OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Aug 12, 2012 at 2:34 PM
    #681
    jandrews
    '09 FourDubDee TRD OR
    Most likely, yes. Alignment or out of round tire than *cannot* be balanced is my primary suspect.
    That said, you'd be amazed what sensations an unhappy driveshaft can cause.
    Caliper slap from the front brakes. Not a worry.
  2. Aug 12, 2012 at 2:40 PM
    #682
    SummitCo.Skier
    SummitCo.Skier Active Member
    Keystone, CO
    08 Tacoma...3in lift...TRD Off-Road
    Not to worry as in, not to worry at all, or not causing the vibration??
  3. Aug 12, 2012 at 2:40 PM
    #683
    jandrews
    Both.
  4. Aug 12, 2012 at 2:45 PM
    #684
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I have that too. brake pads shifting with momentum, normal
    If it was pre lifted, and the vibes came with the truck when you bought it, they should be liable under their certified pre owned warranty.
    Alignment wouldn't shake a sterring wheel, though the out of round tire could very well be the problem, the tech would see that when they balanced the tire if they paid attention to it. And I've had the unhappy driveshaft. I finally found where it was happiest with alot of trial and error. I've got an 1/8th" spacer that has done the trick. And 1+ on the caliper slap. Alot of folks are like OMG! WTF is that? Just the pads shifting.
  5. Aug 12, 2012 at 2:48 PM
    #685
    jandrews
    If your toe is out of spec, it certainly can on the right road surface. Again, this is less common.
  6. Aug 12, 2012 at 2:50 PM
    #686
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    True, tight road surface and grabby tires.
  7. Aug 12, 2012 at 2:54 PM
    #687
    jandrews
    Also, FYI:
    My carrier bearing photo was taken during test fitting. Saw exactly what you saw and went out about 10 minutes after that and got some 50mm bolts (Photo is with 40mm) to remedy. Most here don't notice the "issue". Truck was never driven with those bolts.
  8. Aug 12, 2012 at 3:02 PM
    #688
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Outstanding. I have had three different size bolts over the past year with tons of combinations of drops, and flipping the bearing and shims. It has been a real pain, but finally got the shudder into an acceptable range. Looks like you made your drop yourself, how much of a drop is that?
  9. Aug 12, 2012 at 3:04 PM
    #689
    jandrews
    1in. drop even. I didn't make it, Lowe's has spacers in their hardware section from .25 to 2in in .25in increments. Most any hardware store should have something similar.
    Cost me about $7 and 5 minutes to bolt in.
    20 minutes if you count the return trip to exchange the 40mm for 50mm.
  10. Aug 12, 2012 at 3:07 PM
    #690
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Nice
  11. Aug 12, 2012 at 3:38 PM
    #691
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    TRUST ME WHEN I SAY... its your tires. Had someone at a mod day swap their front tires/wheels with someone else temporarily after they had the same exactly problem as you and guess what... the problem went away. You need to either get with a friend and swap tires, or take it up with your tire company. I've had to balance my tires/wheels 3 times alone just to get mine to go away!
    Tire balancers these days can't handle the crappy build quality of tires such as BFGs. You need a road force balancing setup and even then, those don't work but 70% of the time.
  12. Aug 12, 2012 at 3:40 PM
    #692
    brian
    Elizabeth City, NC
    TIRES/WHEELS Summit. Nothing else. Take it back to your dealership, you WILL NOT pay a dime to them if they sold you it. Tell them to swap for some stock tires and wheels and you WILL see.
  13. Aug 12, 2012 at 5:07 PM
    #693
    Teeps1206
    Teeps1206 Well-Known Member
    Omaha, NE
    '12 DCSB MGM Off Road 4x4
    Roof Rack Rear step (not my choice)
    Just installed the new bushing the other day... NO VIBE! Couldn't be happier. Truck rides like glass now, well close to it but you get the idea. I took a couple of videos while doing it.. figured some on here would like them. Unfortunately I didn't take a video of the actual removal, just a few things I noticed and what helped me.
    http://www.youtube.com/watch?v=9hHbn4eHaqs
    http://www.youtube.com/watch?v=8P68OCu_ZeI
    http://www.youtube.com/watch?v=oS-WosnBb_0
    Yes... I know in one of the vidoes I said "west coast gear supply".. oops!!
    The whole process was fairly simple even though I do not work on vehicles all that often. Maybe working on aircraft has given me some skill I was not aware that I had.
    Few things that I did to make the process go smooth:
    -Put a jack under LCA to keep from falling
    -Removed the bolts connecting the spindle to the LCA, seperated the tie rod, removed 35mm bolt from axle, lightly tapped the axle with a malet taking care not to damage the threads. Onces the axle was clear of the hub, the entire assembly swung out of place. Just be careful to keep an eye on the break line and ABS wires!!
    -The auto hobby shop here on base did not have the slide hammer I needed so I used a large punch and tapped the axle out of the diff housing. Took quite a good hit to release the C Clip.
    -I uses a piece of a thick plastic bag(bag that my cv boot kit came in from toyota) and wadded it up to place inside the diff. This helped keep the small plate from falling inside the diff and really helped keep it center as it springs back and pushes the tool against the bearing.
    -Be sure to keep the tool dead center as you can see from the chip I took out of my bearing.
    Hope some of that helps someone out.
  14. Aug 12, 2012 at 6:29 PM
    #694
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    ^^^NICE WORK, It will be very helpful I'm sure! Rep to you!:D
  15. Aug 13, 2012 at 6:34 PM
    #695
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Yes, excellent job and rep.
  16. Aug 13, 2012 at 7:13 PM
    #696
    Teeps1206
    Omaha, NE
    Thanks!! On that note... I have a needle bearing puller for sale:D. $30 shipping included, paypal only please, PM me if interested.
  17. Aug 14, 2012 at 7:04 PM
    #697
    qnyla
    NM
    Teeps1206,
    In your third video posted above, the wear marks that you can feel I believe are caused by the seal. When dirt and dust get on the seal it causes wear on the shaft where it contacts the shaft. There are minerals in dirt that are harder than the induction hardened steel shaft (for example Garnet is used to machine hardened steel).
  18. Aug 15, 2012 at 5:32 PM
    #698
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    That was it! I changed out both wheel bearings this aternoon and its really quiet now - no more growling. I had to put up the windows, shut off the fan and radio, and just drive along marveling at how quiet and peaceful it is now. I must have gotten used to that noise because now that its gone I'm amaised at how quiet my Michelin Latitude Tour tires are, its quieter than a lot of cars I've been in.
    The CV bushing fixed some of the problem and the wheel bearings fixed the rest.
    Thanks for all the help, posts, and videos. :)
  19. Aug 18, 2012 at 11:02 AM
    #699
    TRD1
    TRD1 Member
    Denver CO
    2005 4 door TRD OFF ROAD
    Billstine 5100 at 1.75 in the front. ECGS front differential bushing. K&N Filter Light up 4wd Switch Vision wheels on Handkook Dayna pro tires 265/75/16
    Looking for The Bearing puller is anyone has one they would like to sell PM me. Thanks!
  20. Aug 18, 2012 at 5:22 PM
    #700
    TRD1
    TRD1 Member
    Denver CO
    Sent you a pm back with my paypal info. let me know if the message went threw. thanks
