OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. May 14, 2012 at 2:21 PM
    #541
    drsus
    drsus Well-Known Member
    Los Angeles, CA
    4Runner TRDpro
    stock
    took my '12 to its 5k service and brought up issue to dealer. They took one of their 4x4 DCSB TRD OR truck they had in lot and duplicated the exact same problem on their 0 mile truck.
    the guys were pretty blown away that this issue had not been mentioned by other costumers since it SO obvious when it does it. One guy even said "its bad enough that it will spill your fucking coffee man!"
    they are sending their case and observations to some main service Toyota dude in KY. they measured the driveline/angles etc on both trucks.
    he said the more cases they hear about the more Toyota is put in the position to fix it....so get loud.
  2. May 14, 2012 at 9:40 PM
    #542
    Joshbomb354
    Joshbomb354 New Member
    Josh
    Edmonton, Alberta, Canada
    06 TRD Off-Road Tacoma
    Toytec 3" Lift Adjustable Coilovers SPC Upper Control Arms Satoshi Grill Double Din 7" JVC Head-unit JL Sound system 285/75r16 BFG All-terrain Ultra Motorsports Nomad 16" Wheels Custom Magnaflow Exhaust K&N Air Intake PIA Grill Foglights HID 6000k Headlights
    Got mine in the mail a while ago all the way up here in Canada. Those east coast gear supply guys are great to deal with! Plus with my new 3" toytec lift there's no vibrations or anything. Truck rides smooth. Thanks ECGS!
  3. May 16, 2012 at 5:00 PM
    #543
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Ever get that leaky seal taken care of?
  4. May 19, 2012 at 7:27 PM
    #544
    Izzapac
    Izzapac Member
    St. Robert, MO
    2007 TRD Sport Silver Streak
    Bilstein 5100s front (1.75") & rear
    Quick (and possibly dumb) question: I have Billu 5100's x4 on my '07 TRD Sport. Fronts are set at 1.75, and have slight vibration in the front. I have been told that a 1" diff drop should fix CV angles and mostly cure vibes, if not completely cure. My questions is this: If I've raised my front end 1.75", shouldn't I drop the diff 1.75 to return the CV angles to stock? It seems that with only a 1" diff drop, there's still .75" of lift angle on the joints. If so, I can't seem to find a diff drop kit that's more than an inch. Any help/suggestions is appreciated.
  5. May 19, 2012 at 7:44 PM
    #545
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    I wouldn't even waste your time or money on a diff drop . My 2 cents .
  6. May 20, 2012 at 7:55 AM
    #546
    kiteman78
    kiteman78 Member
    I tried the diff drop on my truck with the same lift as yours, and no difference.
    Took it out. Put the bushing in and all will be good as said above.
  7. May 23, 2012 at 8:48 AM
    #547
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    Got rid of my vibe last night! I removed the needle bearing with the supplied tool from ECGS. It was straight forward and very simple, it worked like a charm. I purchased the race driver/install tool to install the new bushing (also from ECGS). The bushing install went very smoothly as well, simply followed directions from their website.
    When I removed the stock CV axle, there were etchings/markings where things were rubbing where they shouldn't have. Prior to tearing the truck apart, I had a new cv axle on standby for replacement. So the new cv axle got installed.
    All in all, I'm very pleased. Prior to the new bushing being put in, the truck vibrated pretty bad (the vibe repeatedly described in this thread), to the point where I didn't want to drive it. Now it feels like its back to stock again, aside from the beefier OME suspension and a slight shudder/vibe at take off up til 10-15mph. This vibe was also there since I lifted it, but I'm gonna play around w/ a combo of removing/installing the diff. drop (installed now) and some axle shims for the dakars. Rep sent to ECGS.
  8. May 23, 2012 at 8:58 AM
    #548
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    After my lift i of course have the driveshaft vibes, but i just found out the first time engaging 4wd since the lift, that i now have a vibe in the right front when in 4hi and kinda whines at a high pitch.
    anyone know what that would b
  9. May 23, 2012 at 9:04 AM
    #549
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    I have a brand new ECGS bushing that was never used. I decided to go a different route. If someone wants to take it off my hands for less than new, PM me.
  10. May 23, 2012 at 2:18 PM
    #550
    BassMaster06
    Dan
    South Carolina
    Which route did you choose?
  11. May 24, 2012 at 7:10 AM
    #551
    SLC TACOMA
    SLC TACOMA Member
    Tim
    SLC, UT
    08 4x4 DC, LB TRD SPORT
    5100's, 1.5 Block, LEER TOPPER, Winter=Blizzack on Stockers Summer=TBD
    I'll take it. PM sent.
  12. May 24, 2012 at 1:52 PM
    #552
    GP3
    California
    4X4 TRD Off Road
    ARB.
  13. May 24, 2012 at 3:54 PM
    #553
    firulice
    firulice Well-Known Member
    james
    utah
    05 DC SWB 4x4 Sport
    3 inch lift (coilovers, leaf pack and shocks Katzkin leather interior Nfab Steps Gibson Exhaust Nfab light bar with piaas and hellas Rear power window Tonneau sport cover
    Hey slc Tacoma... we need to have a garage party one night and swap these out. There is a member on here from west Jordan that is letting me use his puller tool and give me a hand since he's done his already
  14. May 24, 2012 at 4:05 PM
    #554
    Izzapac
    Izzapac Member
    St. Robert, MO
    I installed a 1" diff drop on my '07 Sport and unfortunately...my vibes are GONE!!! I say "unfortunately", because it's just another example of how varied the results are with different remedies. I'm running 5100's all around with front @ 1.75. No TSB rear. After dropping the diff I have noticed a significant reduction in CV angles. No trimming of skid plate or anything. I have 265/70/17 Silent Armors. Time will tell if these results are lasting. For all we know I could be back tomorrow cursing my Taco to hell! :mad:
    If you have a similar build and have vibes, might as well give it a shot. If it doesn't work for you, you'll only be out about 25 bucks and about 20-30 min worth of work. But if it does work, then it's a pretty simple solution.
  15. May 25, 2012 at 7:06 AM
    #555
    SLC TACOMA
    SLC TACOMA Member
    Tim
    SLC, UT
    My buddy has one in Heber as well (puller tool). I need to get seals and then I'm good to go. I had the needle bearing replaced last summer by the dealer but have 15k on my truck since and it's starting to resurface:mad: 5100's set to 2.5
    Might ditch my rear riser blocks and go add-a-leaf since I'll have my sled in the back next Winter....
  16. May 25, 2012 at 4:12 PM
    #556
    firulice
    james
    utah
    05 DC SWB 4x4 Sport
    Cool let me know if you want to make a party out of it and an extra hand, yeah aal is the way to go. I pull a boat with mine with no issues
  17. May 26, 2012 at 3:28 AM
    #557
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    That whine is probably the chain in your transfer case. It's a normal sound, I have it too.
  18. May 26, 2012 at 7:13 PM
    #558
    tim allan
    tim allan Well-Known Member
    Wv
    2017 double cab trd offroad
    update: still no vibes want to lift my truck more now...
  19. May 27, 2012 at 11:10 AM
    #559
    Ugly Betty
    mark
    TX
    cool, thanx. thats what i was hoping
  20. May 29, 2012 at 7:26 AM
    #560
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I need to take care of this too. Would you be willing to sell the removal & install tools? Or, send them to me and I'll send them back when I'm done? (I'll pay shipping both ways, of course.)
    Do you still have the bushing available? I need one!
