. The vibration related to this thread can be very subtle - maybe the 10% you mentioned.
  9. Apr 27, 2012 at 12:15 AM
    #509
    ratrod
    ratrod Well-Known Member
    Los Angeles
    2006 Toyota Tacoma Dbl Cab TRD SR5 4x4
    Bilstein 5100s @ 1.75 with 1.5 AAL, Satoshi Grill Mod with 2 Hella 500s behind the grill, LED dome and map lights, custom made (by me) 10" subwoofer box behind the dbl cab seat, DVD/iPod/Bluetooth/GPS/TV/USB/Stereo, Yakima rack, Shell, tinted front windows to match the factory backs. Backup cam in the tailgate handle mod.
    Okay I've been away from Tacoma world for awhile and I posted here at #121, now we are at #527, what the hell did I miss? What's this new fix for the vibe? There's a video? Crap I need to catch up, anybody have the Clift notes? My truck has been fine since diff replaced and even got new bigger tires but still worried about this issue. Someone fill me in! Guess I better start reading.
  10. Apr 27, 2012 at 8:20 AM
    #510
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Short end of the story ^
    People are getting vibes from the needle bearing on the drivers side diff . Some people that had the diff replaced claim the vibes came back in X amount of time/miles . East coast gear supply came out with a bushing to replace the needle bearing . So far I haven't heard anybody say the vibe has come back after installing the bushing . They have the bushing and removed tool available on there website .
    I have around 5k miles on the bushing and still have no vibes .
    Hope this helps .
  11. Apr 27, 2012 at 8:33 AM
    #511
    Hard
    Hard Well-Known Member
    H
    4X4X4
    Has anyone pulled out their CV after a few thousand miles to inspect the bushing? I would just like to confim that that the bushing surface is not wearing before I go for a bushing. Some of these were installed a few months ago now so someone should do some investigating.:D
  12. Apr 27, 2012 at 9:58 AM
    #512
    ECGS
    ECGS Well-Known Member
    Chase
    RALEIGH
    yes you are correct the structural part of the seal flush with the seal bore.
  13. Apr 27, 2012 at 4:50 PM
    #513
    Koby
    Vancouver
    06 access trd
    It's not a stupid question, if you are like me, you learn the hard way! I do everything at Discount as well and they do have a roadforce balancer but they will not do it unless you ask. It is a different way of balancing tires and is simply the best for larger tires. Once again, look into getting the right lug nuts and possibly hub centric rings( I have them and they work, no charge from discount tire). Very common issues...simple fixes.:)
  14. Apr 27, 2012 at 5:07 PM
    #514
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    What did you do to remedy the situation?
  15. Apr 28, 2012 at 10:55 PM
    #515
    mkrespke
    mkrespke Well-Known Member
    Phoenix, AZ
    07 4x4
    I took the differential out of the truck and split the case. I had the old bearing pressed out by a local shop and the new bushing pressed in.
  16. May 7, 2012 at 7:28 PM
    #516
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Local shop just quoted me $320 in labor to do this. I already have all of the parts including a new CV axle, ECGS bushing, axle seal, diff oil, and new differential drain and fill plugs. I hate to pay someone to do something I could probably manage myself, but I just don't have the time or patience that I used to. Does $320 sound about right?
  17. May 7, 2012 at 7:58 PM
    #517
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Email ECGS and ask how much they would charge to do this job, and use that as a baseline. Then shop around various trans and gear shops in your area.
  18. May 8, 2012 at 7:38 AM
    #518
    GP3
    California
    4X4 TRD Off Road
    That's too bad.
    People might want to take note of what can happen if things don't go smoothly.
  19. May 8, 2012 at 12:14 PM
    #519
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    That's precisely why you stuff something inside the needle roller bearing before trying to remove it (I used a sponge, but I think Chase used plastic wrap). Then if it disintegrates, the needles can't go anywhere but out. Someone who did this in the beginning (way back) had it happen and had to cut the bearing out after all the needles came loose. It is a very flimsy bearing that's in there tight.
  20. May 8, 2012 at 2:47 PM
    #520
    GP3
    California
    4X4 TRD Off Road
    :confused:
    A sponge is going to help pull the bearing out of the carrier? :eek:
    Because that was his problem. He wasn't able to pull the bearing out. He had to drop the differential, split the case, and press the bearing out from the inside out.
    It can happen to anyone. I just wanted to let the new armchair mechanics know what they may be in for. It's not an oil change.
